Question about McCulloch FHH18A Electric Pressure Washer
Unit is leaking. Just bought it used, runs fine but leaks water out the bottom of the motor. Can this be repaired ? Is there a gasket or o-ring or something to replace ?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
It might be the pcv(positive crankcase ventilation) valve. Go to a parts store and ask for a new valve($5-$10) and also ask where it is. It's usually right on top in the back of the engine where you described. If the hose is all cracked then you might have to get a custom one from the dealer because many stores no longer carry hose strong enough to be used here.
Posted on May 30, 2010
Garbage disposer leaking at bottom
Since you have checked all pipes and see no leaks next please check the area around the top and bottom of drain housing. If that's not leaking there is a gasket inside the disposal that could fail and cause water to leak into the motor area and then leak through the bottom of the unit. Generally in my experience replacing the whole unit is a time saver because access to that gasket is a pain and finding the right gasket can be timely. Depending on how old the unit is I would just replace it.
Jul 06, 2017 | Electrical Supplies
Insinkerator leaks water from the bottom. this is when water runs through. no difference if the unit is running or not
There is no repair, just replace the unit. Once they start leaking, that is fatal. you could not repair for less than replacement of the unit.
Jan 21, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My compressor won't build pressure over 90lbs
Small leak will prevent the unit from building proper pressure. Check all connections with soapy water and repair as needed (including under cover). If no leaks are found check cylinder for scratches. Push piston to top of stroke and check walls for fine scratches. If scratched, pressure is leaking past vinyl piston ring. If no scratches or leaks, most likely reed valves, head gasket or combination of both. Easy test, with compressor running and attained 90 lbs, place finger over air intake and check for good suction (carefull could be hot) . If good suction, then air is leaking somewhere, of no suction suspect reed valves/worn cylinder, if air seems to be blowing out of intake, suspect reeds /gaskets. Good holidays
Dec 13, 2010 | Stanley FactoryReconditioned Bostitch...
Badger 5 is leaking from bottom of unit... is this repairable? Thanks Chad
If it is leaking from the bottom and not from the top and running down the side then it is only repaiable by replacing the disposal, If it the top leaking and running down the side, then it can be rpaired by replacing the rubber gasket on the top.
Nov 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Help! We bought out home 3 years ago and have a Nortiz tankless water heater. Recently we heard a dripping sound coming from the water heater and found that the bottom of the unit is leaking. We had a...
you will need to explain more of where the leak is on the bottom. You have two plastic valves on the bottom and if the clips are not on exactly it will leak and if the person who replaced valves did not use vasoline when they put it back together the could have cut the gasket ring on the inside putting in back together and again it will leak. You have to determine where the leak is coming from to begin with using a flash light to get the exact location. .
Oct 05, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
Leaking dishwasher
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 29, 2009 | Asko Dishwashers
Oster 6700 Gasket O-ring leaks
Gasket is not the problem.
Square shaft that is pressed into the turning gear is not tight and allows leaking through the connection.
Only repair is to replace the assembly with the gear drive, blades, etc. and this will take care of the leak. The "O" ring gasket is fine and holds the liquids. However the leak is around the center of the shaft that goes through the bottom.
Regards,
Gary
Jun 06, 2009 | Oster 6700 Work Top Blender
Lg DISHWASHER INTERMITTENT WATER LEAK
I have this same dishwasher,and have had the same problems that have been described in this forum..
LG model#LDS5811.I bought it from Home Depot as a scratch and dent with no warranty available for about $400.00.
The problems I have seen on my own and have read online have been Intermittent leaks on the left side door,as well as both sides.And in some cases,even wiring and motor problems.
In my case,the water was coming from a leaking O-ring behind the evaporator housing in the door,as well as a small hole in the drain hose in the part of the hose on the left side where the hose loops up the side of the machine behind the panel before it comes out of the back.
You will need to take the left side panel off to undo the wire holding the hose in place as well as remove the bottom plate over the motor to gain access to remove the hose from the pump to get the hose off of the machine.Simply replace the hose.You can order online or buy a replacement at an Appliance Repair store as I did.
To repair the door leak,you will need to remove the lower outside panel that is under the control panel.Inside the door,you will need to turn the vent cover at the top of the door counter clock-wise one-forth turn and remove the entire evaporator unit as a whole.You will see a 1.5 inch O-ring.
I repaired this by getting G.E 100% silicone that you can purchase at a Home Repair store like Lowes or Home Depot and sealing around both sides as well as putting a good bead on top of the O-ring itself,and wipe off the excess after re-installing.
I performed these repairs over a month ago,and have had very good success.No leaks to be seen.I am a A\C,Refrigeration Tech by trade,and have done alot of Appliance repair/installation as a side trade from being a maintenance technician at some very large Grocery chains the last 20+ years.
I completely dissassembled this machine and have found it to be a decent product,but some shoddy materials and questionable assembly practices have created these problems,but good sound engineering.
I hope this helps someone with the problems with this machine so it wont be a total loss.
Nov 06, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
KitchenAid Dishwasher Leaking from under Door
I had a similar problem with a KUDM25SHWH1 dishwasher. Rubber seal looked fine. I found an incredible tip on another fixi it site. One possible problem iss the pump cover screws may have worked loose and is squirting water directly on the door seal. Man that was it! I saw a couple of looses screws and a small portion of the pump cover gasket showing. I loosened the pump top, reset the gasket tightened it all down...no leaks! The pump I refer to is located directly below the spray arm inside the washer. Easy to get to. Another tip was to look for a split sspray arrm that may spray water directly into the door seal.
Nov 04, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Leak off pump housing
Sidewinder, sounds like it's leaking from the pump gasket or the water seal assy on the impeller. Check the locking ring to the pump housing and see if you can increse the pressure to the tub. Also check the tightness of the motor fan assy. to the impeller assy. tighten if necessary. Pump gasket part number is 912529. Impeller seal part number is 903494. Catriver..post back.
Oct 23, 2006 | Jenn-Air 24 in. DW731 Built-in Dishwasher
McCulloch FHH18A Electric Pressure Washer Logo
450 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
