Question about Sharp R-1491 Microwave Oven
Microwave will not work
The fan and lights run, but when trying to work the actual microwave, i get nohting. Could it be a fuse? where are the fuses located? thank you
  • Sharp Master
  • 9,098 Answers
Even though you don't mention the model number, you posted under Sharp model R-1491, so I'll assume that's it.
You say when trying to work the actual microwave, you get nothing?
We could use a little clarification, but FixYa only gives you one shot at posting a help request.
When you enter the cooking time and press "Start", if the timer counts down and the oven lamp comes on, but the the turntable, cooling fan, and microwave section do not run, then you have a bad secondary interlock (bottom door switch) or its mount is bad.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
Also look at this info on door switch diagnosis and replacement.
Hope this helps.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 30, 2010
No power - blown fuse?
If it was run without the fan a thermal protect device was more than likely taken out. Check for that and replace the fan.
Mar 25, 2013 | GE Profile Spacemaker XL 1800 36"...
Kenmore Ultra Wave microwave Model # 665.61652 Quit Working
There are fuses in the unit but why did they go bad? something else has to go bad to cause the fuse to blow, unless the fuse got old or had bad connections at the fuse holder. Can try a new fuse then run and see if it works. Just don't run it empty, just put a container of water in it to test. If it works check all connections and see if any are loose or browned like it has been hot. That's where your problem will be.
Aug 12, 2017 | Microwave Ovens
The oven is totally dead. No light, fan etc. Replaced fuse internally, found no current at the fuse. Outlet has 120 v. Oven was run empty prior to going dead! Any thoughts?
check power between power cord connection and inernal fuse,start at cord connection and work way to fuse conn.eliminating possibe problem area
Oct 11, 2010 | Maytag MMV5000 Microwave Oven
Model is GE JVM1430BD002. Microwave works but range fan and lights do not. Unit "popped" when fan was turned on one time and hasn't worked since. Is there a fuse or breaker for the range hood functions?
Yes - there is an internal "special" in-line fuse. Most likely it is the fan that has caused it. Clean the fan with switch-cleaner spray and make sure it is smooth running. Replace special fuse with identical version.
Check lights before operation.
Replace all covers before test.
Oct 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the fuse for this microwave? The
Generic Comment:
First check the breaker - then check that you are not on a GFI protected line.
Remove the cover. Somehwere probably on the right hand side near where the power cord comes in should be a fuse.
This should answer your question. I dont think this is your problem, however. The fuse Im talking about protects the entire device. You have a burned out light and a fan that doesn't work.
With the cover off, it should be easy to find the light and inspect, check and replace it if necessary. You can inspect the fan at the same time and maybe discover why it isnt running if that is indeed the case.
I hope this helps you
a
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Where do I find the fuse?
THE FUSE IS LOCATED UNDER THE HOUSING OF THE OVEN THERE SHOULD BE 4-6 SCREWS HOLDING THE TOP, LEFT AND RIGHT SIDES ON THE OVENTHEN SHOULD LIFT OFF IN ONE PIECE
BUT IF THE LIGHT IS STILL WORKING I DON'T THINK THE FUSE IS THE PROBLEM
Aug 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a JES 1456 GE Sensor microwave oven purchased at Walmart about 3 years ago. It has worked great up until now and it just quit. It is blacked out and does nothing. It quit without a sound while in...
Sounds like you have a thermal reset opening up on the unit and disabling it till it cools down. Make sure all air intakes are clear of debris, papers from the counter , etc. also make sure no dust covering air intake holes. Do you hear a fan running when the unit starts?? If not, bad fan, burnt wires. bad main board. Like a lot of my other posts, maybe a bad fuse and fuse holder. Check for brown flux coming out of shiney metal end of fuse, where it meats the ceramic body. Replace fuse and fuse holder. Sometimes fuses do just get tired and barely open, not actually blow, then just expansion and contraction of the element inside will make the unit work and then quickly shut off. Cheapest way is just sub the fuse and give it a try. Cost you a dollar or two, if that works replace the fuse holder too.
Aug 18, 2017 | GE JES1456 Microwave Oven
No heat, does not cook
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave went dead when I opened the door ( same problem as closed the door ).
A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q - My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
May 14, 2008 | Hotpoint RVM1635 Microwave Oven
Sharp R-1491 Microwave Oven Logo
178 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
