Question about Acer Aspire 3680-2682 Notebook
Wont turn on
My computer wont turn on and before this happned it would not hold a charge. Finally it just quit and smelled like it was burning.
Should i order new battery or it is something else.
thanks
Problem with your charger or pin connector
Posted on May 30, 2010
My 2001 grand marquis heater turns on but wont blow i smelled a strange smell before it quit
Could have been the resistor or the blower motor. It was probably a burning wire smell.
Check the blower motor for power and ground.
Jan 22, 2014 | 2001 Mercury Grand Marquis
Hyosung ms3 250 battery fully charged engine turns over wont fire up also new spark plug fitted
has spark? has fuel going to carb? if you smell gas from the muffler or carb then it not burning check for spark pull plug touch away from the hole so you don't ignite the vapors on the engine look for a great blue red spark
Feb 24, 2013 | 2009 Hyosung MS3 250
Maytag washer MAV6650aww burning smell
OK, this model has a known issue with a bad pump design. The bearing on the pump goes bad and will lock up. The burning smell is the belt trying to turn the pump. Look under the unit and see if you see rubber residue at the pump. Here is the pump to order. To replace the pump, tilt the unit back and remove the belt. Remove the back lower left side access panel. Remove the 2 hoses, then the 3 bolts that hold the pump down. Replace in reverse order. The pump is a new design it looks completely different but will last you the life of the unit.
Dec 09, 2012 | Washing Machines
Macbook wont turn on, burning smell
Hi, I have the same problem. Now is in the Apple Store for revision. I'll let you know when they give me an answer.
Jun 02, 2012 | Apple MacBook Air
New battery wont charge
I had the same problem. First, I ordered a non-Dell battery online but battery would not hold charge either - had to send battery back twice but new battery wouldn't work either time. Finally, I resigned myself to ordering one from Dell directly and it's working fine now - so my advice is to bite the bullet and pay more for Dell battery.
Apr 15, 2009 | Dell Inspiron 1300 Notebook
Toshiba wont charge
Sound like you may have the wrong power cord for your unit. The original power adaptor for the A105 is 75W (15V x5A) Auto sensing 100-240V/50-60MHz frequency input. If you got a replacement adaptor, I would reccomend a 75W or higher adaptor. (A new opposed to a used one.) Good Luck.
Feb 02, 2009 | Toshiba Satellite A105 Notebook
7.3 diesel turbor wont start
It needs to spin over at correct speed so if it is dragging causing slow turn over then yes it can cause
Oct 17, 2008 | 1996 Ford F350 Crew Cab
Casio exilim ex-Z750 camera wont turn on
Have you made sure the battery is still good? Even if the battery looks like it's charged (via the charging cradle) it may not be holding the charge.
So first, test the battery. How? Easiest way is to go to a camera store.
Before that, try removing the battery from the camera. Then reinsert it. This will reboot the camera, just in case that is the problem.
Finally, assuming the camera has not been dropped and that it is a mechanical or damage problem, download the latest firmware update.
Jul 21, 2008 | Cameras
Wont charge
make sure the hold/lock is not engaged
then:Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jul 06, 2008 | Philips GoGear Flash MP3 Player
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Acer Aspire 3680-2682 Notebook Logo
93 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
