Question about Zanussi 24 in. ZD686 Built-in Dishwasher
Rotors not turning during operation
The top and bottom blades are able to move freely are not blocked by dirt, but will not turn during operation, causing unwashed articles in certain areas. Solutions please!
  • 159 Answers
Confusing..You say in one line Rotors not turning during operation. next line says
The top & bottom blades are able to move freely?
Il try & help anyway.1st the water level may not be high enough to load the the wash motor & spray water.2nd the dishes or cutlery may be hitting the arms.
Posted on May 30, 2010
Top rack not getting clean on Normal Cycle
Empty the dishwasher. Look at the 2 rotating plastic arms in it (like 2 bladed windmills) spin each one, do they move freely without hitting anything? If so remove the top one (its a press on fit) the look inside it with a torch, is there any debris or dirt inside it blocking it? Water has to flow inside it or it will not spin, and top rack gets no water spray.
Dec 20, 2013 | Dishwashers
Dose anyone have a owners manual for a true refidgerator GDM-12
The fan your referring to is the condensor fan. it should not be tight to turn. it should spin freely. if it is hard to turn, its probably stuck, which is why its not spinning. Remove grill, slide the nottom portiom out so you have access to fan, remove fan blade, and spraylubricant on fan motor (around the area that the screw that held blade). Remove hair, dirt, string, or anything else that might be prevrnting fan from spinning. sometimes its easier to burn it off. If fan still doesnt spin you may have to replace fan motor.r
Sep 26, 2012 | True GDM-12 Refrigerator Commercial
Dishes on top drawer not washing fully,appears hi pressure going to bottom rotar and not top. is there a somthing that sends pressure to different cleaning heads during wash cycle
There is a connector under the top draw from the rotor top the pressure at the back of the inside. This connect at the bottom where the main pump directs the water upward and into the bottom of the rotor. Also, check that rotor is freely moving and nothing is blocking it.
Aug 15, 2011 | Bosch Dishwashers
My craftsman 18.0 42" lawn
First check to make sure you can turn each blade by hand, with the mower off. If neither blade spindle is frozen remove the deck and make sure all the pulleys move freely and function like they should. The cable should have been operating a spring loaded pulley arm that applied tension to the deck belt to make the blades function. Some times build up with block that from moving or rust will make it stick.
May 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Acer 5610 is getting hot and keeps shutting off.
The fan may have gone bad. Turn the laptop on and put your hand on the bottom where the fan vent is. If you can't hear the fan turning or feel air coming out, the fan is probably bad and will need to be replaced. (Hopefully it hasn't caused any hardware damage and once you replace the fan it should work fine.)
If you can hear the fan spinning but can't feel any air coming out, the duct might be blocked or clogged with dirt. Turn the computer off and blow some compressed air into the fan from about a 45 degree angle. If you feel comfortable opening the computer up, remove the screws from the bottom of the case and take the bottom off so you can get to the fan. Clean the fan blades with a dry lint-free cloth, or with a damp cloth and then dry the blades. Put the computer back together and hopefully the fan should spin freely now and blow air out the vent.
Jul 04, 2010 | Acer Aspire 6530-5143 Notebook PC
The blades will not disengage
Usually when this happens, there is grass/dirt buildup on top of the mower deck and the pivot point for the tensioner pulley gets rusted to the point that it won't rotate easily. Clean it off and lubricate the pivot point and get it moving freely. Also, sometimes the blade brake arms get stuck. There are rollers on each blade brake arm towards the center of the deck. They are hard to see just by looking under there. I suggest pulling the deck and get it out where you can see it well. The rollers get rusted up and won't turn and follow the cam on the pivot bracket.
Apr 05, 2009 | Garden
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Can not get the DAMN replacement belt on
Take the bottom plate off, the top needs to come off also, if you don't see any screws, then on each side edge, from the bottom, use a flat blade screw driver, pry up on each spot and the top will come off. Put the belt over the brush roll, put the bottom plate back on, turn it back over and stretch the belt to go around the motor shaft, turn it by hand to make sure it moves freely, then put the top cover and knob back on. Just push down hard until it snaps into place.
Jun 14, 2008 | Hoover Vacuums
Top blade not turning
does it turn freely??
like if you give it a swind does it take about 6 revolutions then slows and stops?
if it does unscrew it (silver screw) and check the holes and washers and screws etc... as they can break perish.. if you dont know what to look for here i a tip!!
go snooping at any respectable white goods store, find the same model that you have and pretend to examin it lol! look at its top arm and see if it mooves as freely as yours!!!!!!
and for same parts etc.. anyhow the point is that if it moves freely then when the pump goes on the water should force it to spin smoothly!
however. get your self some dishwasher cleaner!
for the dishwasher! not the dishes! it is like a drain-o for dishes! it unclogs and un clags the pipes etc...
good luck!
Oct 13, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Zanussi 24 in. ZD686 Built-in Dishwasher Logo
143 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
