Question about Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor
Flooding engine runs for short period then chugs and blows out black smoke then repeats cycle. same with air filter on or off unit.
  • 66 Answers
The timing may be off a little. I would first look at the fuel system to rule that out. Is the choke all the way in? If so...have you tried a carb kit and checked the float? If the needle is stuck...fuel will keep pouring in. www.nnyparts.com
Posted on May 31, 2010
Why does it blow a lot of black smoke out tail pipes when floored to pass a car?
Yes. Could also be a dirty air filter. Try the cheap and easy first. look for something restricting air flow first. Did a plastic bag get sucked up around the air intake going to the filter? etc. Hope that helps
Feb 27, 2016 | Cars & Trucks
Why is my craftsman running rough?
Black smoke means it is running rich. Too much fuel or not enough air. I doubt that it is an air issue. Check the float and carb.
Aug 16, 2014 | Craftsman Garden
Nissan starting problems
You have a vacuum leak therefore your car is running rich
Jul 21, 2014 | 1993 Nissan Sentra 4 Door
Act like it is flooding out at high rpm
try cleaning the air filter as it is probably blocked
Jul 13, 2014 | Briggs AND Stratton Intek Briggs &...
Honda pressure washer GCV160 5.5 HP started smoking while engine was running.
White smoke or black? White means the carburetor is flooding. Black smoke could mean a clogged air filter.
Sep 16, 2013 | Garden
My truck will only start if I hold the gas to the floor, like its flooded, and it chugs, and blows black smoke out exhaust
first ,l want to know whether is caburettor type or injection,if carb check your carb float, injection you should get a car scanner read for fault code maybe air mass sensor, coolant temperature sensor or 02 sensor
Apr 05, 2011 | 1994 GMC Sierra
My 2004 ram 1500 4x4 has the 5.7 HEMI engine and runs great out on the highway but when i first start it up and take off it blows black smoke and seems like its trying to flood out and uses way too much...
Check the following:- Map sensor, Air flow sensor if fitted instead of map sensor and the engine coolant temp. sensor. When did you last replace the air filter?
Oct 02, 2010 | 2004 Dodge Ram 2500
I have a Craftsman Yard Man 6.5hp push mower with a Briggs & Stratton engine. The engine starts and runs fine for about 30 seconds or so then slowly dies out. It turns over slower and slower until it...
Have you checked the choke that it is off after you get the engine started,the black smoke is definitely from the choke, if you take the carb off and check that the needle closes when it should,as one can easily do an adjustment by bending the float/tab,rgds
Sep 25, 2010 | Briggs & Stratton Garden
Engine is cutting out below 5000rpm and missfiring
hi mate change the airfilter black smoke is a sign of a dirty air filter
Mar 28, 2009 | 2005 Yamaha YZF-R1
2004 sprinter Black smoke
assume diesel engine ? so if water was in fuel ? the engine would not run even b4 it got to engine because fuel filter would rstrict diesel due to water on filter element ? can i just say that from your symptoms ? black smoke/engine runs but poor ? the fact it is black smoke? is most due to lack of air flow to manifold remove air filter element and see if smoke clears? if element of filter has got wet ie floods? it will not allow air through? make sure there is no other restriction/s on filter inlet and outlet pipe to manifold espcially check now for any weakness on pipe to engine from filter ie when you rev up look to see if hose is sucking together due to vacuum created by revs of engine? if injectors were defect ? the smoke would be blue due to over fuel injection ie injectors not atomizing correctly ? i would suspect problem is lack of air? out of curiosity?? how did water enter fuel tank ?? if any more info you can provide it may give better idea of problem ?
Nov 04, 2008 | 2004 Dodge Sprinter
Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor Logo
140 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
