Question about Lexmark Office Equipment & Supplies
I have a model X7170. It has been a fine machine but all of a sudden this past week the page is blue. My customers cannot read what I am sending them. I have so much work to do this week-end & cannot do it. Can you help? Thank you, Janet
  • 493 Answers
Hi Janet,
As I understand you mention about the scanner. (It scans in blue)
Please check the scan mode in the setup while scanning. Try setting it different dpi mode.
Did you install any new driver or update your operating system? If so you shoul update your printer/scanner driver to be compatible to your operating system. What is your operating system?
You can try to download its latest drivers from this link.
Posted on May 30, 2010
My car wont go past 35 sometimes and bumps when it gets there
Only thing I can is do you have a check engine light. If you do what is the code. Many auto parts stores will read your code for free.
What you said picks up slowly and tops out at 35 mph. My Chrysler 200 took 2 block to get to 2000 rpm 30 mph. That was all it would do. I had a code and changed the throttle body sending unit. The throttle body and sending unit are 1 piece unit on my car. some cars you can change just the sending unit. It improved 75 percent and when we changed gas station 3 weeks later the problem went away. With the limited info you gave that is all I got. Hope it helps.
Aug 07, 2017 | 2001 Dodge Intrepid
My grandkids have a Playstation 2 slimline console. Suddenly it quit playing games and on sytem configuration it says " Disc could not be read ".I changed the 2 memory cards around , and even unloaded both...
hi,
i Had the same problem with reading blue disks as well as the system will no longer read DVD's or DVD based games. Cleaned the heads with a DVD/CD cleaner and it worked for a couple of months and stopped again this past weekend. Found several threads on other sites indicating that if you contact Sony customer support and verify that: (1) you ran thru diagnostic mode (Page 9 in manual), you CD/DVD's work in another machine and aren't damaged, they'll fix it for free.
Contacted Sony yesterday, shipped the system to them in PA, and they are "waiving" the repair charges. There explaination is that since they aren't sure what's causing the problem with my system, they won't charge me for the repair. Shipping charges where $18.00 for UPS ground. It will probably take approx. 3 - 4 weeks to get the system back, but that's a huge savings over buying a new one or trading it in at EB Games for a new / refurbished one. They also will reinstate the 90 day warranty as well.
thank you,
vijay (vote for me)
Sep 24, 2009 | Sony PlayStation 2 Slimline Console
Printer does not print. It has worked fine for about 15 months. I can send a document to be printed, the printer goes through the motions, makes all the "correct" sounds, but ejects a totally blank page....
it seems that the cartridge is empty but if ot check as below
u need to turn off ur printer & pull out the cartridge and clean the pinout of the printer cartridge mount then also clean the pinout of the cartridge with acitone then try it if it's not work u need to pull again the cartridge and apply the output ink place to a hot steam then install it back again.
hope it works
Jun 29, 2009 | HP Officejet J5780 All-In-One InkJet...
Blue Lights Flashing on Lexmark X7170 All in One
there is a little string in my printer and it fell off it looks like it holds the ink and its hooked to it where dose it go i am so in truble i cant figure it out........... STACY SMITH
Feb 03, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Charging does not happen
I took mine back to Best Buy...I think it was a faulty bluetooth...the new one has worked for the past week...good luck!
Sep 19, 2008 | Plantronics Explorer 220 Bluetooth Headset...
LEXMARK X7170
Hi - You can view the manual from the link underlined in blue below:
Lexmark X7170
Changing information that appears on your fax cover page
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  2. Click View Cover Pages.
  3. Click Change your personal information that appears on this page.
  4. Make any changes.
  5. Click OK.
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 21, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printer reads RIGHT CARTRIDGE INCORRECT
If you have purchased the cartridges directly from dell , it will be covered under warranty for 2 years for hardware errors and you can call dell on 1800 624 9896 and get the cartridge replaced , even after the replacement of the cartridges if you have the similar issue then its an issue with the printer and needs to be replaced.
Jun 24, 2008 | Dell 922 All-In-One InkJet Printer
My fax machine
We are having the same problem. I can hear it dial, but when the receiver fax picks up, there is no signal from the Lexmark to let the receiver know that we are sending. All we need is one stupid "BEEP"! So much for plug-and-play.
Mar 31, 2008 | Lexmark X7170 All-In-One InkJet Printer
Fax confirmations
i have read the manual end to end and I don't think you can.
Only thing I see is this.
Customizing your settings using the Lexmark Fax Solutions You can adjust the fax settings in the Lexmark Fax Solutions. These settings apply to the faxes you send or receive.
  3. Click each tab and change the settings as desired.
  4. Press Save Settings after you finish your updates. Nothing is saved until you press this button.
  5. Click Close.
The following table contains the Setup and Settings tabs for the Lexmark Fax Solutions.
On this tab
You can
Personalize
  • Enter your company name and fax number.
  • Enter your name, company name, phone number and address as you want them to appear your cover page.
  • Select a cover page for your fax.
Send
  • Choose to use error correction.
  • Choose to use fax header.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report
Select when to print an activity report is the only close item I can find. Nothing whatsoever about a confirmation report.
Feb 25, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
