Question about Dryers
My mother has a Maytag electric dryer that she purchased in 1980 - the dryer will air dry clothes but will not heat. What could be the problem?
  • 10,319 Answers
That dryer is old so more than likely the vents tubes to exhaust will need to be cleaned out. If cleaned the switch relay can be the problem as will. Since this unit is 30 years old a new replacement dryer would be on my list to buy
Posted on May 30, 2010
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
Our dryer stopped heating up and will not dry clothes
tif it is most likley the element has gone bad they usually cost about 45 dollars and if you can find a friend to help you replace it its not that hard best bet is to call a used appliance store they usually have them new and in stock do not try going to the manufacture they will charge you double for the same exact part
Apr 12, 2010 | Maytag SDE3606A Electric Dryer
Not drying
Many times your lint filter is plugged or the exhaust is plugged
Try cleaning both and see if it helps
Apr 01, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Brand new Maytag Centennial electric dryer does not dry clothes!
It may have shipping damage, such as a loose or broken connection or heating element.
But if it's brand new, it's under warranty, and they will fix it free.
You can find your nearest Maytag-authorized servicer here.
Jan 09, 2010 | Maytag Appliances Over-the-Range Microwave...
The dryer doesnt get hot enough to dry clothes
Pull the dryer out and remove the lint hose . Turn on the dryer and feel if there is good air flow and if you feel heat . If there is good air flow and heat , dry a load of clothes , to see if they dry normally .
If there is not good air flow , then the blower wheel is probably stripped and needs to be replaced . If there is good air flow and heat , then the problem is in the vent ducting , between the dryer and to where it vents to the outside . Dryer could be pushed back too far , causing the hose to " kink " , restricting the air flow to the outside .
Remember , a dryer either heats or doesn't heat . If no heat , then a dryer problem exists . If heat , but dryer does not dry , then a vent problem is the cause ( except for maytag , which the blower wheel sometimes strips out ) .
Nov 08, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer model # SDE3606AWY HEATS UP TUMBLE clothes but does
There is most likely a lint obstruction somewhere in the exhaust. Start by checking the outside vent as often there is an animal screen on it that over time gets caked with stray lint. If that's clear then work backward and check the hose, etc until you either find something or get to the dryer itself. It's possible that in the internal exhaust tubes there's an obstruction as well so if you don't find anything in the external tube you will need to disassemble and have a look inside those internal exuast tubes/ports. If it's inside then do it soon as there's clearly a risk of fire if there's a wad of lint somewhere inside where it shouldn't be.
The mother of a friend at work had this issue - her clothes took HOURS to dry. Her animal screen had several inches thick layer of lint. Once that was removed the dryer dried like new.
Mar 29, 2009 | Maytag SDE3606A Electric Dryer
The dryer will not heat up to dry clothes
youve probably got a bad heating element, also make sure air is blowing out back of dryer to the outside of house if its plugged it will cause element to break good luck
Mar 23, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
Top Dryers Experts
