Question about Gaggia Coffe Deluxe Coffee Maker, Espresso Machine
Water leak causes the main power to trip. can you
Gaggia coffee maker: water leak causes the main power to trip. can you fix it?
    President:
  • 1,618 Answers
Yes it can be repaired, I would suggest getting a rebuild O-ring kit for your machine, it comes with all the gaskets and O-rings that you will need for the machine.
Posted on May 30, 2010
Gaggia titanium coffee machine trips the electric when turned on
The heating element is shorted out. Contact the manufacturer for a replacement part (if available)
Jun 29, 2016 | Gaggia Titanium Espresso Machine
The machine will brew one coffee and on the next attempt, will trip the GFI.
HI
You probably have an internal leak that is hitting a power wire and tripping the GFI. It needs to be fixed before it shorts something and burns up the board.
Nov 13, 2010 | Gaggia Syncrony Compact Digital Espresso...
My Gaggia Synchrony is leaking - If I remove the water catch basis, I can see a drip. We have used this machine every day for years - can the problem be fixed easily?
HI
There is a panel behind the brew unit, that has 2 screws. Remove it and clean the coffee residue behind it. That is what drains the pressure relieved after brewing, and has coffee residue that can build up and cause the leak. It should leak into the drip tray though, except when you rremove it.
Oct 23, 2010 | Gaggia Syncrony Compact Coffee...
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
The coffee machine trips the electricity when I use it.
Take it to a service agent,it sounds like the boiler is leaking.
Do not use it is unsafe
Mar 28, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Baby - water leaking from round the edge of main bulkhead
you need to replace the main rubber gasket within the bulkhead. due to heat and use, the gasket cracks and no longer is able to seal the brew head. a new gasket should be part of the warranty but you can purchase one and replace your self, pretty simple.
Mar 05, 2009 | Gaggia Baby Espresso Machine
Leaking water
It sounds like the main valve is faulty. Replacements are available or you may be able to dissasemble it and replace the seal.
Hope this helps.
Sep 04, 2008 | Gaggia Baby Espresso Machine
Gaggia syncrony compact coffee machine
It is very hard to say where the leak is coming from. If you can open the case of the machine a physically notice where the water is leaking from then we can tell you if you can repair it yourself or if you will have to find a service center.
Authorized Gaggia Repair Center
Cerini Coffee Services
New York, USA
www.cerinicoffee.com
Jul 22, 2008 | Gaggia Baby Espresso Machine
Bunn coffee maker trips the breaker
It is possible that you have a short in your limit thermostat, but most likely this is caused by small holes in your main heating element. these units start to split length ways down the element, causing a short to ground through the water. These elements are readily available at your local Bunn repair shop.
Oct 27, 2007 | Bunn RL Coffee Maker
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Logo
187 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
