Question about Refrigerators
Compressor clicks but wont run - Refrigerators
    President:
  • 2,468 Answers
Replace the ptc overload on the side of the compressor as this is the relay clicking and not starting the unit properly,they simply unplug off the compressor body
Posted on May 30, 2010
Fridge wont turn on
After ensuring power is going to unit, I would be looking at either compressor or thermostat or control board. If compressor is not running at all, not even clicking, then board or thermostat is most likely the problem. If compressor is running or trying to run, then starting device for compressor or compressor itself is bad.
Sep 05, 2017 | Refrigerators
Replaced capacitor and start relay. now the compressor clicks but wont start. is the compressor bad. replaced thermostat and heater also
you can measure from pin to pin on the compressor connection with an ohm meter, the two small numbers should equal the large number if not bad compressor start to run = start to common=and run to common=
Nov 05, 2015 | Maytag Refrigerators
Freeze keeps clicking over but wont freeze was in storage frooze for 1 day wont freeze has it run out of gas or would the timer need placing what would be the problem worth reparing
If you are hearing the clicking sound down by the compressor you could have issue with the compressor. Really need more info.
Oct 30, 2014 | Freezers
Maytag refrigerator Model mff2557heb wont cool
The compressor in your refig is bad. whats happening is when you let the compressor cool down it will run for a while then it starts binding internally until it gets to the point of humming and clicking. only repair is replacing the compressor. sorry for the bad news...
Sep 30, 2012 | Maytag MFF2557HE Bottom Freezer French...
Refrigerator making a clicking noise about every 5 minutes as if stuck in defrost mode, It is making noise as if it is running. It wont keep food cold. outside of frig feels warm. about 6 wks ago i...
If the fans are running and then the compressor is trying to start but clicking out on the overload . If the compressor is hot but not running try a new relay pack if it still does it then the compressor may be bad.
Oct 29, 2010 | LG LFX25960ST Stainless Steel French Door...
NOT GETTING COLD
the first thing to check is the thermostat if its stoped working them it wont be telling the compressor to start up and the unit wont get cold,,
have this looked at first as its the cheapest part to renew
May 22, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Wont run while under load
ok buddy i know the problem before the pipe connects to the tank it goes to a valve unscrew this and check the rubber inside turning it around if necessery get back to me51a35be.jpg
Sep 19, 2009 | Coleman Powermate 11 Gallon Air Compressor
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Compressor wont kick on wont catch on
IT IS SIMPLE CONNECT A HEAVY GUAGE JUMPER WIRE FROM A/C COMPRESSOR TO POS BAT TERMINAL WITH A/C MAIN WIRE WITH ENGINE RUNNING AND A/C ON MAX AND SEE IF COMPRESSOR CLICKS ON AND ALWAYS DISCONNECT IT AFTERWARDS
Sep 18, 2008 | Amana Refrigerators
Maytag refrigerator clicking
it sounds like a bad:
  • ·       start switch (on the side of the compressor) or
  • ·        compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Jul 06, 2008 | Maytag 23 cu. ft. Side-by-Side...
Refrigerators Logo
151 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
