Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
Dish washer turns on by it self .
It turns on by it self . then i hit the buttons it turnes off . Then it comes back on . The light on the button is red at this point
  • 523 Answers
Is there a chordless phone near by?
if so remove it
Posted on May 30, 2010
Emersin tv
which Dish Network system do u have. If it is the Hopper they program a little easier that the others. but if you have anything other than the hopper u do this. #1 turn onTV,#1 take Dish Remote,#3 press and hold down the TV button on top of the remote, hold it till all four lights light up.#4 press the small red TV button,# now press and click the channel Up or Down , do this one click at a time , (do not just press and hold ) this may take 200 clicks so don't give up. #5 when the TV goes off u quickly press the #(pound button) located on the bottom right of the remote. the TV button on top should flash 3 times. Now try to turn the TV back on.Ok now if you are clicking the channel button too fast and the TV turns off and u pass it up no sweat,,just hit the # button anyway.. and start from the beginning again, but this time use the OTHER channel button the TV should turn off within a couple of clicks. (that saves you from having to hit the button another 100 tries.. ha good luck
Sep 29, 2014 | Televison & Video
Kenmore dish washer lock button blinks and doesn't run
Hi
Thanks for using FixYa. To unlock the controls Press and hold Air Dry/No Heat Dry for 5 seconds or until the light turns off. Please revert back for more help.
Rylee
Dec 23, 2011 | Dishwashers
While my wife was washing, the water was turned off to the washer. She hit the pause/cancel button. Now that the water is turned back on, when we hit the start button, all the lights turn off.
Hello,Select any button except start and hold it 4 seconds let go 4sec hold 4sec let go 4sec hold 4sec see if unit goes in service mode all lights will come on hit same button again unit will go into aut test and run a cycle when its done unplug for 5 minutes plug back in and see if unit works.
Jun 18, 2011 | Maytag EPIC MFW9700S Front Load Washer
Door will not open after self cleaning cycle
I tried a suggestion found on this site.
Turn off the light button and hit cancel. Cancel did not work for me.
Turn off the light button and hit clock. Worked for me. Technology?
Apr 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My Dish Network Remote will not allow me to...
go to page 19 of your manual (for the E-Z remote) or here "http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/remotes/EZ_Remote_Manual.pdf"
(if you don't have the manual)
or to here "http://www.dishnetwork.com/support/documents/receivers/default.aspx" if you have a different remote.
basically, turn your TV on, then you press the antenna button for about 5 seconds until the TV button lights, then use the channel up/down buttons to find the code (the TV will turn off when you find it) hit the TV button again to turn it back on, then hit mute to set the code! good luck!
Feb 17, 2009 | DISH Network IR Remote Control
Dishes come ot just like I put them in
Check that both spray bars are turning. They can both be easily removed.
Once removed, make sure they are not clogged with stuff to prevent them from turning.
I assume you can hear water spraying around inside when it's washing, and that the dishes do get wet, and water does get hot.
Soap dispenser requires water hitting on it to open.
Jan 28, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Washer power
Sounds like you have a stuck or shorted keypad. I've seen this a lot on this model. Solution is to replace the keypad. Catriver.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
TV input
it is likely that your tv is interpreting a random button on your remote as a signal sent for it to change inputs, next time this happens turn the tv off and back on and note what comes up on the screen, for example video 1,
Aug 04, 2008 | DISH Network IR Remote Control
LF Error Code
How is the water filling? Slower than it should?LF (long fill) Start by removing the hot & cold hoses off the back of washer ,now look inside the valve for clogged screens,if they are clogged ,clean them.If problem continues replace the water valve.
May 26, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Turning on dishwasher
although the light may be a true indication of a pending problem, try this test: Find the circuit breaker and switch it off to remove power to washer for 30 minutes. Then power back up. Any changes? If light still on, then threat of trouble is real and must be fixed. Not sure what to CLEAN, though. Search for manual online...I'm sure Kenmore put that light on for a real purpose.
Jun 14, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
169 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
