No sound cuming out of amp fuses all ok - Audio Players & Recorders
    Problem Solver:
  • 14 Answers
Sounds like the output amp module is kaput, the output fuses can still be intact and the transistors or power amp chip can be faulty, there can also be fuseable resistors that can blow before anything else if its a fairly modern unit,,what type of amp is it and how did the problem occur
Posted on May 31, 2010
2004 escalade speakers work but not left side balance on deck is ok all chiming sounds are from left side Are there fuses on central amp Fuses in hood ok Fuses in dash ok
If your wires are hooked up correctly then it is possible you have blown a channel in your amp or head unit , the amp does have its own fuse but most do not have a fuse for each channel it either works or doesn't . Only other possibility is somehow the amp has been switched to mono .or "bridged" these settings are used when the amp powers only one channel or a subwoofer
Oct 13, 2015 | Cars & Trucks
Fog lights on my 2003 mazda 6 not working. fuse & relay are both ok, but no power going to the bulb. is there another fuse other than in the drivers compartment panel?
probably corrosion on the ground wire to the bulbs or the wire to the bulb did he check from chassis to connector or just take the bulb out sounds like you need to find a real mechanic
Mar 02, 2013 | Mazda 626 Cars & Trucks
Washer cuming up e03
OK, e03 is a draining fault.
If the machine is actually draining ok and quickly it would suggest a restriction in the pressure chamber or a faulty pressure switch.
Unplug the appliance.
Take the rear panel off.
Take the large plastic tube out of the sump hose (pressure chamber).
Clean it out and clean the hose out.
Reassemble and try the machine again.
Oct 28, 2012 | Washing Machines
Canon ClC 3200 , ERROR CODE E-000602-FF13 , HOW CAN I FIX IT ?
program u r hdd or go to service moode press copier , function . system and press hdd check select this one & press ok it is starting from 100% & it will be cuming to be 0% or ok.
May 04, 2011 | Canon CLC 1120 Color Copier
Dead receiver/amp.No sound no dial lights. Voltage ok at wall outlet, present at back of amp, but not at auxiliary built-in AC outlet on case of amp. All 4 fuses OK. On/Off switch seem OK. What is the...
the power transformer may have blown the primary winding causing no power for the secondary windings witch means that the main power board has no power
Mar 06, 2011 | Onkyo TX-SR501 Receiver
No picture sound ok,osd ok.
LG 42pj350r this led tv sound ok but not cume picture
May 25, 2010 | Panasonic VIERA TH-42PX80B 42 in. Plasma...
I just bought a 98 concorde lxi and no sound coming out of the speakers, radio comes on and shows channels just no sounds
Hello georgouseyes,
The problem could be in the output from your receiver to the amp or in the amp itself.
First check to see if the amp powers up. If it doesn't, check the main power fuse (usually located under the hood near the battery). Also check the power and ground connections on both ends.
If the main fuse checks OK, check both onboard fuses. There's 2 35A fuses on the far right.
If the amp powers up OK and the onboard fuses are not defective, it's possibly the output from your receiver or line output converter. Replace the RCA cables with a known good pair. If there's still no sound, I'd suspect that the amp itself is defective.
Hope this helps.
Oct 17, 2009 | Infinity 475A Car Audio Amplifier
Red light on fusion amp?
This is a rather common problem. The red light indicates it is not correctly getting power.
So trace your power wire from the battery--> check the fuse on the wire if there is one---> to your amp. If that is all in working order next move onto the ground wire.
Make sure it is sparking on the surface that you have it grounded at. If it does not spark when you touch the ground wire against that surface then you are not correctly grounded. It should be bare metal, something connected to the cars frame.
Try this and post back if you still need additional help. Thank you for choosing Fixya!
Oct 01, 2009 | Fusion Digital designs EN-AM6004 Car Amp
I have brought some speekers i do not have any sound cuming from them
Power on the speakers, rotate the volume knob (if present) to full. Then take the input wire (Which connects to the PC's green audio socket) touch at the end of the jack. Surely some voice will come from the speakers. If some buzz noise comes out from the speaker, the speakers are ok. reply for the other possibilities.
May 08, 2008 | Computers & Internet
41 people viewed this question
 Grubhead
Grubhead
