Question about iLO 2600 Television
Black and White Screen
This morning when I turned on my television it was black and white, now I go threw my VCR to get surround sound, could it be that my VCR is shot? Please hlep me the TV isn't a year old. It was a gift, so I don't have the receipt for it.
Thank you,
Cheryl
  • 1 more comment
  • Chay01 Apr 08, 2008
    It is a ilo 26" Digaonal LCD HDTV and I have satellite reception. My other TV's are working fine with the satellite.
    I have an ilo 26" diagonal LCD HDTV and use satellite. All my other TV's working fine, could the VCR be the problem where I go threw it.
  • Jeffrey Johnston
    Jeffrey Johnston May 11, 2010
    What kind of television are you using and is it on antenna or cable or satellite reception?
  • 124 Answers
First, check the co-axial cable that enters the satellite receiver. It may be loose or have an inferior connector. Look closely at the cable end...look for a very small strand of the braided shielding material that may be touching (or very close to) the center copper needle. If that is the case either replace the fitting or use something (small pocket knife blade) to move it away or get it out of the connection.
If that doesn't do it, connect satellite receiver directly to the TV bypassing the VCR. That will tell you if it is a VCR problem.
Posted on Apr 08, 2008
My little 15
If the format of color system such as PAL/SECAM etc. is not same as that of telecast, you will get picture in black and white.
Aug 04, 2012 | Coby TFTV1503 15 in. LCD Television
Color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
Jul 23, 2010 | RCA F19431 19" TV
Only get black & white, double images
bad power circuit may cause such problems.
may be power ic or bad capacitors.....
Aug 18, 2017 | Philips 50PFP5332D 50 in. Plasma...
Dvd's are playing black & white via sound surround system
Check first your dvd player settings if it is in PAL or NTSC.
Mar 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
DVD hookup to LCD monitor only appears in black and white!
I have a RCA flat screen television and my dvd player when hooked up is in black and white. How would i fix this and if so plz be more specific then these other people.
Jan 02, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
52 inch RCA big screen
check all connections and different sources(dvd, vcr, antenna) to make sure that it is the tv. otherwise i would say call a technician because you could be in for some extensive troubleshooting
Jan 25, 2008 | RCA P52960 52" Rear Projection Television
DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Dec 18, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Playing movies in black and white
Use a scart lead to connect it to the TV, that should cure it.
Dec 08, 2007 | Sony DVP-NS315 DVD Player
62' Mitsubishi WD-62525 little black and white squares instead of picture but I have sound
Mitsubishi list this problem and has a solution of replacing several small surface mounted caps and diodes. we have tried this repair 5 times and only successfully done it once. so replacing what is called the formatter board part # 930B924002 for around $ 350.00 usually repairs this type of failure, However changing this board is a time consuming thing and takes a lot of Patience. It is buried deep in the set and several other board have to be removed just to get to it
Oct 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
TV picture
The set you have has a bad tuner assembly. At this point most likely you would be better off getting a new TV set. Good Luck
Mar 30, 2007 | Mitsubishi CS-27309 27" TV
Televison & Video Logo
42 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
