Question about DeLonghi Coffee Makers & Espresso Machines
Water pump for the DeLongi EAM3400
My water is not pumped through the machine. After diagnose I found the water pump does not pump any more. Where can I buy a pump spare for the DeLongi EAM3400 coffee maker? The number on the spare is 974-8501.
SOURCE: PROBLEM WITH LOW FLOW/PRESSURE IN GAGGIA COFFEE DELUX COFFEE MAKER
the most likely reason for poor flow through the brewhead is a blockage in the outlet valve.the outlet valve is behind the shower disc holding plate and can be removed with 13mm socket. a straightened paper clip needs to be insrted in the outlet to clear any internal blockage,then pump water through. if the outlet valve splits in two ensure the rubber bung is inserted upwards.once refitted all should be fine
Posted on Aug 07, 2008
SOURCE: There isn't enough pressure to pump water through the coffee
Chalk in the system, let it run a couple of times with plain vinegar. just fill the machine with about half a liter (one water container) vinegar and collect the vinegar in a cup so you can reuse it. run the full 0.5 liter, wait an hour and repeat. Than run 2 full watercontainers plain water. should work again. Cheaper than antichalk fluid and works the same
Posted on Jun 23, 2010
espressonist
  • 1711 Answers
SOURCE: The coffee maker refuses to pump water to make the
Here is a sugestion tip that will help
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Good luck thanks for voding
Posted on Aug 10, 2010
  • 40 Answers
SOURCE: my keurig coffee maker will not draw water into
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
  • 248 Answers
SOURCE: keurig coffee maker only drips water real slow, I
try web search-keurig b50 repair manual
Posted on Oct 15, 2010
Ec702 delongi is not pumping for espressor but steamer works
first perform a chemical cleaning, place the chemical in the water tank and then this hot place to make coffee, so that the chemical clean pump and piping hot water, repeat this until you spend all the water,
if not repaired you may have problem with the water pump, solenoid or inlay is great need to remove the tubes and clean them out
ramon
nomarpartsupply.com
Sep 01, 2014 | DeLonghi EC701 Espresso Machine
Will not water
hi as you turn the machine on turn the steam knob fully ..this will bleed your system ... if it dont bleed through replace your pump or check filter inline right side of machine ... [turn machine off befor removing main covers } 07779933829
Jan 03, 2014 | DeLonghi EAM3400 Espresso Machine
Delongi eam3400 machine. the water flow is good on the back of the machine but drips into the drip tray instead of flowing through coffee grinds/cup?
http://dl.mypdfmanuals.com/new/external_light.php I found the user manual, look in the troubleshooting section Kolbrub
Sep 17, 2013 | DeLonghi Esclusivo Magnifica ESAM3300...
Delongi magnifica EAM3400.n leaking water and coffee not flowing to cup
Hi i would start cleaning the machine with the cleaning stuff that is recommended. By the way from Electrolux comes a very good cleaningstuff.
Sep 17, 2013 | DeLonghi Magnifica Coffee Makers &...
Hi. I have a Delonghi Magnifica EAM3400 that wont pump steam. When I turn the steam valve you can hear a slight click like a switch has been activated but the pump does not turn on. Does anyone know of a...
poke something up the outlet hole .....pin or something .. or if this dont work u need service and replacement parts .. bsc appliance 07779933829 we carry out repair service via post anywere.
Dec 03, 2010 | DeLonghi EAM3400 Espresso Machine
Water pump failure?
The water pump drain motor has something stuck in it or it has gone bad like most LG parts.
Remove the drain pump and look for any foreign object to be removed.
Check the drain pump for a failed pump motor.
LG is pretty.
Feb 02, 2010 | LG WD-3274RHD Front Load Washer / Dryer
Water ends up in the tray
Have you checked the brew group screen? I am assuming that this is a super automatic machine, and by pressing a button it grinds and brews? If yes then the only other problem would be in the brew unit.
Jul 25, 2009 | DeLonghi EAM3400 Espresso Machine
The washer make a humimng noise and don't complete the draining stage. I remove all clothes from of it, and still have some water
Heool Welcome to Fix ya,
Is your drain pipe at the same level as the top of the machine?
You may have any of these two common problems!
Defective Water Pump
If the motor is running and water is not pumping it could be a defective water pump. Ensure the tub to pump water hose is clear. If so, replace the pump.
Defective Motor
If the motor is not running, the pump will not work. Most washing machine use a reversible motor and it is possible for the machine to agitate and not spin or drain.
They need to be diagnosed to know which to replace. You will need a capable hands on tech there to do this!
Please remember to leave a rating before you sign off!
Dec 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
New unit just won't work - keeps saying to insert brewer unit
These machines seem to respond to what their CS dept call "priming the pump." Turn on machine and after it has warmed up, turn the hot water valve or about 30-45 seconds. Shut it off and after a pause 30 seconds, repeat this process 2 additional times. Do the same 3 cycles in the steam mode. ( hit the steam button for frothing) Check openings  where coffee comes out with a small wire, ect., to make sure they are clear. It should work.
Mar 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
439 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
