I have a Rheem Raypak Pool heater, model P-m266A-EN- C that won't heat. When I turned it on it seemed to be working then about an hour later it had a "service" blinking and a ROL code on the display. When I turn it off a CFH comes on and then the ROL. Any Help?
  • 3422 Answers
SOURCE: unit no longer heats
If ur AC is not coolling properly thn u must go for replacing a fuse, resetting a circuit breaker or checking to see if the thermostat is set properly. If an electrical problem isn't the cause, the refrigerant may be low if the system still runs but does not cool properly. This can be corrected by having an EPA certified technician add necessary refrigerant. Most likely, if the problem involves any major part, such as the compressor, you would hear strange noises similar to those of any mechanical equipment not running correctly, or the unit might not run at all.
Go for replacing both theoutdoor condensing unit (which includes the compressor) and the indoor coil on my central air conditioning system at the same time
Matching a new condensing unit with a new coil is the only reliable way to be certain you are going to get the rated efficiency of the new equipment. Matching a new, high SEER (seasonal energy efficiency ratio) condensing unit with an old indoor coil probably would not result in optimum efficiency.
Goodluck,
Dont forget to rate me as fixya..
Posted on Jan 30, 2008
SOURCE: Laars LX Pool Heater ,blower
I had to replace both hi limit sensors in mine. The sockets that they fit into has a plug inside that corrodes and allows clorine water to escape. I had to put the plugs in with auto gasket sealant around threads only. This solution helps but the sensors should be inspected now and then for corrosion. Lithium grease on electrical conectors on the bottom of sensor helps to. This area is attacked by corrosion big time along with top. (winterizing) On low pressure switch inside the heater the copper tube must be undone on switch or undrained clorine will clog up lower tube with corrosion. This blocks low pressure switch from working. Then you have to cut small piece off and redo the tubing. Been there done that. For the most part the Laars hasnt been a bad pool heater but the hi limit sensors along with the plugs could have been engineered better. Good luck and watch the ph...StLouis
Posted on Aug 28, 2008
  • 659 Answers
SOURCE: Raypak pool heater, error HL2
It is probably the pressure switch. Remove the hose from the inducer and **** in and then blow lightly several times. It is probably stuck in the either the open or closed position. If this isn't the problem, check your manual reset limit switchs to make sure they haven't tripped. Also, make sure your are getting power to the ignighter as well.
Posted on Mar 16, 2009
  • 234 Answers
SOURCE: Raypak gas pool heater with error code HL2
Do you have power to the heater?If you do then I would look for a hi limit switch to reset.It might be the pump you have to reset.
johnsonr1
  • 91 Answers
SOURCE: Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Posted on Aug 22, 2009
Water switch open , heater heats up for short period and cuts out
ensure pump is running at full prime. clean the filter out as well. disconnect both connections from pressure switch in raypack heater. check continuity. if switch opens at any point and you have no flow restrictions then replace the pressure switch
Mar 11, 2014 | Solar Rheem Gas Fired Pool & Spa Heater...
I have a Rheem/Ray pak P-M266a-En-C that reads REM off & am unable to program it despite pushing & holding all 3 buttons on scene as suggested in manuel
see if on remote if not put on remote if ok itsnot seeing controller turn all off then the controller on then the heater then make sure on tstat remote
Apr 13, 2013 | Solar Rheem Gas Fired Pool & Spa Heater...
My Rheem model P-M266A-EN-C is displaying this: GVC. The heater isn't working. What does this mean?
GVC means Gas Valve Closed. This fault can be caused by many different problems, or even a faulty gas valve. Here is a link to a PDF file that give a step by step troubleshooting chart. This may help put you on top of the actual problem. http://shop.solardirect.com/pdf/pool-heaters/gas-pool-heaters/raypak-r-series-oim.pdf
Sep 03, 2011 | Solar Rheem Gas Fired Pool & Spa Heater...
Need to replace gas spa heater. Is there a combination gas and solar spaheater
You may actually use any pool heater with a solar water heating array. I do not however know about any that come as a package deal. You will need a solar array, a solar controller, a actuating valve to hook to the solar controller, and a new bypass assembley for the plumbing system. All of this is made by manufacturers such as : Jandy, Pentair, Raypak, Lasco, Buderus, Hayward, etc....
Feb 16, 2011 | Solar Rheem Gas Fired Pool & Spa Heater...
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
