External modem is not being rcognized by computer. Modem is making a strange noise and then is completely silent.
    Genius:
  • 3,422 Answers
Please change the modem.Is it external or internal??
Posted on Apr 08, 2008
6ya staff
SOURCE:
Modem is not functioning properly
There should be a small pin hole .at the back side of the modem you will require a small pin to put it inside it and reset the modem .If this step does not solve the problem...then replace it
Jul 30, 2014 | Dell Inspiron 531s Desktop Computer
Internet connection error 734 extra initialization command does not work.it leads to another error 692.
692 - Hardware failure in port or attached device.
This behavior can occur if any of the following conditions exists:
  • The modem is turned off or malfunctioning.
  • If you have an external modem, the serial cable is incorrectly wired.
  • If you have an external modem, the serial cable is not securely connected or has open connections.
  • The serial port or multiport adapter on the RAS server or client is malfunctioning.
  • The handshaking options for the modem are incorrectly configured.
  • The modem is unsupported, or the chosen emulation may be incorrect.
  • The modem .inf files become corrupted or the modem driver becomes corrupte
To solve this problem, use the appropriate method:
  • Reset your modem. Consult the documentation for information about how to reset the modem.
  • If you have an external modem, make sure that you are using the correct serial cable. For more information about requirements for proper cabling, refer to the "Cabling Requirements" section in Dial-Up Networking Help.
  • If you have an external modem, make sure that the serial cable is connected securely.
  • If you are using a pin adapter to connect your external modem to your serial port, make sure that the pin adapter is wired properly for modem communication. For example, a 9- to 25-pin adapter for a mouse does not work properly with an RAS serial setup.
  • Test the serial port or multiport adapter, and replace the adapter if necessary.
  • Make sure that the handshaking options for the modem are configured properly. Consult the documentation for information about the different handshaking options that are available for your modem.
  • Contact the modem manufacturer to see if any setup and initialization information is available for your modem. Also, check the latest Windows hardware compatibility list (HCL) to make sure that your modem is supported.
  • Use Device Manager to remove the modem. You can do this in safe mode or in normal mode. Restart the computer in normal mode. Windows will redetect the modem and reinstall the correct drivers.
May 12, 2011 | Computers & Internet
While connecting to internet with nokia 3230 usb modem i'm getting error 692
Hi to resolve this problem, use the appropriate method:
  • Use Device Manager to remove the modem. You can do this in safe mode or in normal mode. Restart the computer in normal mode. Windows XP will redetect the modem and reinstall the correct drivers.
Thanks...
With regards....
Priya
Sep 30, 2010 | Computers & Internet
I have a laptop NEC versa Note serial: 116700069, part no: PC-709HB211552X I want to ask is, why the laptop is not in use to connect to the Internet. I have been using MODEM (local) type CM300 Cheers. if I...
OK when you use external modem you have to creat a new net connection. and there you make it default modem. but follow the. 1st uninstall your external modem, restart, then run external modem set up after a while your system ask for modem that time you connect your modem and follow the instruction. then restart your pc. after that create a new connection point for net connecting and make a default with these modem, restart ur system. after that you can connect your net i wish.
Jan 30, 2010 | NEC Versa Note NB 6/233 (VN230020-000000)...
I have a computer, a all-in-one printer, a phone line, and a cable modem. how do i make this work? there is no phone jack in the modem.
Okay... Let's see if I can help you out.
Yes, your cable modem should have a phone jack on it. Are you sure it's a modem and not a router? Do you have phone service through your cable company? If so, your modem should be phone ready. Just checking..... :-)
The first thing you want to do is get your computer completely set up and ready to run (do not turn on yet). Just make sure all components are plugged in. Everything should be color coded and different sizes & shapes making it virtually impossible to cross anything accidentally. Your mouse and keyboard should be the only two components having the same kind of connection but they are color coded on the connectors and behind the computer too. No worries!!! :-)
Next, get your modem hooked up. Plug in power cord and attach cable wire into the back of the modem. Next you'll need an Ethernet wire to go from the back of your modem to your computer. If you're not familliar with ethernet - it looks like a phone cord only bigger.
Next get your printer wires hooked up to your computer as per directions for your specific unit. Should be fairly simple.
Once you have everything connected, power up your modem. Once it's finished booting up, turn on your computer. Once your computer is completely finished booting up, Turn on your all-in-one. Your computer should now be showing...Found New Hardware. Follow on screen prompts.
I hope this info was helpful to you. If you do need further assistance don't hesitate to ask. If needed, I'll give you my # so I can walk you through it over the phone.
Good Luck!
Jan 29, 2010 | Telebit Refurbished OPEN BOX EXTERNAL...
My 8330 does not let me browse the internet on my
Hi BlackBerry smartphone with tethered modem capabilities can be used as an external modem to connect a computer to the Internet.
To set up a tethered modem, complete the following tasks from A to D
A) Install BlackBerry Desktop Software 4.1 or later on your computer.
B) To set up an Internet APN, complete the following steps:
1) Click Start > Settings > Control Panel.
2) Double-click Phone and Modem Options.
3) In the Phone and Modem Options window, click the Modems tab.
4) Select Standard Modem and click Properties.
5) Click Change Settings.
6) In the Standard Modem Properties window, click the Advanced tab.
7) In the Extra initialization commands field, type the following:
+cgdcont=1,"IP","<your Internet APN>"
The extra initialization command is: +cgdcont=1,"IP","wap.voicestream.com"
8) Click OK.
9) In the Phone and Modem Options window, click OK.
C) To configure dial-up networking, complete the procedure that is appropriate for Windows Vista
1) Click Start.
2) Select Connect To.
3) Click Setup a connection or network.
4) Click Setup a dialup connection.
5) In the Dial-up phone number field type *99#.
6) Type the user name and password provided by your wireless service provider.
7) In the Connection Name field type BlackBerry.
8) Click Dialing Rules.
9) Make sure the profile created in Task 2 has been selected, and then click OK.
10) Select Connect to establish an Internet.
D) To connect to the Internet using dial-up networking, complete the following steps:
During this procedure, do not operate the BlackBerry Browser or any third-party applications on the BlackBerry smartphone. An active data session might interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
1) Connect the BlackBerry smartphone to the computer.
2) Open BlackBerry Desktop Manager.
3) Click Start > Settings > Network Connections > <name of your new connection>.
4) Type the user name and password provided by your wireless service provider.
5) Click Dial.I hope this information will help you
Nov 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Need help picking an external modem for an old Dell Insprion 2500
Any computer capable of running Windows ME is capable of supporting any external modem.
In the past, for "internal" modems, there were "hardware" modems and "soft" modems.
The "soft" modems had 50% of the hardware of the "hardware" modem,
and the rest of the "brains" of the modem were embedded
in a software device-driver that gets installed into Windows.
Fortunately, most external modems are *NOT* such "soft" modems.
There do exist external modems that connect to a USB port,
and external USB wireless-devices, if you want a higher-speed connection.
Apr 27, 2009 | Dell Inspiron 2500 Notebook
My modem
Returning the computer to Gateway is the most reliable option, but unless you have the premium grade warranty this will be expensive.
You can buy a replacement from Best buy, but if it is for a laptop I would recommend either an external modem or a PCMCIA modem. Opening up a laptop is a job for an expert. If you have a desktop/tower PC then you can buy an external or an internal Modem, Only but the Internal modem if you feel confident about opening up the PC. The external modem is the safest to buy. You will need to check what connections you have on the back of your PC either a serial connector or nowadays a USB connection. Make sure the modem you buy is appropriate to the service you use e.g. dial up or DSL. The assistant in Best Buy should be able to help you with that.
This should fix it .
Carrie
Jul 21, 2008 | Computers & Internet
Pc modem help
Yes, they do make an External Modem. You can purchase a an external modem and any local computer store or even online.
It can easily be hooked up with a power cable which should be included and a phone cable or a dsl cable depending on if you are getting a dsl modem or a dial up modem.
Either way, the external modem should come with easy to follow directions.
I hope this helps.
Please post a rating if I have answered your question.
Good luck.
Mac =)
May 20, 2008 | Computers & Internet
Need to install a modem on a Quick Eagle 4200T CSU
C-NOS:
Basically the modem has to dial in first to give you connection, One end goes to the Phone wall socket and the other end to your computer.
-Now in your case I am sure that your router is a DSL router meaning have no capability of dialing on command from the external modem.
-Nowadays VOIP built in routers are much more capable of dialing numbers directly.
-Old dialing modems should be connected directly from computer to the wall jack (phone lines).
Hope that helped!
Dec 10, 2007 | Computers & Internet
Open Questions:
Computers & Internet Logo
24 people viewed this question
Ekse
Marvin
Marvin
