Question about Jandy ZODIAC LEGACY HEATER 400KBTU MILLIVOLT NATURAL POLYM ()
New Pool Heater not igniting on demand
Installed new Jandy Legacy LRZE (250k BTU) Pool Heater 2 weeks ago
I have plenty of water pressure. However, since the initial start up of the pool, I have been having issues with the heater not wanting to ignite. When I increase the temperature on the display the ignition will not ignite or should I say only when it wants to. Additionally, when the heater does work, as soon as I try to increase the temperature (ask for more heat) the system shuts off and I get a 'Faulty Ignition Control' error. I can make several attempts to reset the system; turn off the gas, power, etc... and it will not restart. Should be immediate. I tried for 2 hours Friday night and it wouldn't come back on. Tried last night (for the hell of it) and the heater fired up. Attempted the above again (increase heat after running for 1 hour) and got the same errors.
I could see having problems if I didn't have enough water pressure, but that is not the case. Could there be an issue with a brand new 'Ignition Control'/Pool Heater? Has anyone else had a similar problem?
I look forward to your feedback...
    Top Expert:
  • Jandy Master
  • 7,897 Answers
If wired 120 volt make sure to check wiring red and black wires need to be changed ignitor not getting enough voltage
Posted on Apr 29, 2016
SOURCE: 5 year old Laars 25,000 LX won't ignite.
The low pressure indicator is for the gas pressure not the water pressure. The heater won't ignite because it's not getting gas to the igniter. Check gas supply, if okay, check gas connections, valves, etc.
The 1 HP motor should be fine on the jacuzzi.
Posted on May 26, 2009
  • 246 Answers
SOURCE: Jandy Lite 2 does not ignite
burners are plug with spider get a wire and bended get it inside the orifices where the gas come out every single one than try now ? magic heater comes on
Posted on Oct 16, 2009
  • 990 Answers
SOURCE: I have a Jandy Lite
This sounds very much like spider webs in the gas orfaces. If you shut the power off and remove the wires to the gas valve then shut the gas down and remove the fed pipe from the gas valve you should be able to pull the burner tray out of the heater. Now if you remove the burners you should be able to remove the brass orfaces connected to the main gas feed pipe. If you use an air hose or a can of compressed air you can blow this out now. Now take the orfaces you removed and clean them with a tooth pick or a small piece of wire. The webs will look like small cotton balls or lint. They don't stop the gas they just slow it or disperse it and keep it from firing clean and evenly.
At this point you can reassemble the tray and install. This should fix your problem.
Posted on Nov 14, 2010
  • 31 Answers
SOURCE: new jandy LxI 400 natural gas pool heater makes a
Your bypass valve is bad. Probably because you did not pay attention to your water chemistry. It is located where the pipes enter the heater. You remove it from the side of the manifold that is outside the heater. It is not a difficult job. Just make sure your pump does not come on while the heater manifold is open!
Posted on Apr 18, 2011
  • 256 Answers
SOURCE: jandy legacy pool heater brand new igitor doesnt
Good day. Some of the gas heaters have a battery powered ignitor. Please check if batteries are installed, and if so, is there sufficient power from the batteries (have the run down). Hope this helps
Posted on Jun 21, 2011
Error message Fault. High Limit , upon attempting to use the heater for the first time this season
either not enough water flowing through heater or low gas pressure to overheat unit replace high limit in stack if not one replace one on bottom white unit with 2 white wires
May 26, 2016 | Jandy LRZ250EN Legacy LRZE Pool & Spa...
Why won't my new lrz start
need more info if wired correctly yo have a display you have correct gas pressure check wiring first if not wires 220 you must change thing see a professional
Aug 16, 2014 | Jandy LRZ250EN Legacy LRZE Pool & Spa...
The pool water does not heat even though the heater says that it is set to 86 Jandy Legacy model LRZ325EN
there may be a problem with one or more of the safety devices causing the heater to not start. the biggest culprit is the pressure sensor followed closely by the fireman switch. get a pool heater technician to test and repair this problem
Jul 06, 2014 | Jandy Legacy 325K BTU Natural Gas Pool...
What does fault ing control mean on a LRZE pool heater
means it tried to fire 3 times and didnt light ignition failure make sure gas valve is on then see if ignitor is glowing if not need ignitor
May 18, 2014 | Jandy LRZ250EN Legacy LRZE Pool & Spa...
I have Jandy/Zodiac LRZE legacy heater and Jandy RS6 controller. When hooked up to RS6 and there is a call for pool heat the heater ignites but shuts off in about 30 seconds. When I disable the TSAT...
check your dip switches on the inside panel of the aqualink if you still cannot get it to work i would use the pool to 1 wire of a new wire you will run to the heater then 2nd wire to com then on the on the PCB board going to pins 1 and 2 of the big plug then turn heater all the way up when heater button is pushed or activated it will turn heater on and off
Aug 05, 2013 | Jandy Legacy LRZ Heater
Jandy LXi gas heater error message "ignition control failed
if ignitor is glowing try changing position of the shutter 1/2 to 3/4 open should lite
Dec 22, 2012 | Jandy Laars LX Pool Heater / 250,000 BTU /...
Error code open water sensor
need new temp sensor located right side in front 2 black wires with black plastic nut
Jun 15, 2012 | Jandy LRZ250EN Legacy LRZE Pool & Spa...
My Jandy Laars Natural Gas pool heater (LJ250N)
Check your heater by-pass valve and be sure it is almost closed. If not that then it will be your internal by-pass. These will force water through heater and keep it from overheating the water inside it and shuting it down. Also check to be sure the baskets are clean and the filter is clean.
Jun 27, 2010 | Zodiac Jandy Lite 250K Btu Natural Gas...
Low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
May 10, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy ZODIAC LEGACY HEATER 400KBTU MILLIVOLT NATURAL POLYM () Logo
97 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
