Question about Sunbeam SMW777 Microwave Oven
We just bought a Sunbeam 700 watts Microwave and it doesn't heat up. We put a cup of water in and it comes out cold. Please help.
  • 2,841 Answers
If you just bought it then it has a warranty. Return it for a replacement.
Posted on May 30, 2010
I want to know how many watts my 2002 jvm1430bd002 microwave has...I have googled this question and have answers ranging from 700 to 1200! what gives???
Conduct what the USDA Food Safety and Inspection Service calls a "Time-to-Boil" test, which will help you estimate your microwave's wattage. Add 1 cup of water to a microwave-safe 2-cup measure. Add ice cubes and stir until the water is icy cold. Pour out the excess water, leaving just 1 cup. Place the measuring cup inside the microwave. Set the oven for four minutes on high. Watch through the glass to see when the water boils. If it takes less than two minutes, the microwave is 1,000 watts or more; if it takes 2.5 minutes, the oven has a rating of 800 watts or more; if it boils in 3 minutes, the estimated wattage is 650 to 700.
How to Find Microwave Oven Wattage eHow
Jan 08, 2015 | Microwave Ovens
How do I know wattage for 1974 recipes and convert cooking time to todays microwave (1200)
A 1974 Microwave Oven is probably not putting out more than 600 watts. You need to do a power test to determine it's actual power output. Place a 2 cup glass measuring cup with exactly 500 mL of cold water. Record the starting temperature of the water. Run the microwave on 100% power for 18 seconds, using a watch or timer, not the timer on the unit. Take the water out and stir it to make sure that there are no hot or cold spots in the measuring cup. Record the new temperature. Example: 78.4-64.1= 14.3.
Multiply 14.3 X 38.75= 554.125. The power output is 554 watts IEC. If the recipe is set for a 1200 watt unit, and your is almost 600 watts, obviously, you would double the cook time. Since this is rough, you need to experiment a bit. If the cook time is 10 minutes, check your product at 8 minutes. Be sure to push the stop button before you open the door when it is in cook mode. This will save wear and tear on door switches and leave the remaining cook time on the timer. Let me know how this works out for you..
Oct 11, 2013 | Panasonic 1974 Microwave Oven Cookbook &...
How do i replace a fuse on sunbeam microwave
If it does not heat, the magnetron tube died. Not worth repairing unless under warranty. Generally the only fuse is a main fuse. If it blew, the entire microwave would be dead.
Feb 04, 2013 | Sunbeam 900-watt Digital Microwave Oven...
I need an owner's manual for a sunbeam microwave 700 watts model#SM0701A7E
For assistance with your Sunbeam Microwave, you can call 1-866-257-3336.
Dec 15, 2011 | Sunbeam Microwave Ovens
My microwave does not heat as hot as it use to. What would cause that.
Here is a simple power test.
Place a measured cup of water into the microwave. Run the micro for 2 minutes. A 1000 watt micro will boil a cup of water in 2 min. Check the power output of your machine. It will be found on the model number tag. A 700 watt micro will take about 3 minutes. If this occurs, the machine is working properly.
Otherwise, check the outlet voltage, should be 110 or higher.
Outside of this, you could need a high voltage capacitor or magnetron.
Dec 30, 2010 | GE Microwave Ovens
Sunbeam SM777 700 WATTS
This is most likely a simple problem or a bad door switch or door switch mount. See this file.
It should answer all your questions so you or someone you know can fix it pretty easily.
Jan 29, 2010 | Sunbeam SMW777 Microwave Oven
Sunbeam 700 watt micro shut off while in use now nothing comes on
it is problem power supply or panalboard unite,If you are not a technician,please go to a service center.
Dec 06, 2009 | Sunbeam SMW777 Microwave Oven
Microwave oven not heating thoroughly
u need to clean the cavity inside the microwave .. step to clean that .. put a cup of water nearly half filled( 30 ml ) and start microwave for five minutes .. after that just open microwave and clean from inside with clean cotton cloth .. this will surely help ..
Mar 23, 2009 | Kenmore 63683 Stainless Steel 1200 Watts...
What is the time for a 8oz cup of beverage to heat?
Depends on the power of the oven and to what temperature you are trying to heat it.
My rule of thumb is that a cup of water should boil in 1-1/2 to 2-1/2 minutes for microwaves rated at 1200 watts and 700 watts respectively.
Does this answer it?
Aug 26, 2008 | GE Microwave Ovens
Sunbeam SMW777 Microwave Oven Logo
180 people viewed this question
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
