Question about Siemens 32 in. EH78754EU Electric Cooktop
HTET 715 har gått i baklås ur återställer man
Where can I get a wiring diagram for whirlpool speed top 2600 electric cooktop
Sometimes if you call the manufacturer of an appliance and have your model number ready, they will email you an diagram or mail it to you. I would not tell them what you are planning on doing, simply because of them not recommending doing this they may not give you what you need. Just tell them you need a diagram thats all. I've done this in the past and it was free, just depends on the company you are dealing with. Hope this helps, good luck.
Feb 11, 2012 | Cooktops
How to clean the cooktop fan
as always turn off the power , I have tryed several types of cleaners over the years but fantastic works th best
Dec 04, 2011 | Jenn-Air Cooktops
My gas glass cooktop keeps clicking. I unplugged the it and left it overnight. When I replugged it the next day it still continues to make the clicking sound. It is driving me nuts! Two days ago my...
That was a really smart idea to unplug your cooktop and let it dry out. Many times that fixes the problem, however, if the problem returns as in your case it is time to replace the wire harness. Their are 4x switches associated and directly under the 4x burner knobs. Moisture can case a short and send a false single to ignite the burner when nothing has been turned on. Take a look at this picture from the link. Number 12 is the wire harness that has failed.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0108041-00002.png
You can purchase this switch by typing in the model number on a appliance parts website and doing a search.
If you are handy here are some general steps to remove and replace the bad igniter/switch harness.
  1. Take off all the grates and burner caps
  2. Unplug the unit and turn off the gas line
  3. Un-screw the 2x screws on each burner
  4. Remove burners and knobs
  5. Lift up on the cooktop cover separate it from the burner box
  6. Pop off the wire harness switches one by one and observe the way it comes off
  7. Place the new wire harness into place and snap in switches then connect wires
  8. Reinstall all components
Fasten everything down and retest unit. This job should take around 45min to 1hr to complete.
Please rate me "4 thumbs" if this free answer was helpful to you. Always the best of luck!
Dec 16, 2010 | KitchenAid 31 in. KGCC505 Gas Cooktop
All 5 ignitors constantly spark
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Feb 26, 2010 | GE 30 in. Profile JGP933 Gas Cooktop
Gas doesn't come through to hob
hi,mostly is the problem is in only the line,i think ur line is far in ur cooktop thats why is the gas flow is slow to out in ur cooktop try & try,open ur gas valve for about 3 min or more until the gas is out.
Sep 03, 2009 | Whirlpool GLT3014 Gas Cooktop
Replacement of control board for Electrolux Icon 30''
Hello, I am going to go out on a limb here and risk a bad feedback score but I have seen this many times in the past few years and have even made the mistake of replacing the EOC (Electronic oven control) when the EOC was not the problem, Reading between the lines with no model number I'm going to assume you got the error code for a bad EOC which is why the repair guy changed it. Well the second one could be bad too but I seriously doubt it. To me after changing the EOC and it still don't work the problem is going to be with the touch pad if it has one (be mindfull I dont have model number so I don't know other then electrolux which oven this is). The way to test this diagnosis is to turn the power off...Remove the ribbon/cable harness from the touchpad to the EOC. Switch power back on and wait 24 hours. If Error code does not return it's the touch pad, if within the 24 hour period the error comes back it's the EOC. Can't be any easyier then that to figure which it is and any tech worth his salt would know that. Hope this helps some, Maybe you can try it while you are waiting for the new part. Good Luck!! if you have any further questions or concerns please feel free to comment again. Mike
Jul 20, 2009 | Cooktops
Jenn-Air Cooktop replacement needed
You can get a new cooktop surface from Maytag/Jennair for $229. It is a pain however to replace it. Where is the crack in your cooktop and does that crack pass directly through a heating element? If not, then you may be able to repair it. I broke the corner off mine, and then dropped the piece (now 5 pieces). I was able to bond them back together and you really can't tell it was ever broken. But, it takes some work.
Apr 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Kenmore gas stove top switch harness replacement instructions
for the 4 burner if u not use coz of no igniter,use matches or lighter every time to use,if not turn the burner remove the knob & try to use hammer slowly at the top of the gas valve mostly the problem is stockcup,use oil b4 u try to turn.for the harness wire call the contact service center to buy a harness wire to replace the parts,but it so easily to replace the wire try to open the unit to see the wire size,color then gi to hardware to buy a wire same as in ur unit.tnx gerbee
Jan 27, 2009 | Dacor Preference SGM466 Gas Cooktop
Did the element fail, or the switch, or the harness?
Buying and learning to use an ohmmeter is best. You can also inspect both the harness and the burner for damage. If nothing is burnt or broken, then you probably need the switch. Hope this helps!
Dec 29, 2008 | Jenn-Air JED8430 Electric Cooktop
Child lock on for neff t1443
gud day,not all models of ceramic hob have a child lock,check it 1st ur unit if have it,if we have,touch the circle w/sign of key to lock the ceramic for ur child,to unlock touch again.u see the ligth red is on it means the lock is in ON.easy to unlock even ur child by touching the key sign,for ur safety to not use ur unit,unplug the unit if it not use.
Aug 21, 2008 | Neff 23 in. T1443 Electric Cooktop
Siemens 32 in. EH78754EU Electric Cooktop Logo
453 people viewed this question
Top Siemens Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Siemens Cooktop Expert? Answer questions, earn points and help others
