Question about Zanussi ZWF1430W Front Load Washer
Zanussi washing machine drum will not go round at all
Hi there can you please help me with this problem i have a zanussi electrolux washing machine and the drum wont go round at all my husband has checked the belt and thats fine and the motor still works even if you try and turn the drum with your hand from the inside it still wont turn. thanks tracy
drum wont turn at all
  • 1 more comment
  • Anonymous May 06, 2008
    drum wont turn
  • claremacbeth Sep 21, 2008
    I have a zanussi aquacycle 1050 and the drum is jammed please advise
    Many thanks
  • Anonymous Mar 22, 2014
    washing machine wont start. led's keep flashing
I had a similar problem with a zanussi machine
a cheap bracelet got washed with some clothes and it found its way into the drum housing jamming the drum.
it may have been cheap to fix, but i just got rid of it cos it was 4 years old anyway
i now have a zanussi ZWF1231W just past its 1 wear warranty that has just died completely except for an "on indicator light"
the store inform me that i will have to pay the zanussi engineer a Euro 90 call out charge, plus labour costs, plus parts if needed.
im a little bit disappointed with zanussi to say the least
Posted on Apr 23, 2008
2 Suggested Answers
  • 43 Answers
SOURCE: zanussi washing machine drum will not go round at all
Tracy
The bearing may have siezed or you have something jammed between the drum and outercasing
Posted on Mar 23, 2008
Zanussi zwf1421
Thermostat or heater most likely causes. Does timer button move round without doing anything? Timer knobs on Zanussi notorious for breaking off inside.
Apr 28, 2012 | Zanussi F1245W Front Load Washer
Hi I have a zanussi Jet system FJS 1397W washing machine, the problem with it is that, the drum does not spin round any more- What is likely cause? thanks
hi check the pump first it has to drain before it spins the other cause could be the module control board the control the motor speed hope it helps
regards
shaun
May 27, 2011 | Zanussi FJS1225W Front Load Washer
How easy is it to do a bearing change on a Zanussi progress 1400 washing machine please?
It is far from easy, as it usually involves a complete strip down, not recommended unless you know what you are doing.
Also, if the drum shaft is worn, then that is a major expense.
Hope this helps.
Jan 18, 2010 | Electrolux Washing Machines
Zanussi electrolux essential 1400
bad smell coming from inside the drum how do i fix it? thanks
Jun 26, 2009 | Zanussi FC1200W Front Load Washer
WASHING MACHINE
Unless you can hear it catching as the drum is going round I would leave well alone, it will probably just get lodged near the heater and not cause any problem.
If the m/c has a removable rear panel then you can get access into the drum by removing the sump hose fastened onto the bottom of the drum. you might find it stuck there.
If no removable panel, then it is a strip down job, Not recommended, unless you know what you are doing.
Dec 12, 2008 | Zanussi FS1255S Front Load Washer
Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Jul 28, 2008 | Zanussi FC1200W Front Load Washer
Filter can be clogged, pump can be dead or water outlet clogged.
Apr 11, 2008 | Zanussi ZWF1430W Front Load Washer
Tracy
Mar 23, 2008 | Washing Machines
Zanussi ZWF1430W Front Load Washer Logo
1,371 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
