Question about Amana 24 in. DWA73A Built-in Dishwasher
It won't turn on. Two lights, the Water Temp
It won't turn on. Two lights, the Water Temp Boost and Air Dry, are blinking but won't turn off when the start button is pushed. Checked connectors, power source, door latch.
  • jmrrdaniel May 30, 2010
    It was the door latch contact. Thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check for the following--
1. Wire fasteners at dishwasher junction box.
2. Electronic control board faulty.
3. Motor (inoperative, check resistances).
4. Door switch (open contacts).
5. Door latch not making contact with door switch.
6. Touch pad circuit defective.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 30, 2010
Dishwasher won't run, clean light flashing
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 06, 2011 | Maytag Dishwasher
Green clean dishes light blinking instead not blinking. Dishes clean, but not totally dry. I removed them from dishwasher. Clean green light continues to blink after door is shut. Pushing cancel...
Hi
Daniel
Aug 04, 2011 | Kenmore Dishwashers
The "clean" light blinks 7
Hi
Daniel
Jun 28, 2011 | KitchenAid Dishwashers
The "clean" light is flashing
Hi
Daniel
Jun 18, 2011 | Whirlpool Dishwashers
Clean light blinks 7 times and won't let us start a cycle. Then it continues to do that
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 08, 2011 | Kenmore 24 in. 17029 Built-in Dishwasher
My clean light is blinking and it will not start
Push in this order within 5 seconds...
Sani Rinse Air Dry Sani Rinse Air Dry....if you dont have those buttons, substitute:
Hi Temp Wash Heated Dry Hi Temp Wash Heated Dry
Let it go through the diagnostics cycle, about 10 minutes. Push Cancel/Drain. If it occurs again, you have something wrong with the heater circuit. Check the heating element for breaks.
Jan 13, 2011 | Kenmore Dishwashers
Kitchenaid dishwasher....clean light will not turn off. Dishwasher will not turn on. Just had motor and pump replaced on Thursday 12-30.
Hi
If clean light is blinking indicates an issue with heater circuit, door switch or wash pump. To resolve this please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Jan 01, 2011 | KitchenAid Dishwashers
The "clean" light is blinking - so the dishwasher isn't working.
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn’t work then it’s an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Daniel
Aug 07, 2010 | Whirlpool Dishwashers
Blinking clean light, will drain with cancel button,wont wash
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 26, 2010 | Kenmore 13853 Stainless Steel Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Amana 24 in. DWA73A Built-in Dishwasher Logo
54 people viewed this question
Top Amana Dishwashers Experts
Cleverer2
Charles T Nevin
Charles T Nevin
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
