Question about Canon PIXMA MP150 All-In-One InkJet Printer
My printer mp145 with error e23, please help?? help....
  • 903 Answers
From looking around online, it appears that E23 is a paper feed error. Do you have jammed paper anywhere inside the printer? Open all of the covers and doors, remove the toner cartridge and paper trays, and try to find the paper that it sees. If you close everything up and the printer still shows the E23 message, turn it off and turn it back on to see if it clears.
Posted on May 30, 2010
Open the printer cover and check the right drum that whether the head cleaning pipes open off the head cleaning part and rolled stuck in the drum or not if not than check the left side wheel black belt whether it is loss or not if loss than tighten the motor with which the belt attached cause some time the motor come front by printing pressure for what the hole wheels assembly can't load the paper for which much strength needed.
Posted on Oct 01, 2010
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
Error e42 22
Apr 24, 2011 ... E40 20 = Other hardware error. E42 22 = Scanner error. How to reset CANON WASTE INK COUNTER MP160/MP145 Before you reset the ... canonprintersink.com/error-code-printers-reset-canon-mp145-mp160.html canonprintersink.com/error-code-printers-reset-canon-mp145-mp160.html
have just checked this site and I am sure it will help you
Feb 20, 2012 | Canon Office Equipment & Supplies
How to fix error 24 for mp 160????
Hi
This is a purge unit error hence you need to check and make sure the purge unit is working fine. If not you need to clean it.
THE PURGE UNIT IS THE ONE ON THE RIGHT SIDE WHERE THE CARTREIDGE RESTS WHEN YOU TURN OFF THE PRINTER.
And at the same keep the below mentioned error list for your future use.
CANON MP140, MP145, MP150, MP160 ERROR CODES RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E3-3 = Paper jam
E4 = No ink
Direct Printing
E29 = EEPROM error
Jul 31, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I have a canon pixma mp145 and have error 23..how can i solve this problem???thanks..
The manual does not specify exactly what error E23 means, but tells you what you should do.
Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
You can read more about the error codes on Canon website: http://support-au.canon.com.au/contents/AU/EN/8000137001.html
Dec 05, 2010 | Canon PIXMA MP150 All-In-One InkJet...
On the screen show 5e
Procedure to reset Printer canon MP145, MP150 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E29 = EEPROM error
E35 15 = USB Host VBUD overcurrent error – USB
Aug 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error code E-5
Found this, it may help you Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
button pressing
Error Code :
E3-3 = Paper jam
E4 = No ink
E29 = EEPROM error
May 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Mp 145
How to reset the e27 for canon mp145 printer?
May 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
1,437 people viewed this question
old marine
old marine
