Question about Whirlpool GI5FSAXVY Stainless Steel Bottom Freezer French Door Refrigerator
When the compressor comes on it makes a poppiing sound Is this normal?
    Novelist:
  • 77 Answers
No this is not normal. Either the device plugged into the side of the compressor is making that sound or the compressor itself.
I have a couple of suggestions. If it is the device plugged into the side of the compressor (called an overload and relay) then I would replace it. Sometimes you can take them off and see that they are damaged or burned. Other times you have to take them off and shake them. If they make a distinct rattling sound it is broken. What is rattling is a disk shaped object that is broken and no longer works. However, your compressor is starting sooooo, I doubt that piece is totally broken.
If it's the compressor, it may be worth fixing because it looks like you have a really nice frig. This will be expensive unfortunately. Compressors are expensive as well as the labor to replace them.
Posted on May 30, 2010
I want to cancel poppy lottery
Try to go to your email settings, and add to black (block) list. Or login and remove your account and unsubscribe from all messages in poppy lottery.
May 24, 2014 | Computers & Internet
What does giving white poppies in a corsage mean/symbolize?
White poppies are famous in corsages. White matches most party themes. They represent peace and love.
Apr 10, 2013 | Event Planning & Celebration
My refirgerator model number pbf2255hew stop cooling & compressor stop working...tries to come on but won't
Check your fan on the back of refrigerator...Might need replacing..Surly needs cleaning
Dec 08, 2017 | Maytag Refrigerators
Should the compressor be going fut fut fut? I got mine out of a box new after keeping it unused for three years. It makes a fut fut fut sound rather than a continuous pressure release. Is this normal?
I have heard some belt drive compressors make that fut fut fut sound you describe, Its not a problem in my book as long as the pressure builds and the motor is not straining. I have even heard that sound come out of direct drive compressors, so I don't think you have a problem here.
Jan 22, 2011 | Mammoth 300 PSI Air Compressor 12 Volt
External unit noisy
Sounds like bearings are out on the compressor. I'm assuming that it's not the fan motor making the noise, cause if it was - and the fan motor is cycling on and off - it (fan moter cycling on/off) will also cause the compressor to cycle on and off.
But, since you say it's the compressor (from which the noise is coming from) I would have to say the compressor's bearings are out and since it's a hermetic (sealed) compressor - your only option is to have a service tech check it out to be sure.
Note: I think you are correct (in thinking) a thermal overload is cutting off the compressor, because the compressor does have a 'saftey overload' built internally in the compressor just for that reason.
good luck!
Apr 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
My fridge freezer GR359SQ is making a constant buzzing noise and is hot to the touch round door area and the side.
The hot touch around the door area is normal. Buzzing sound can come from anything in and around the compressor. A slight bend of tubing can change this. Feel around the compressor while it is running and you may notice a change in the sound which is caused by resonant frequency in the routing of the tubing or mounting of the compressor. Hope this helps
Jul 02, 2009 | Refrigerators
Kenmore bottom freezer, make clicking and gergging sounds, the unit is 8 yrs old
The gergging Is probably normal sounds of the compressor equalizing pressure when it cuts off. The clicking, could be the compressor starter relay possibly going bad making the noise when the compressor comes back on.
Jul 01, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
There is a loud noise coming from my engine ..sometimes..
oh ok, you probably have air shocks and that is the compressor running... makes sense that it sounds with the engine off... it should not be a loud sound though, normally it's quite quiet and you only hear a faint noise... if it is that loud it's probably a bad compressor
Jan 13, 2009 | 2003 Lincoln Navigator
Whirlpool GI5FSAXVY Stainless Steel  Bottom Freezer French Door Refrigerator Logo
76 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
