Question about Peavey TLS115X Speaker
Was gigging with peavey 112xt subs and hisys 6 rx sats, one side went very low and ive isolated the problem to one of the subs, i was using dynachord 1000 powermate and driving it pretty hard, have i blown the sub, if so any ideas on how it can be fixed ?
To pjstokes.I have exactly the same set up as you and have experienced the same problem. So far I have Changed The Bulbs inside the tops and also replaced the thermal fuses on the soundguard circuits (which are inside the 6XT tops) but still have the problem. Only when the cabs are driven hard do they stop working, no problems at low volume. Peavey don't have a solution. I think maybe some of the other components have blown but I don't know which ones. If anyone knows a solution please post it here.
Posted on Jun 03, 2010
I have a Peavey 8600D can I safely run 1 main
When you unload one amplifier you stand the chance of killing the amp's output transistor. If you must use only one speaker, you have to bridge the amps.
Feb 09, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
How do I properly connect my peavey 118 subwoofer to my peavey 215 speakers
When asking questions please give as much detail as possible, t LEAST give the model or part numbers of the items you are asking about and anything else you will be using with them. Without this information it is impossible to answer more than general questions. However I will attempt to give an answer which could point you in the right direction below.
As you don't say which 118 and 215 you have it is impossible to give an absolute answer. Some 118s have an internal low pass crossover with two inputs in parallel, in this case you can take a connection from the amp to the sub and from the sub to the 215. Again some 215s have a high as well as a full range input so you MAY be able to use this to avoid driving full range into the 215. Some 118s have a high pass as well as a low pass in which case just connect the high out to the fullrange in on the 215. You could also possibly split the amp to use one side as a sub driver and the other for the mid/tops if the amp has a crossover.
You may also find that the wiring on the speakons on the tops needs to be different according to how you are going to use them (2+/- instead of 1+/-)
You will also need to know what impedance your amp is happy to go down to as in some combinations depending on which model 118/215s you have you could end up presenting a 2ohm load.
Dec 10, 2013 | Peavey Music
Fixing grill on peavey hisys 2
Grill cloth can be found on line, try Ebay too.
Dec 09, 2013 | Music
I have a sherwood RX 4109.....can i hook a pair of 6 ohm speakers and then a powered sub?
By design, yes for one pair of 6-ohm speakers used at a time; depends on the sub for the second BUT there is no way to control its volume at the Sherwood.
Mar 25, 2011 | Sherwood RX-4109
I have recently purchased a an XLS1000 amplifier. If the speakers (Peavey Hisys 2) are connected and the amplifier then switched on, an error code is displayed (LEDs sequenced in red and displayed the...
It sounds like speakers are loading down internal DSP - contact any Guitar Center and ask one of their techs for sure. Double check your speaker connections also.
Feb 13, 2011 | Crown XLS202 2Channel Amplifier
I have 2 peavey sp 5 and a pwavey 2600 amp . i wanna know can i hook a peavey 118 passive sub to one of the sp5 and how would it sound?
You would send high as well as low to the sub and unless the sub had a built in crossover it COULD get muddy sounding. The specs SEEM to indicate the 118 DOES have a low frequency crossover so it SHOULD be OK... How would it sound? An 18 inch sub normally adds to the sound of a system... You MAY need to PAN over to send more power to the one side with the extra load on one side. Often people use two sub's... one for each side so it is balanced.
Jan 19, 2011 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Wiring my peavey 112xt subs with my peavey 2xt tops
hi don't know if you have sorted this yet, you need to wire your cables that go from sub to top +2 -2 on the speakon (on the sub end only) HTH
Jan 04, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Two amp
I don't know why you'd set the Peavey to 2 ohm to drive 8 ohm speakers??? My other thought is... I wonder if the phase is correct. try reversing one of the speaker wires Left or right side.
Geno
Feb 27, 2008 | Harman Kardon AVR 630 Receiver
Peavey TLS115X Speaker Logo
312 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Steve
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
