Question about Saeco Royal Coffee Bar Coffee Maker, Espresso Machine
Error message says "coffee dispens. blocked" - Saeco Royal Coffee Bar Coffee Maker, Espresso Machine
  • 13,433 Answers
Most likely the dispenser is blocked, in order to unblock the dispenser pipe, you might need to disassemble the coffee machine, possibly remove the hose between the dispenser and the source inside the coffee machine and clean it.
saeco maintenance instructions
Advice for correct maintenance of an automatic Saeco espresso coffee machine:
  1. Brew Group maintenance :
    • Use Saeco cleaning tablets to remove old coffee from the brew group filters
    • Use the Saeco grease (included in the Saeco Service kit) once a month to maintain your Brewing group in perfect operation.
  2. Use Saeco tablets to degrease the brew group:
    • This operation should be carried out at least once a month if 2/3 coffees are brewed daily.
    • Perform a cleaning cycle more frequently if more coffees are brewed.
  3. Changing the water filter: Aqua Prima or Brita Intenza (according to the model): Change the filter whenever indicated by the machine:
    • To install the new filter, follow the instructions in the Instruction Manual.
  4. Descale the machine using the Saeco liquid descaling solution :
    • Descale the machine at least every three months or when prompt by the unit whichever occurs first.
    • Before descaling the machine, remove the filter inserted in the water tank
  5. Primea Cappuccino maintenance:
    • This model requires descaling and brew group maintenance the same as other machines. Additional maintenance requirements include:
    • When "Milk rinsing" flashes and you have finished using the machine, activate the rinsing cycle (20 sec) then remove the milk container and placed it in the fridge.
    • When “Milk cleaning” appears make sure to run the cycle within the 20 days otherwise the unit may block. Use “Saeco Cleaning Powder” to sanitise and clean the milk dispensers (15 min).
    • Wash the brew group under lukewarm running water at least once a week, do not use soap.
    • Clean the coffee circuit and brewing unit filters at least once a month if 2/3 coffees are brewed daily using the Saeco cleaning tablets (5min).
    • Grease the brewing unit once a month using the Saeco food safe grease
    • Perform these cleaning cycles more frequently if more coffees are brewed
    • Change regularly Saeco Brita Filter to improve the quality of the water used and your coffee.
NB: All necessary information about product maintenance and cleaning is reported on the Instruction Manual. Please read it carefully.
For further information or advice and/or to purchase Saeco accessories, you can call our free phone number 1800 0 72326 or go directly go to one of our Service Agents. Saeco accessories may be purchased from most major retailers
Locate service point
http://www.saeco.com.au/en/support-from/support-from.html
Posted on May 30, 2010
  • brennamanmar May 30, 2010
    Is the coffee dispenser the same as the central unit? My book does not say what the coffee dispenser is. Can you run water down the filling funnel? Since I'm a novice on this should I avoid trying to disassemble the machine?
  • Ekse May 30, 2010
    The dispenser is where the coffee comes out of. if the problem is not obvious, it might be best to take the machine to a service point, which you can find from the link on my last message, or you can give them a call.
Why wont the steamer work
hi,
he pump presses hot water through the grind not steam.
if the coffee is hot and hot water is dispensed, your line are clocked.
descale the machine as directed.
if coffee is cold the heat element is toasted. very unlikely though, since the machine will not dispens coffee, pump running if correct temperature is not reached.
good luck
Aug 08, 2014 | Saeco Royal Professional Espresso Machine
DeLonghi Alicia EMK6 - H20 error
Here is the link to the instruction manual if you need it; http://www.delonghi.co.uk/pdf_files/EMK6.pdf There is no information regarding this error message available online, but I think you are right and it relates to water - probably the sensor of the water level is stuck/blocked/scaled up. you can try descaling using white vinegar 50/50 solution with water, leave it overnight. Give the whole unit a good shake, in case the level sensor is a mechanical float device and it is stuck. See if any change. You can call Delonghi/Comet from this link; http://www.delonghi.co.uk/service_info.php hopefully they will tell you for certain what the error message means - if they do and it is different from what is discussed above, then please ask again if you want to try and solve the problem yourself. Hope this helps :)
Jul 30, 2007 | DeLonghi Alicia EMK6 Coffee Maker
Water dispening not working
try to check the motor
Jun 18, 2012 | Keurig B31
Get error message priime
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Jun 11, 2011 | Keurig B60 Coffee Maker
We have a Siemens Surpresso S40, giving 'error 8'
Error 8 indicates a technical fault. Try switching off the main switch for about 1 minute and then start it up again. If the error message persists, you will have to have the machine serviced. The most common fault would be that the machine is blocked.
Jun 06, 2011 | Coffee Makers & Espresso Machines
Our Jura coffee machine S9 model has error message Malfunction 4 appearing, have turned machine off from power swith and left off for 30 secs, still has same error message.
Hi, Printed below is the fault for Error 4:
STEAM: Temperature sensor notify “value above tolerance”
I hope this helps.
Alison, Uno Coffee Company
Feb 11, 2010 | Coffee Makers & Espresso Machines
'Grinder Blocked' error message
The grounds chamber is clogged, you will have to open the machine and clean out the chamber on the side of the grinder, it is the one covered with the little door, you might be able to get to it if you dremove the brew unit.
May 03, 2009 | Gaggia Titanium Espresso Machine
Hi I have a gaggia titanium coffee machine it has comme up with an error message the the brewunit is blocked i have decalcified machine but no joy can you help
Remove brew unit, If you have the key that came with the machine use it to remove the shower screens and check for blockage.
Mar 29, 2009 | Gaggia Titanium Espresso Machine
Brew unit blocked
You can remove the brew group by following the "how to remove a jammed brew group?" on this page http://cerinicoffee.com/Saeco_technical_documents.asp
For Cleaning Supplies and Saeco Parts visit:
www.cerinicoffee.com
May 30, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Royal Coffee Bar Coffee Maker, Espresso Machine Logo
291 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
