Question about DCS BGB30BQR (NG)
My grill won't stay lit, or does not heat up enough.....how can I clear the obvious blockage in gas flow?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
The most common obstruction in the gas manifold are spider webs. using compressed air and a blower tip is the easiest was to blow out your supply lines. some of this can be reached from the bottom of the grill but others require that you take out the grates etc which gives you a good chance to give the grill a tune up and scrub down all the normal parts and check the condition of the burners etc. good luck. always shut off your gas or disconnect the tank first. when your done the flames on the burners should burn blue with only the tips showing any yellow. otherwise your air or gas supply mixture is incorrect.
Posted on May 30, 2010
  • 3 Answers
THROW TO DUSTBIN
Posted on May 31, 2010
I don't hear the electronic ignighters
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
replacing whirlpool gas dryer ignitor not heating www goodappliancesupersto... How to Fix YOUR gas Dryer that is not heating up Part 1 rear panel
Jan 04, 2017 | Dryers
How to fix a whirlpool gas dryer that tumbles but no heat ?
Air Flow and Heat
Warning
Apr 12, 2015 | Whirlpool Dryers
Gas dryer throws reset after a few minutes
Air Flow and Heat
Warning
Apr 07, 2015 | Dryers
Kenmore advantage gas dryer
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Air Flow and Heat
Warning
Aug 10, 2014 | Kenmore Dryers
Just bought a new Jenn-Air grill and cant get the temp past 250. Any ideas what i am doing wrong?
First, check that all the gas lines and flame bars are clear of any 'things' or bugs. I had a similar problem with a Webber grill and found out my problem was with the gas bottle. The new Overflow Protection Valve required on LP bottles can closed off or severly slow the flow of gas when the bottle is full and the valve is opened quickly. It will let enough gas flow to light the grill but won't let the fire get high enough to heat the grill up. Turn all the valves off on the grill and gas bottle. Open the gas bottle valve slowly then turn on the grill burner and try lighting it. If the flame is still very low try again or you have to let it burn at the low level until the OPV float drops down and the valve doesn't impede the gas flow. The best way to avoid this in the future is to not fill the gas bottle to the top when you have it refilled. Just ask the LP attendent to not fill it all the way.
Jun 06, 2011 | Garden
Grill doesn't stay lit for the first 20 times, then does
regulator, is faulty, you need to replace it.
Apr 06, 2010 | Weber Q Grill
Burner will not stay lit
try to replace the regulator on the grill
Mar 20, 2010 | Ducane 30400042 (LP)
Poor gas flow. Burners will not stay lit. Gas
Try taking a large hammer or set of vice grips and banging pretty heftily on the tubes feeding the burners. These are usually build ups of Carbon. If not, then make sure your connections are good (sort of move them around to see if they are loose), and make sure your propane is not getting too close to empty (you can shake it around and feel/hear the propane).
Aug 10, 2009 | Amana 5939 Grill
DCS BGB30BQR (NG) Logo
412 people viewed this question
Top DCS Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a DCS Grilling Expert? Answer questions, earn points and help others
