Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
No power resistor 5.6 ohm open
    Novelist:
  • 144 Answers
Most likely that open 5.6 Ohm resistor is in the power supply, is it a fairly large squarish resistor? If so just replace it and try the set again. I think it's a ballast resistor that has opened up and this can happen with age especially if it was not perfect to begin with.
Try replacing it, I bet it will fix the problem...
Zashiban
Posted on May 30, 2010
I need to know the value of the Resistor "R1" in
Let us use a bit of logic to resolve this... I have an Axiom but it would be a lot of screws to take out to get to the part... so let us think about this. The resistor value starts with a "1" and we know it is 5% tolerance (gold). we know the resistor burnt up with likely 5 volts on it... Value could be 1000 ohms, however the voltages present (12 volts max) would NOT have burned up a resistor of 1000 ohms. The USB area is mostly 5 volts and across 100 ohms is only a quarter watt... not enough to really burn up a resistor... First thing is to MEASURE that the resistor s open... in spite of being burned, it MAY still be OK... these resistors now usually either open or remain close to their value. The resistor ALSO may be a fusible resistor intended to act as a fuse... Is the resistor open or not? is it near a resistance with a "1" as the first digit? If it is not open I suspect it is not all of the problem. In that case, look for a burned circuit trace on the board. If it is open, then MEASURE the voltage across the resistor with the power applied. If you find 5 volts, then it MIGHT be a 10 ohm used to limit the USB current to 500ma. Get back to me with your findings... I have unraveled many of these things...
Jul 12, 2011 | Music
Model KLH KL-2400 Reciever keeps popping fuses. Resistor in power input ckt is color coded YellowVioletYellow Gold for 470 Ohms 5% Tol. However this resistor reads 370 Ohms. Resistor needs replacement?...
470.000 ohms not 470 ohms 470k ohms at 5% tol. either the main p.s. diodes are shorted or the output and driver transtors are shorted causeing the fuse to blow....
Nov 17, 2009 | KLH KL2400 Tuner
I have a jl 1000/1 mono amp and my low ohm light was on and making a buzzing sound and found that there was a resistor that one of the terminals broke off and now no matter where i look i cant find the...
The 5 ohm could be challenging, what you could try is to get 2 10ohm 3 watt and put them in parallel. Will be 5 ohm and 10ohm is easy to get
Hope that helps
Jul 26, 2009 | Car Audio & Video
Front audio channel burnout
Resistors can fail from being turned up to hire, wires getting bumped together or against metal, speakers being wrong ohms, or just plainly overheating.
May 22, 2009 | Harman Kardon HKTS 5 System
KP-53HS20
Yes you can. Just go to service menu (display-5- vol+- power) and adjust convergence settings.
Thank you.
Feb 23, 2009 | Sony KP-53HS20 TV
NEED TO KNOW THE OHMS VALUE FOR RESISTOR ON PEANUT 8685
I have the same problem, but it is open.  The color code Brown - Green - Brown - Gold.  If it is a resistor, the value must be 150 ohms +/- 5%.  To confirm the value, I open the working trimmer and remove one leg from the circuit and measure resistance.  The meter reads only 4 ohms.  Therefore, I think it is an inductor (150uH +/-5%), not resistor.
Jan 27, 2009 | Wahl 8685 Hair Trimmer
No Video or Sound. Power Light Blinks 5 times = IC4011. Where do I go from here?
Check your hori out put transistor NTE2973 & 1200pf & 2kv capacitor next to it,most of the time this is what is bad .
ThankYou for using FixYa. Have a Nice Day.
Feb 08, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Sony 7 blinks
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
also found this
CHASSIS: AX1/AX1X/RA6/RA6A
MODEL: KDP51WS550, KDP57WS550, KDP65WS550, KP46WT500, KP46WT510, KP46WT520, KP51WS500, KP51WS510, KP57WS500, KP57WS510, KP57WS520, KP65WS500, KP65WS510
SUBJECT: Picture gets bright then shuts down. After repairs tech noticed a mark was created on all 3 CRT's.
CAUSE: Found Video Output was defective causing the failure of the 200v line. 200 volt line has two fuse resistors R7301 (10 ohm 1/4w) on the CB Board. R8225 (1 ohm 1/2w) on the D board. R8208 (0.47 ohm 1/2w) also on the D Board. All three resistors are in series. One or all 3 could be open. After replacing 2 resistors and Video Output IC set returned to normal operation. CRTs will need to be changed due to phosphor damage. On Models KDP-51WS550, KDP-57WS550, KDP-65WS550 CB Board resistor is R9335 10 ohm 1/4w. D Board resistor is R6509. NOTE: This resistor may be a jump wire according to the schematic. Models: KP-51WS520, KP-57WS520 These models have a fuse resistor on all 3 CRT Boards. CB R9335 10 ohm 1/4w CR R9110 10 ohm 1/4w CG R9211 10 ohm 1/4w On the D Board R6509 is a jumper wire according to the schematic.
Dec 11, 2007 | Sony KP-65WS500 65" Rear Projection...
Parallel connection of power mosfets with two of 5 smoking
The IRFZ46N are n channel high speed switches . They basicly drive the Mosfets. Sounds like you have some problem there my friend, and unless you paid alot for this amp. Its going to need probobly all the n channel switches as well as every mosfet + the bias resistors repalced. Before plugging in the amp jump out the fuse with a 100 watt light bulb.. If the bulb glows brightly when you apply power there is still a short in the unit and could be in the switching power supply section of the amp. If it glows bright and dims, The shorts are most likly gone. The bulb will minimize the amount of current the unit can draw and most of the time wont let the new parts blow out. Check out this service number and see if they can help you. Good Luck Main support number 978-823-0300
Jul 26, 2006 | Pyramid PB779X Car Audio Amplifier
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
85 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
