Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
Dishwasher runs for about ten minutes
My Diswaher runs for about ten minutes and the it shuts off and flashes 30. There is still water at the bottom of it and it is not running for the full cycle. What do I do?
  • 159 Answers
There may be a heating problem,if the water doesn't heat, the cycle can't progress further.
Posted on May 30, 2010
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Blanco Dishwasher BIDW605 does not
I would check the hose/water filters. make sure that you have proper flow from the hoses
Apr 04, 2008 | Dishwashers
FIRGIDAIRE DISHWASHER FDB1050RES0 WASHING LIGHT BLINKING CONSTANTLY BUT MACHINE WON'T RUN
Thank you for your inquiry, William Garrett!
I understand that the washing light on your Frigidaire dishwasher, FDB1050RES0, continues to blink and will not run. You may need to perform a reset on your dishwasher. In order to do so you would need to disconnect power from your dishwasher for roughly ten minutes. This will help clear out any false error codes or miscommunications within your dishwasher. If resetting your dishwasher does not resolve the issue you may need to have an electrical component replaced and I would recommend seeking professional assistance for that. Hope this is helpful. -Matt
Feb 16, 2015 | Frigidaire Dishwashers
Dishwasher wont completely drain and turns off
Good Morning Friend,
I understand that your Frigidaire dishwasher shuts off near the end of the cycle, leaving water in the bottom of the tub. I also see that the display is going black. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 20-30 minutes. When power is restored, run any cycle. If you are still noticing your dishwasher shutting off towards then end of the cycle and water being left in the tub, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to shut off and not drain. Hope this is helpful.
-Best regards-
WP
May 14, 2014 | Frigidaire Dishwashers
Dishwasher will turn on but no water will come thru then it shuts itsself off
make sure water line was not shut off or if hose.. not kinked going to to washer. If not it is the water valve on the dishwasher it self that is broke or stuck.
Oct 12, 2012 | Whirlpool Dishwashers
Our "Clean" light is flashing green continuous and
Try running a cleaning cycle with no dishes. If you have hard water, try adding a little CLR, or cleaning solution. Check the bottom of the washer for clogged bottom drains. Also check the manual if you have it. Sometimes holding down the button for almost a minute will reset the systems alert for cleaning. Unplug and let it set for a few minutes. Good luck
Feb 21, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
WATER IN BOTTOM OF DISHWASHER WILL NOT GO DOWN. I LOVE IT THOUGH
Check the diswaher drain at the dish washer wash area down the chamber. clean that filter.
Apr 29, 2010 | Dishwashers
Hotpoint dishwasher
Switch the machine off and unplug at the mains. Leave for ten minutes, then plug in and switch on. My dishwasher control panel had a mind of its own and did what it wanted including leaving water in the bottom of the machine. The electrics sometimes need re-booting! Hotpoint suggested the solution and it worked for me. Saved me £99 call out charge. Good luck.
Jun 04, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Whirlpool dishwasher reset code
Yup, found it on another site..I had the same issue today.
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later ..presto, my machine worked again.
My machine is not the GU3200XTP, but in the same Whirlpool tall tub series (same manual) so leds may not have the same name.
Mark
Oct 19, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
102 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
