Stay on for about 10 min and then shut off i wait for about 5min and it come back on but shut off again
  • 8,617 Answers
Need to know the model number of your set to help you. Shutdown usually happens as a way for the set to protect itself when voltages arent within the proper tolerances, but need model number to be more specific than that.
Posted on Apr 08, 2008
Hoover vacuum shuts off after 10 minuts of use.
If there is no clog the filters may need replaced to improve airflow
Jan 21, 2014 | Hoover Vacuums
Car will run or 10 min and shuts off,,wait 15 min and starts and runs for 10 min
Replace the fuel filter and check again, also check fuel pressure and catlic back pressure/tempreature.
Oct 22, 2011 | Cars & Trucks
1999 Pontiac Sunfire ignition lock cylinder changed but car has anti theft and car wont start. How can I get it to start?
try turning the ignition on try to start then without shutting key off wait 10 mins then shut key off then back on but do not try starting leave on for ten mins then back off turn key back on to run but do not try starting it wait ten mins then if it reset it should crank over and start if not repeat all steps again
Sep 19, 2009 | 1999 Pontiac Sunfire
1996 eagle vision over heating
look for leaks on the passenger side!!!! also this car has a "air pocket" you need to find the bleed off screw on the upper hose fitting on the engine and bleed it when filling up with coolant
Sep 18, 2008 | 1997 Eagle Vision
2002 MERCEDEZ CLK 430 Shut off and wont start for atleast 10 mins wait???
is the check engine light on? if so this will lead you in the right direction once you get the code.
Sep 11, 2008 | 2006 Mercedes-Benz CLK 500
Computer keeps shutting off
The problem more likely seems with the power supply or the front power button. Donnot try switch on the computer again and again it may cause damage to the motherboard. Use the following link to pin point the problem.
http://tinyurl.com/5bbrxc
Thanks
Proton
Do remmber to rate the solution if it was helpful or fixed your problem.Thanks for using fixya
Jul 05, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Sony KV32s22
Hi: Sounds like it might be an overheating part, and the short is shutting of the set. Or it could be an intermittent connection in the pc board. Either case it would have to be repaired by a expert.
sorry.
Mar 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
