Rinnai 2001 heater knob stuck
Hi
I have a Rinnai 2001 heater that normally works fine. Last night, the heater wouldn’t light. I turned the ignition knob around and then pressed it down. I could hear the clicking sound that means it's trying to ignite the pilot light but it didn’t light.
I then pressed down harder on the knob and turned it. Now the knob is stuck down and I cannot get it back to the ignition/off position. I can turn it along the temperature range which doesn’t help as I can’t ignite the heater. The knob is obviously stuck lower than it usually is and I can’t get it back up. Can anyone suggest a solution?
Jenny from Melbourne
  • lisa farinosi Oct 31, 2011
    hi jenny.. i have the same problem with my rinnai 2001. did you get an answer or manage to fix it?
    kind regards
    lisa
2 Suggested Answers
  • 48 Answers
SOURCE: Pilot light won't ignite on a Rinnai 2000 1
The trick is that it may take a long time for the flammable portion of the gas to reach the pilot light orifice where the flame lives. This happens a lot when the pilot flame has been out for some time. There won't be a clicking sound as YOU are supposed to provide the flame - it's not like a cooking stove with such conveniences, because the pilot light is only an occasional thing to light it's rare to find an ignition source built in. I'd hate to see you spend good money when all you need to apply here is time and a flame.
Posted on Sep 06, 2009
Testimonial: "thanks - much appreciated Mark"
Clicking noise Rinnai Avenger Gas heater
Is sounds like it could be the automatic ignition. If the sound only happens when you are pressing or turning the knob, I would say that is all that it is. Most gas heaters have an ignition switch under the knob. This triggers the ignition to try and spark. light the gas when the knob is depressed.
Apr 09, 2014 | Rinnai Heating & Cooling
Rinnai RC98i Error 12 - Flame Failure
IF THIS UNIT HAS SPARK IGNITION THE IGNITORS ARE PROBABLY OUT OF ADJUSTMENT WHICH IS LIKE HAVING TO WIDE OF A GAP ON A SPARK PLUG . IF YOU MAKE GAP OF IGNITOR ELECTRODES APPROXIMATELY 1/8TH OF AN INCH APART IT SHOULD LIGHT AS LONG AS YOU ARE GETTING VOLTAGE FROM IGNITION COIL. CALL A SERVICE TECH
Dec 22, 2013 | Rinnai RC98i Tankless Water Heater 9.8 GPM...
What is the significance of the red light at the power on/ combustion indicator? It was flashing last night but not this morning.
the light that indicates power is usualy green then the heater will ignite and burner will light then the light should change to red as heater is on.
Jun 15, 2011 | Rinnai Heating & Cooling
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Charmglow patio heater
Well, I just went out this morning and worked on the heater after it would not light last night. Turns out that a spider or moth set up camp in the pilot light intake housing and plugged up the two small mixer holes that pull in air for the pilot light. This would explain the 'yellow-flame'. I took a punch awl and some compressed air and cleaned out the hole, then re-installed the cover and knob. Lastly, I turned and depressed the knob and the pilot light ignited almost instantly, stayed on when I let the knob up, and the heater turned on normally after that. Good luck, I hope this helps.
Oct 20, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Rinnai 2001 space heater: stuck dial
mine did a similar thing, when in off position, it would only turn to pilot/ignite, but would not move past this point. I took off bottom cover to locate regulator. where the slector knob shaft meets the regulator, try spraying wd40 in the top of regulator where square shaft goes into reg. There is a saftey lock mech in there, and in my case it was stuck in the locked position. I then worked the knob back and fourth applying alot of pressure, but not enough to break the knob. it worked after a few tries, and lights and functions normally, locking again if pilot goes out. good luck.
Jun 05, 2008 | Heating & Cooling
Our heater wont light
your in the wrong section this is airconditions
Mar 27, 2008 | Heating & Cooling
Rinnai EnergySaver 556F Heater flashes
I'm picking up a faint propane scent when the heater is completely turned off. When I turn the heater on it lights fine so I don't suspect it's the pilot light. Is this an issue with the installation of the fuel line, or could it still be the pilot? Any ideas on troubleshooting the source?
Nov 10, 2007 | Rinnai EnergySaver 556 Air Conditioner
Heating & Cooling Logo
268 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
