Motherboard problem. before bootscreen appear it displays verifying DMI pool data. how to disable it? please help.........MCP6P M2+ Ver. 6.x
  • Robin ray Derro
    Robin ray Derro May 30, 2010
    before i load the default setting it doesn't show that word
  • 4,737 Answers
If the system boots up after the verification, there's no problem, it is a built-in bios feature which checks the computer settings/input-output devices/hardwares/softwares,etc.. If there's problem after this, then you should set you Bios settings to default and check if it's helps or not. Let me know if you still have another problem. Good luck. Thanks for using FixYa.
Posted on May 30, 2010
Mcp6p am2+ ver:6.1 problem no beeps and vedeo?
mcp6p am2+ ver:6.1
No beeps or Video means only one thing, the bios went on blank, engineers made a huge mistake and left the bios unprotected and all information is gone, the mother board is a failure. Store For Electronics People who have this kind of motherboards, must buy something different, and never that model again, as it can't be fixed ever.
Dec 23, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
I have no internet connection because i don't have a LAN port driver...can you provide me the drivers for Biostar MCP6P-M2 Motherboard?
Dear kyrios 9205
here what u need
Driver for MCP6P-M2 Ver. 6.x CLICK_DOWNLOAD
And
Driver for MCP6P M2+ Ver. 6.x CLICK DOWNLOAD
Chose 1 for your motherboard model no and download driver match for your windows operating system
hopefully this can help solve your problems..
tq
please leave your ratting........
Oct 26, 2010 | Biostar MCP6P-M2+ Socket AM2+/ GeForce...
Motherboard problem. when i press the power button it displays floppy disk failed and it require to press f1 to continue. how to restore the previous? please help.......MCP6P M2+ Ver. 6.x
Go to bios settings (Press F2 or Delete or as shown there to enter the Bios settings), and locate the "Floppy Seek Boot" and disable it. This will fix your problem. I can't give you specific answer since I am not much familiar with Biostar. But i hope at least this helps. good luck. Thanks for using FixYa.
May 30, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
My Zenith PC displays Verifying DMI pool data . Update Success
Sometimes this can be even simpler. Put in your Windows CD and boot to safe mode command prompt and type fixmbr. This will repair your master boot record for your primary boot harddisk. Eject the windows CD and reboot and see if it fixes your problem.
Sep 02, 2009 | Computers & Internet
Acer desktop T180 is stuck on verifying DMI pool DATA..
verifying DMI( Data Migration Information/or Dynamic Migration Information) pool data refers to hard disk function. check the hard drive to see if it functioning properly.
Jul 12, 2009 | Acer Aspire T310 PC Desktop
MCP6P-M2 v6 not working?
u should change the ram and try again.
Jan 16, 2009 | Biostar MCP6P-M2 Motherboard - v6.0,...
Cant boot pc
hi i have put together a pc but when i power it up it say soft menue has changed and then says verifying dmi pool data pls can anyone help thanks
Sep 04, 2008 | Intel Motherboard
Frezes at verifying DMI settings. Already changed MB and Power supply. Lan connection only flashes green once in a while should be constant. Tried on a working terminal and does the same.
The Desktop Management Interface (DMI) is a new
method of managing computers in an enterprise. The
main component of DMI is the Management Information
Format Database, or MIFD (the DMI Pool Data). This
database contains all the information about the
computing system and its components.
At times, some systems may experience hang
conditions after partitioning, formatting and initial
bootup of a hard drive. The message, "Verifying DMI
Pool Data" appears and the system hangs. This
condition may continue after the drive has been
removed.
! WARNING ! ALL SUGGESTIONS LISTED IN THIS
INFORMATION BULLETIN ARE BIOS RELATED. FOR
A PERMANENT SOLUTION, MAXTOR RECOMMENDS
THAT USERS CONSULT THEIR SYSTEM OR
MOTHERBOARD MANUFACTURER FOR BIOS
UPGRADES.
Suggestions to Resolve the Condition:
1.Apply power to the computer.
2.Access the system BIOS.
Set the drive type as None or Not Installed.
Load BIOS Defaults
Load SETUP Defaults
3.Save the BIOS changes and reboot the PC to a
System Boot Diskette.
4.Shut down the PC after the memory count is
displayed.
5.Reconnect the power and interface cables to the
hard drive.
6.Access the System BIOS.
7.Auto-Detect the hard drive. Ensure that the LBA
Mode option is enabled.
8.Save the BIOS changes and boot the PC with a
System Diskette.
9.Partition and format the hard drive via the
operating system.
10.Reboot the system. On bootup, the screen should
read:
Verifying DMI Pool Data
Update Successful
The system should continue booting normally.
Other Possible Solutions:
2.Access the System BIOS.
3.Disable both the Internal and External CPU Cache.
These features are located in either the "BIOS
Features" or "Advanced Settings" options of the
BIOS Setup.
NOTE: Consult the System or Motherboard User's
Manual for exact location of the Internal and
External CPU Cache settings.
4.Save the BIOS changes and reboot the PC to a
System Boot Diskette. On bootup, the screen
should read:
Update Successful
5.After the system successfully boots, re-start the
PC and access the system BIOS.
6.Enable the External CPU Cache. This feature is
located in the "BIOS Features" or "Advanced
Settings".
Manual for exact location of the External CPU
Cache setting.
! WARNING ! User's MUST re-enable this feature
for optimal system performance.
7.Save the BIOS changes and reboot the PC to a
should read:
Update Successful
NOTE: If the aforementioned suggestions fail to
resolve the issue, contact the system or motherboard
manufacturer to:
Remove the "Clear CMOS" Jumper and reset the
system BIOS
Obtain a Flash BIOS Upgrade
from pc help;
SYSTEM HANGS AT MESSAGE: "VERIFYING DMA POOL DATA":
You did not say what operating system you are running but I assume Windows 95 or 98. It is possible some Windows
system files are corrupted or perhaps the system doesn't like your ram (if you added or installed ram recently). There
is also a possibility that there is something wrong with your BIOS and you *may* have to update it, but I would avoid
doing that if at all possible.
A quick fix - if the problem is software related - is to:
1. boot to a Windows startup disk (one that matches your operating system). this step assumes that your PC is setup
to boot to the A: drive before the C: drive (via the BIOS SETUP program). If you don't have a Windows startup disk,
you will have to make one on another person's computer that has the same version of Windows. You make one via:
my_computer/control_panel/add_remove_programs/startup_disk
2. run "scandisk c:" to make sure that any file corruption is fixed before going to next step
3. do a "sys c:" from the "a:" prompt to transfer a good copy of Windows system files to c: drive
4. remove the boot floppy, reboot the system and see if all is well.
If that does not solve the problem you may have to reinstall Windows 95/98. Ouch!
I recently had someone bring me a computer that had this DMI error message problem and I tried the "sys c:" method
(with the startup disk) without success and had to entirely reinstall windows 95 (and almost all applications except for
some programs that did not need to be placed in any Program Files directory or other special location) to cure the
problem. However nasty a job that is, it did cure the problem.
Jun 23, 2008 | Computers & Internet
Computers & Internet Logo
186 people viewed this question
David Payne
David Payne
