Question about Hayward SAND FILTER, PRO SERIES
I purchased a used Hayward S160T sand filter, the Keycover and handle assembly was not on, I'm having a hard time figuring out how to line it up properly, I thought I had it right but when on filter water comes out of the waste line. Help
  • 4,924 Answers
Http://www.poolcenter.com/parts_filter_Hayward_S160T.htm
Hello ..see if this simple schematic is for any help ...I guess you do not need much but an Idea and this is the exact thing this will do ...
If not let me know and I will look for a much more detailed to see if i find>>
Posted on May 30, 2010
Model SW 256T Swim Pro broken handle - cannot turn to different settings. Can the handle be replaced separately or will I have to replace the entire port?
You can replace the Key Cover Assembly , part # SPX0714BA
You will also want to purchase an o-ring for it, part # SPX0714L
Jun 01, 2014 | Hayward SAND FILTER, PRO SERIES
Hayward 220T pool filter is leaking water; could it be the multi-port valve needs to be replaced?
if coming out of top where handle is yes if out backwash line yes make sure unions are tight also
Dec 30, 2013 | Hayward SAND FILTER, PRO SERIES
I bought my above ground swimming pool package in 1990. My Hayward sand filter is a top mount and has a lateral assembly w/center pipe in side of it. The pipe is broken at the top and I need to purchase a...
I believe that the owners manual has a parts listing to help you distinguish the part that you will need to buy. However, if your pool filter was purchased in 1990, you are probably going to need a new filter. Most do not last over 20 years.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 01, 2010 | Hayward SAND FILTER, PRO SERIES
I have put my hayward 710 multiport valve assembly back together and need to figure out how to put the handle back on. The handle has a pin assembly and does not seem to fit once everything is assembled....
Place valve on ground, sit in chair and place feet on top of valve. Press down evenly and the spring will compress. Insert pin in one side of handle then tap in lightly with hammer until even.
How to replace the havyward key/seal assembly
remove the screw holding the top to the body of the valve. Tap the pin out that holds the key assembly into the top. Note the direction of the handle to the key assembly before you do so...it matters how you align the new one.
Usually you reuse the spacer and o-ring on the old stem or else just install all your new parts. The hard part is compressing the top while leaving room to reinstall the pin. I use a vice and a big pair of channel locks and do it myself. Otherwise get someone to help you hold it compressed enough to punch in the pin and your all done.
Dec 12, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward filter problem
YOUR HANDLE IS NOT SEATING IN THE RIGHT POSITION THERE IS A SPROCKET UNDER HANDLE THAT MAY BE DAMAGED TRYSETTING HANDLE TO DIFFERENT POSITIONS SEVERAL TIMES IT MAY HAVE DEBRIS UNDER IT MAKE SURE PUMP IS OFF.TAKE HANDLE ASSEMBLY OFF AND CHECK SPOCKET
Aug 04, 2009 | Hayward SAND FILTER, PRO SERIES
We have found sand in the bottom of our inground pool we have a hayward pool sand filter what could be the reason
have you added sand to filter if so may be to much make sure that handle is in the right position check by changing setting several times to make sure sprocket under handle is not damaged sounds likeit is not seated
Jul 14, 2009 | Hayward SAND FILTER, PRO SERIES
When i turn y pup on, the filter almost seems to
you have a problem with top valve on filter check to see if sprocket is not seated right you have to remove handle assembly to see sprocket
Jul 06, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
169 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
