Question about Microwave Ovens
I have a grind & brew coffee maker and the grinder is not working.
    President:
  • 1,561 Answers
The problem might be that the motor on the grinder is bad or hang, you will need to disassemble the grinder in other to see if there is nothing blocking the motor of the grinder to spin, if after the check and nothing is blocking the motor, you can drop a comment so that i can further suggest what can be done.
Take care,.
Posted on Jun 07, 2010
  • Sulaimon Jimoh Olayemi Jun 07, 2010
    Turn the garbage disposal on and off quickly and check to
    see if it has
    power. If it hums, the power is on. Move on
    to step 3. If it doesn't hum, it may have overheated and tripped a
    circuit breaker. Move on to step 2.
    Restore power to the machine.
    Most disposals have an overload switch
    that trips when the motor starts to overheat. To reset the switch, look
    for a small red button on the bottom of the housing, and if it's there,
    push it in. If your disposal doesn't have an overload switch or
    the machine still won't run after you reset the switch, reset the
    circuit breaker that serves the disposal.
    Clear the jam from
    underneath. On many disposals, you can insert a
    1/4-inch (6-mm) Allen (hex) wrench into the bottom of the housing and
    manually move the motor shaft and flywheel to dislodge the jam. If your
    disposal has an opening for an Allen (hex) wrench, insert the wrench and
    move it back and forth until the motor and flywheel turn freely.
    Press
    the end of a short broomstick against one of the impellers, and
    jab in one direction and then the other until it breaks loose.
    This
    should fix the problem.
    Take care.
Grinder appears to be grinding, but not ground coffee ends up in the basket. Metal door underneath the grinder is closed.
Empty grinder and chek nothing is stucking to the opening plate If not then replace the solenoid that open the shuter from where the coffee go to grinding chamber Thanks Please rate my work
Sep 06, 2011 | Microwave Ovens
Farberware superfast coffeemaker--how to i stop coffee grains getting into the brewed coffee?
Use a paper filter.
Place the filter under the coffee to be brewed. That will let the coffee through without the grinds.
Jan 09, 2011 | Microwave Ovens
We are trying to set up the hamiliton beach brew station 6 cup but do not have the manual. can you walk me threw it please?
Sure Thing :)
1) Open the lid
2) Take out the filter basket.
3) Take out the Coffee Tank and fill it with water to the appropriate mark at the back of it. (Should be a stepped type marker)
4) Pour the water from the Coffee Tank into the Water Reservoir in the coffee maker it's self. (This should be on the left side of the metal warming plate.
5) Place the Coffee Tank back on the brew station.
6) Place the Filter Basket back in the coffee maker
7) Add a coffee Filter and 5 Tablespoons of coffee
8) Close the lid
9) Press the Brew/Start button (The top left one)
Jan 08, 2011 | Hamilton Beach Microwave Ovens
After grinding coffee,can you submerse in water to clean
No!!! You can clean the cup that the coffee goes into, but do not get the grinder in the water...
heatman101
Nov 25, 2010 | Microwave Ovens
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Feb 10, 2010 | Microwave Ovens
Kenmore Microwave / coffee maker leak
I have a Kenmore Microwave with built int coffee maker (Model 721.63999303). The coffee maker works, but the microwave doe not. Can the microwave be fixed ?
Apr 12, 2008 | Kenmore 63993 Microwave Oven
Microwave Ovens Logo
26 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
