Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas
I have a Teledyne Laars Lite pool heater Model LLD 250N. When I turn the heater on it will run for 10 minutes and turn off. If I turn the power switch off and right back on it will run agin for 10 minutes and shut off.
  • 640 Answers
It sounds like your pool heater might have a defective controller (the part, not you). Check the controller and replace if necessary. It could also be that you need to cycle the ignition sequence until the air is out of the gas line. It could also possibly be that your gas valve needs to be replaced.
Posted on Aug 12, 2010
How turn on pilot on teledyne laars series 2
turn gas valve to pilot hold down for 1 minute keep holdibg and light pilot hold for 2 minutes then turn to on
May 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Gas pool heater model no.lg125p laars lite 2 max.gas preesure 14.
should be between 9 and 10 on front side manifold side should be 3.5
Feb 10, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Heater runs about 40 min then shuts down . replaced water temp sensor and it still shuts down
make sure it is a propane heater propane burns hotter than gas if not correct heater it will overheat if ok check gas pressure if not enough heater will overheat you also might have too small gas line and are emptying it
Oct 10, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool heater kicks on and off
safety switch is opening and closing, or issue with gas valve coils
Sep 17, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a larrs lite lld 400 n it heats up but it doesnt get hot enough
if you have a bypass made of plumbing only open 1/2 way if you don't have one put one in if you slow the water down it will heat more per pass
Sep 18, 2010 | Teledyne Laars Laars Lx Pool Heater /...
I have a Laars Lite model LLD 250N 250,000 btu heater that will not light automatically. I hear this gas valve open and I can light the burner with a match. I have replaced the glow plug and it still does...
Have you checked the power tot he ignition control? If you post the model number of the ignition control I can provide you with specific troubleshooting charts for your specific unit.
Aug 03, 2009 | Pool & Spa
Laars Teledyne Pool heater flames on for 2 seconds, shuts off
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
May 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
pull out flame sensor and clean with sand paper or emmoring cloth then try again should work (small black wire with sensor sitting above burners)
May 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas  Logo
455 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
