Question about Goldstar DH304 Dehumidifier
It starts with control set to max and it runs a couple of minutes and it stops so i turn the control to low and back to max it starts again and stops the same way the humidity is at 60+ so it should stay any info would be appreciated thks
    President:
  • 2,468 Answers
One of 3 possible problems,the control is faulty,you can bypass this with a jumper wire and see if it stays running, the condenser coil is dirty and is not cooling the compressor correctly and the condenser and evaporator coils need to be cleaned,i would do this first before bypassing the control,then possibly its low on refrigerant and the low pressure switch is shutting it down or the switch itself is faulty,please rate this if it helped you,thank you
Posted on May 30, 2010
  • dempseyjosh Oct 06, 2010
    I took mine apart to see if there was anything obviously wrong before I came to the internet for help. I saw this that the control could be faulty, so I unplugged that, and it runs. I assume it will just run continuously until I put a new one in??
  • Drybaby1 Feb 03, 2011
    I posted my problem/fix but not sure where it ended up. I am pretty sure it is the on/off switch as I moved the wires to the #1 and #3 poles and now it runs constantly. I have to have it running because the water heater blew out its tank indicator and flooded the basement with 300 gals of water. After sumping/dry-vac'ing, I need the dehumidifier to work! And it does. It has run great for the past 36 hours. In the Spring I will install a new 50k switch.
Why does compressor continue running, even with dehumidifier turned off?
Hello Bernard, thank you for your post!
I see that you are experiencing an issue with the Frigidaire dehumidifier, FAD704DWD, compressor consistently being on. This could be a possible issue with your control panel or sensor. Since it could be any one of these underlying issues I would suggest contacting the manufacturer for further assistance. Hopefully this information is helpful to you. -Matt
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
It runs 5 to 10 minutes, then it stops. When I press the remote control boton, it works again for 5 to 10 minutes and then it stops. So I need to repress the remote control again to make it starts.
I guess you are having a problem. That model dehumidifier doesn't have a remote control. As a matter of fact, I'm not aware of any model dehumidifier that has a remote control. A remote would be useless. Now, some portable air conditioners have remote controls. Is that what you have? A portable A/C unit? Please advise. Thanks.
May 26, 2011 | Danby DDR2509EE Dehumidifier
How do i check if its working correctly
If you want to give it the ultimate in-home test. Put the dehumidifier in the bathroom with the door closed and a hot shower running, but do not turn on the bathroom exhaust fan. Set the dehumidifier's controls as low as possible and let it run for 20 minutes. After 20 minutes, return to the bathroom, turn the shower OFF and check the water collection bucket for water. The unit will probably be running anyway, when you return to the bathroom.
Remember, the lower the setting, the more the unit will run and collect water. Until it either reaches the humidity level you have it set for or the bucket is full and the unit automatically turns OFF
That's the best way to test a dehumidifier at home. Hope it helps you.
Please let me know.
May 16, 2011 | Maytag M7DH45B2A Dehumidifier
My Santa Fe compact dehumidifier in my crawlspace makes a noise (not a smooth humming sound but more of a harsh vibrating sound) when it is not dehumidifying. I can turn the knob to the dryest setting and...
The black cylinder is the compressor. It sounds like your unit is cycling the compressor for some reason. If the compressor starts, runs fine, and removes water when you set the humidity control to the driest setting the compressor is probably OK and the problem may be with the humidity control causing the dehumidifier to "short cycle" for some reason. You may need to change the humidity control or relocate the dehumidifier in your crawl space.
If the compressor attempts to start, and then sits quiet for 10 minutes, and then attempts to start again, you have a problem with the dehumidifier. There are a few things that can cause this problem:
Low refrigerant charge
Bad compressor capacitor
Bad compressor overload
Plugged capillary tube or broken expansion valve
are the common causes of this behavior. If you suspect one of these problems, call the factory service department at 1-800-533-7533 for help.
Good luck with your dehumidiifer.
Jan 11, 2011 | Santa Fe Advance Pre-Filter Dehumidifier
Zenith ZD30 dehumidifier - 1 1/2 years old stopped working had a half bucket oc colledted water in bucket when it stopped. I checked the fuse on the circuit board and have continuity.
Unplug from wall. Take the front cover off and disconnect the 2 wires that attach to the humidity control dial. Plug back in. If it works, the problem is the humidty control dial (mine just went bad). With it unhooked, it will run constantly, but will still turn off when the bucket is full. To turn off, simply unplug.
Jun 16, 2010 | Dehumidifiers
Signs of a bad compressor or condenser
plug this unit into a receptacle with a lamp also in the recept. unit will try to start the lamp will dim for a couple seconds and go back bright unit wont start maybe fan but no comp. sit and watch a few minutes later lamp will go dim again then back to bright, this is a classic low tech way of confirming the comp is trying but not working possible bad run capacitor, much cheaper than new unit
Aug 11, 2009 | Fedders A7DH65B2A Dehumidifier
Dehumidifier
IS THE ROOM HUMIDITY LOW. IF IT IS BELOW 30% THE HUMIDISTAT WILL SHUT DOWN THE UNIT. THE AMMBIENT TEMP SHOULD BE ABOVE 65 DEGREES AND THE HUMIDITY SHOULD BE ABOVE 50 %.
Mar 26, 2008 | Kenmore 53301 Dehumidifier
Fan runs all the time
I HAVE HAD A COUPLE OF UNITS THAT HAVE KEPT THE FAN RUNNING ALL THE TIME. I REPLACED THE CONTROL AND THAT TOOK CARE OF THE PROBLEM.
Mar 09, 2008 | Whirlpool AD70USS Dehumidifier
Compressor won't run
the over-current relay is tripping out the compressor motor to prevent excessive current through motor windings. To prove this theory, open unit, find motor wires, disconnect wires from unit, and apply 120VAC to motor using external circuit-breaker source. Run 2 minutes max. If motor continuously turns, then relay is failing. Find it by tracing wires back to source and finding a small rectangular item. If motor again quits after 2 seconds, then this motor has an internal over-current self-resetting fuse that may be doing its job of preventing an electrical overload from a dead (shorted) motor.
Jul 07, 2007 | Whirlpool AD40USR Dehumidifier
Runs for a couple of minutes and then stops
Try cleaning out the air filter using cold water. I did not even know the unit had one until I had the same problem. Pull out the bucket. The filter is located where the front top edge of the bucket would be located if it were in the instrument. Remove it by pulling straight down. It may be taped to the instrument for shipping purposes. According to the manual, this should be done every month. I have had the machine since Katrina and this is the first time I have had a problem. Hope this helps.
Apr 23, 2007 | Kenmore 54351 Dehumidifier
Goldstar DH304 Dehumidifier Logo
529 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Jerry Greenberg
Jerry Greenberg
Dan Webster
Dan Webster
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
