Question about Harley Davidson 426290 AM/FM Radio
Unplug radio unit from harness will not power back up 2003 classic
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Harley Davidson Expert
  • 281 Answers
Contact these guys...www.radiosound.com
Posted on Jun 05, 2010
2003 harley davidson electra glide classic cut,s off when playing cd and cool,s down and stsrt up againn
I presume you mean the radio/cd cuts out and not the engine. I also presume you are not letting the bike idle away as you listen to music! If you are, then the bike is over heating and piston seizure is the causing it to stop. Now, if it is just the radio/cd unit cutting out, the radio/cd unit has developed a thermal fault that requires specialist attention. Nothing you can do.
May 28, 2014 | 2003 Harley Davidson FLHTCUI Electra Glide...
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
How to replace the radio on a 2004 harley davidson electra glide
Remove the outer fairing. Unplug the wiring harness from the back of the radio. Undo the 2 screws on each side of the radio. Pull it out.
Jun 13, 2012 | 2004 Harley Davidson FLHTCUI Electra Glide...
I have a 2003 toyota camry and all of a sudden the radio just died. i have checked all the fuses is it possible that the radio just is no good?
it is possible the radio is dead, the best way to check it is to pull the radio out and unplug the wiring harness connector to the radio and using a test light with the ignition in the on position, check to see if there is power coming out of the wire. If there isn't, the radio is not good.
Apr 29, 2011 | 2003 Toyota Camry
Up grade radio on my electra glide classic
yes because you will have to run wires from the front to the back for the speakers unless your really good at wiring
Jul 27, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
I am hard wiring a radio into a 2003 hyundai sonata and i need to know what each wiring coming out of the car does
Radio 12v orange + radio harness Radio Ground black/orange - radio harness Radio Ignition yellow + radio harness Radio Illumination brown/white + radio harness Factory Amp Turn-on lt. green + radio harness Power Antenna gray + radio harness LF Speaker +/- tan - black +,- radio harness Notes: If equipped, the amplifier is in the passenger side of the trunk. RF Speaker +/- blue - red +,- radio harness LR Speaker +/- white - brown +,- radio harness RR Speaker +/- orange - green +,- radio harness
Jul 15, 2009 | Car Audio & Video
2003 grand am radio light out however radio works fine what is problem
Most likely their is a loose connection in the radio harness. One of the wires in this harness sends power to the back light on the radio. It has become loose or disconnected. Assuming no other lights are out and nobody has been cutting wires to install an aftermarket radio. If other lights are not working then check your fuses.
Jun 16, 2009 | 2003 Pontiac Grand Am
Wiring diagram for tourpak on 2003 Harley Road King Ultra Classic
hey first off harley has a harness that will plug in the accessory outlet under the seat, now to the speakers you didnt say if you had a stero or what, now you would run speaker wire from the source to the speakers you can get the male portion (i believe)of the plug at the hd shop or just go to radio shack and get plugs(male-female) there and just soilder them shrink tube the connection hope this helps
Nov 30, 2008 | 2003 Harley Davidson FLHRCI Road King...
Radio codes
Battery WHITE/YELLOW (+) RADIO HARNESS
Accesory WHITE/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Dimmer RED (-) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
Amp Turn On YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) WHITE
LF Speaker (-) ORANGE
RF Speaker (+) YELLOW
RF Speaker (-) BROWN
LR Speaker (+) RED
LR Speaker (-) GREEN
RR Speaker (+) BLUE
RR Speaker (-) BLACK
Oct 18, 2008 | 2003 Chevrolet Silverado 1500
Harley Davidson 426290 AM/FM Radio Logo
53 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
Jim Goldsmith
Jim Goldsmith
Stephen Burdy
Level 1 Expert
xxxxxx xxx
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
