Question about Ariston Technologies L63SNA Stainless Steel Built-in Dishwasher
Code A13 on Ariston dishwasher
Our dishwasher all of a sudden stopped 11 min. before the end of the cycle. The display show code A13. We tried first with resetting but nothing works.
  • Anonymous Mar 17, 2009
    My machine had the same problem, after a wile it will stuck with a13 code as soon as you turn the machine on.
    The first time it happen it was the motor, (warranti) now it is happening th 2nd time .
    I will not make any commnets on this, maybe its bad luck.
SOURCE:
  • 56 Answers
SOURCE: A13 error code
It seems to me that there isn't any problem with the normal washing cycle. The problem you have could be related to your dishwasher's detergant dispenser lid. I reckon that the relevant part isn't functioning normally. You can simply check out the claws placed on the detergant lid. If there is a spring inside, it might be damaged.
Posted on Apr 16, 2007
  • 883 Answers
SOURCE: my dishwasher trips out on certain cycles
sounds like faulty wiring inside unit. your circuit breaker is detecting an overload current condition...must look inside for wire touching frame. if none found, then wire fault may be inside of a device like motor or solenoid, so check these with ohmeter to ground-each wire (except chassis gnd) must be isolated from ground.
Posted on Jun 05, 2007
  • 190 Answers
SOURCE: My Ariston LI 700 I dishwasher doesn't complete wash cycle
dear customer,
 we recommend u to perform the following checks on ur dishwasher,
  1. Test the timer motor
  2. Test the thermostat
  3. Test the heating element
for more details for self test instructions try the link http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Plz rate this solution.. thank you..
Posted on Apr 08, 2009
BIKER T
  • 909 Answers
SOURCE: my Ariston L63 has a problem at start of cycle
Looks like the main dishwasher motor is jambed. Need ro gain access to motor then move the vanes at the back untill motor turns freely. Retry.
Posted on Oct 23, 2009
  • 6 Answers
SOURCE: Ariston L63 dishwasher stopped mid cycle with water in base.
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
Posted on Jan 14, 2010
Ariston dishwasher flashing code a13
http://salvationarmynaples.net/readpdf/ariston-dishwasher-manual-l64.pdf
http://manualslibrary.net/ARISTON-DISHWASHER-MANUAL-OPERATION.html
These are the sites for two manuals on your machine. They are free downloads that can be read by any computer. I'm sure there is a code list in there somewhere.
Dec 10, 2016 | Dishwashers
Error code E:14 Siemens Dishwasher - stops after 1 min of cycle
It might be helpful if you provide the full model number of the Siemens dishwasher. Most likely E14 error has something to do with water flow sensing. Check if your mains water pressure is ok (tap under sink is fully open). But can provide more details only if you can tell me the model number.
Apr 03, 2014 | Siemens Dishwashers
Hello What does the error code A13 represent. The soap dispenser seems Ok. Could it be related to something else. The machine starts up Ok, but about 6 seconds into a cycle A13 flashes up and the...
As you correctly pointed out A13 error is linked to the failure of the detergent dispenser lid operation.
If the lid is not opening at the correct time in the wash cycle, then the detergent will not be getting dispensed.
Either the controller circuit that operates the lid is faulty or the lid solenoid is faulty.
You can check the parts at this site.
Mar 20, 2011 | Indesit 24 in. DE73 Evolution...
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
together, (e.g./ “6” = faults 2 + 4).
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
A13 error code
Apr 16, 2007 | Indesit 24 in. DE73 Evolution...
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Ariston Technologies L63SNA Stainless Steel Built-in Dishwasher Logo
423 people viewed this question
Top Ariston Technologies Dishwashers Experts
Steve Allison
Steve Allison
Ekse
Evan Benson
Evan Benson
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
