Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Protection when in its on television like to protect. red light it appears that the green light should
tech48
  • 624 Answers
SOURCE: no response from amp
They go into protect for several reasons. Unless you are a trained technician you should not try to repair it yourself. It may have a blown channel. Disconnect the speakers and try turing it on again. If it still goes into protect you have a serious problem. If it does not go into protect, you may just have a bad speaker, or have the impeadance too low for that amp. The smartest thing to do would be to take it to a repair center and have them test it to find out if the problem is in the amp or in the wiring/speakers.
Posted on Jun 16, 2008
blueextc3221
  • 15935 Answers
SOURCE: sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
Posted on Jan 02, 2009
  • 69 Answers
SOURCE: Protection Light Comes on
Sounds like you have an ohm problem, Tryy hooking the positive from one speaker to the negative on the other speaker. Then hook the negative from the first speaker to the negative on your amp and the positive from the second to the positive on the amp this will drop your ohm load and the amp should stop going into protection.
Posted on Mar 10, 2009
  • 3 Answers
SOURCE: red light
no i think the subs are blown because subs blown send transitor sound back to the amp
Posted on Apr 17, 2009
etirbynnor
  • 655 Answers
SOURCE: red protection light wont turn 2 green no matter
Hello mcis43fan,
The protection circuit can be activated by shorted or grounded wiring or it can be caused by a defect in the amp itself.
First, disconnect all wires except power, ground and the remote turn-on lead and see if the amp powers up normally. If it still goes into protection, the amp is defective, most likely shorted outputs and needs repair or replacement. If the amp powers up normally, test the other wiring for shorts and grounds. You can reconnect them one at a time to determine which one is causing the problem.
Hope this helps.
Posted on Aug 06, 2009
Testimonial: "i found that the amp has a problem internally "
Should the interex surge protector have both red and green light?
the red may indicate a surge controlled but will no longer protect the equipment
most surge protection is only good for one hit and that fails the protection for more surges
read the user manual on it or go to a retailer and read the instructions on a new unit
Oct 25, 2016 | Televison & Video
Hitachi 42hds69 green light does not go on
Protection mode, either PSU failing on caps or transistors, defective AV board, or dead inverter.
Jan 16, 2013 | Hitachi 42HDS69 42 in. Plasma Television
HITACHI TV 50XU53K DEAD SHUTDOWN RED PROTECT LT BLINKS
Do any of the green led lights in the set come on?---red one should be on all the time--blinking would indicate a problem in the power supply at the primary side (INPUT).
May 21, 2012 | Hitachi Televison & Video
Xplod XM-554ZR Car Audio Amplifier: powr/protect light comes on red not green...
Hi, disconnect all speakers from unit and try again - if red light still shows then your amp has died.
If the light goes green, then start testing for shorted speaker/wiring. This includes speaker wiring to vehicle shorts - there should be an o/c reading on your meter
May 05, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Mar 03, 2010 | Hitachi 60SDX88B 60" Rear Projection...
Hi when the tv button is pressed a green light appears without a picture and then goes back to red standbye light. thank you
Hi! your television is on safe mode or on protect. have your unit checked by a qualified service technician. if your not technically inclined in electronics.
Sep 05, 2009 | Televison & Video
My t v will turn on, the light will be Red, then Green ,then
your tv in protection mode some thing wrong inside tv.mostly power card defective.
Jun 28, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Protect led light
It appears that the amp is going into protect mode. To eliminate external causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 10, 2008 | Car Audio & Video
How to change the Red Protect light to Green Power.
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Sep 21, 2008 | Audiofonics ADF-240 Car Audio Amplifier
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
55 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
