Question about Coleman Roadtrip Grill LXE 9949-750
How do I connect the propane to the grill? - Coleman Roadtrip Grill LXE 9949-750
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
If it uses the little one pound green gas cylinders they normally push and click on the gas inlet and stay in place due to two small little metal pressure bands which release when you pull the gas cylinder back off. make sure its in the off position when you are putting it on. good luck.
Posted on May 30, 2010
2 Suggested Answers
  • 68 Answers
SOURCE: Can use gas for my liquid porpane grill
Yes you can as long as your home uses LPG. You can not use 2 regulators. If your outside line is after your home regulator you need to eliminate the regulator on your grill. LPG products operate on 11" of water column, that's about 1/2" PSI.
Thanks for using Fixya
Jerry
Posted on Mar 30, 2009
I have a Kenmore 14116329 propane grill. The propane tank is full but when I turn on the burners very little gas comes out resulting in a VERY low flame. Is it the regulator or???
It is most likely the saftey check valve in the tank. The procedure is to:
  • Close tank valve.
  • Disconnect hose connection from grill to tank.
  • Wait
  • Reconnect hose connection from grill to tank
  • "Slowly" open valve on tank to release gas back into grill
Through on some steaks
If still a problem replace tank.
The check valve that can cause your problem drastically reduces propane flow in case of an accident and the lines are ruptured
Hope this helps?
Jul 03, 2017 | Kenmore Grilling
Why wont my old grill work with new propane tank
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 13, 2014 | Weber Q Grill
Where can I find a replacement oring for the regulator end that screws into the grill
Your local propane supplier. They are made of a special material so that propane won't react with it.
Jul 12, 2014 | Coleman Roadtrip Grill LXE 9949-750
Grill isn't flowing propane when tank is on. No smell of propane and starter is clicking. Tested 3 tanks on grill and no luck. Tested same tanks on another grill and they work fine so it's the
it could be the reg or a blockage in the line or open the taps on the grill then close them reconnect gas tank open slowly then tis if there is gas to grill
Mar 16, 2012 | Barbeques Galore Turbo STS 3-Burner...
I'm going to hook up the grill to our house propane gas line and not use a propane tank. Will I need a special hook up device? Where is the connection on the grill? Thank you. Frank...
Yes Frank, you will need some specialty parts. The gas line from your tank will need a shut off valve near the grill. You cannot hard pipe the line to the grill. Code requires that your use a 12' long, rubber, Quick Disconnect Gas Hose. They are normally sold as a kit and should have all the necessary fittings. You will need to remove the grill's hose/regulator assembly, as it won't be necessary any more. That is, unless you have a high pressure propane system. Then you will need a regulator on the gas line coming from the tank to the grill. If that is the case, it should have the capacity to carry the maximum Btu output of your grill, if all the burners where ON and at their highest setting, at the same time. And finally, and probably the most important, have the knowledge and skill necessary to properly hookup an outdoor gas appliance. Or have a good friend that is a Certified Gas Technician to help you. Of course, your propane provider would probably do it for you. Which, might be money well spent.
Hope it all works out for you and Happy Grilling!!
Apr 27, 2011 | Weber Summit E-420 Propane Grill
New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Apr 15, 2010 | Weber Spirit? E-310 Propane Grill
We received a natural gas connection bbq and don't have access to gas...is it possible to convert to propane tank connector.
no all components of grill need to be converted to propane. cheaper to buy new grill. Call Manufacture and see if they sell conversion kit. Most companies don't do to liability matters,
Mar 28, 2010 | BBQ Guys BBQ400C/G42 Grill
Jerry
Mar 30, 2009 | Frigidaire FD26LPDC (LP) Grill
Propane tank
yes, you need to buy an accessory cord that connects your tank to the regulator
Jul 03, 2008 | Coleman Roadtrip Grill LXE 9949-750
Coleman Roadtrip Grill LXE 9949-750 Logo
478 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
