Question about Philips 50PF7220A Television
50PF9630A/37 philips plasma tv shut off, wont come back blinking red lite has 2 capacitors slightly bulged on center board (sidexside) all fuses still good.. tv has real low hours no abuse is second of 2 from b est buy Both bad right out of box gotta fix it best **** wont honor their own contract can fix the two caps, but something caused them to blow need to fix everything. have it open on bench but dont have experiance please help!!!
  • bcadk60 May 30, 2010
    first sol will help but i need more info about possible cause or any cautions about workin on this tv i can do the work but lack a scope and more testing eqp only have multi testers and thats it im sure things like the power cord are not the solution to this the ac imput jack shows 120 v at the board so its gettin the juice unless its suposed to be dif thanks let me know anything plz
    great imput feel hopeful that i can resolve a long term pain will post results
    thanks
    \Scully
  • Philips Master
  • 11,800 Answers
Yes, you will gonna have to replace the defective capacitors. No special skills required, all you need to do is to remove them, find identical replacements and solder them back in.
Why did they failed so fast? The usual cause is overheating - make sure the tv's have plenty of free space around them. Also make sure the power coming to that tv is clean - parasites coming thru the wall socket can easily damage the power souce of a tv. If you live near a place where heavy machinery running on electricity is used an line protector is mandatory.
The second cause of failure is that you bought a dud - a cheap product that was build cheaply, with low quality components. Since this is a BB device(which they have refused to support) i personally lean toward that as being the cause.
Posted on May 30, 2010
  • Azrael SRL May 30, 2010
    Yes, the mains voltage is ok but if you have a good multimeter capable of displaying the peak value you should check that the peak value is less than 200V , otherwise there's a very high risk of failure for the main line capacitors due to overstress (in the country it happens more often than you think).
    Once you have replaced the capacitor all you need to do is to check the voltages - if some are lower or even off then check the power transistor and the stabilizers. All you need for that is a decent multimeter.
    hey
    thank u very much i appreciate your imput hoping thatthose caps r all should be fairly simple all components look easy to remove (much easier than my a-4 jet was) got good multi t wish i had a scope top notch to u and your fellow guru ill give this a try
    ever need to know anything about avionics hard or soft im updated through 2008 including vib tic and virtual fly have 4000+ pic hrs for good measure
    thanks
    Scully
I have a Philips Plasma TV that is having a problem when turning the power on. A blinking red comes and after un-pluging and re-pluging a number of times it finally works. Does anyone know a trustworthy repairperson in Toronto, Canada?
Posted on Jun 13, 2010
  • Philips Master
  • 5,807 Answers
Hi
bcadk60,
Servicing the unit will be more
easier if done , with the
right equipment, tools and a service manual .
Service Manual can be found here:
42PF9630A/37 Service Manual
https://www.completeservicemanuals.com/Philips/Magnavox/Plasma-Television/42PF9630A/37-Service-Manual/prod_614.html
only with a fee.
here is a snapshot :
50PF9630A/37 philips plasma tv - 38bc70e.jpg
Once you have it, Verify which board are bad one by one.
How to solder boards properly
How to test for Continuity
How to use a multimeter
Hope these helps,
Let me know , if you need further assistance , once you
restarted probing around.
Regards,
palaboy
Posted on May 31, 2010
  • 2,335 Answers
I'd like to help you with your Philips Plasma TV situation.
I am not the guy to walk you through servicing your TV, but I am the guy who can source you the Service Manual for your unit & the relevant SDI PDP Repair Manual. (Just click free when you follow those links; they are too big to be hosted here at FixYa.)
Please follow the safety precautions!
And don't give up harassing who you bought it from - if it has a warranty contract on it, they don't get the right to choose whether to honor it or not.
I hope that helps.
  • 1 more comment
    thanks i appreciate the help u would b suprised at what we've gotten from the retailer
    they have just mety my lawyer ha they wont like little stone county MO anyway i want to ask if u have any other feed back on the possible cause of this problem why did the cabs blow and is there any other obvious things i can test or look for while i've gort thisw thing on the bench? thanks
    Bryan
    ps im an avionics eng. retired naval aviator this plasma tv was gettin mew down the manual mwill help
  • Fernie Nov 14, 2011
    the links to the manuals are dead... can you please re-post those manuals? thank you.
  • Chris Cole
    Chris Cole Apr 03, 2016
    Paul; clearly I'm six years late to this party. As "Fernie" said, can you repost the links to the service and repair manuals?
Phillip 50PF9630A/37. I have a red blinking 7 times after a green light. i've allready replaced the 2 bulging cap on the bottom of power supply board and also a cap on the Y board (board on the left)...
Hello sir Jose!!!!
try to unplug the y sustain only and power ON your TV..and see what happen next..
Please reply to this tread for immediate help..
Feb 20, 2012 | Philips Televison & Video
Philips tv model number 50PFP5332D 37 wont power up
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
Philips 50PF9630A/37 plasma TV will not power on and has a red blinking light - 6 slow flashes then 3 quick flashes . I've been having the issue on and off for about 2 weeks. seems like when I ...
Hi.
The TV is forced in standby because an internal fault has been detected. 6 blinks slow and three fast blinks points at defective Ysus board or defective buffer. The power supply must also be tested. Till now the TV was starting because when you disconnect power you discharge internal components. Some of the components have the role of storing charge (the capacitors). If a capacitor is defective the TV may still work as other components will compensate the function of the faulty part. After a while more components will fail and the TV will not start anymore. To fix the problem the TV must be tested at component level. Testing will start from PSU voltages to YSus and buffer boards.
Regards.
Ginko
Aug 04, 2011 | Philips 50PF7220A Television
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
RED LIGHT BLINKS SEVEN TIMES
The most likely problem are two failed capacitors on the main board in the center of the TV The failed parts are easy to identify as the top of the cap will no longer be flat but will have bulged up. DO NOT attempt to remove the back of the TV unless you know what you are doing.
soldering on a circuit board will be required to fix this problem.
Aug 10, 2009 | Philips 42PF7220A 42 in. Plasma Television
Blinking red led light when I plug in the tv then it turns right
Phillips purchases the main circuit board from Samsung, and it has a problem with capacitors failing. The failed capacitors can be easily identified as the top will no longer be flat, but will have bulged up.
If you have a local TV repair shop they can help you.
Jul 26, 2009 | Philips 42PF7220A 42 in. Plasma Television
System will not power up
Remove the back from the set and look at the power board in the center of the TV. It will probably have one of more capacitors with the tops bulging out. Replace them with the same value part. Available from radio shack and almost any electronic suppliers.
May 16, 2009 | Philips 50PF9731D/37 50 in. Plasma...
Magnavox Plasma HDTV Red light
I had a similar problem with my magnavox tv with the blinking light issue. Eventually it just didn't come one anymore. Looking at other forms they said the problem was a bad capacitor number 2074 located on the power supply board. When I opened my tv, I noticed that the capacitor was bulging and burnt up. I bought a new one labeled 2200uf 35v and did some solder to attach the new piece. Put the tv back together and it works like new. No more blinking light. I hope this helps.
Feb 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 50PF7220A Television Logo
498 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
