Question about Samsung SPN4235 42 in. Plasma HDTV
42" samsung SPN4235 plasma tv
Tried to power up my tv I have no picture or sound also power on light does not come on can you please help me with this problem. I may be able to do some voltage testing if neccessary I have a digital voltage tester
  • 1 more comment
  • epmd Apr 08, 2008
    I opened the back of the tv I checked the power lead at the plug noise filter plug in connection I have 120v at exit to circuit board connector plug entering the board. I also checked the (3) small fuses 250v 5AMP they have travel through power.
  • epmd Apr 08, 2008
    my outlet power supply have 120V I do not see any loose connections, I also do not smell any electrical burn the tv is out of warranty
  • epmd Apr 08, 2008
    I have no standby light, or click sound when I try to power on the tv nothing lights up
  • 3,037 Answers
No power anywhere you say? hmm (Am I correct in assuming that there is no sound of the tv trying to start?)
Well first thing I would check is if there is power coming out of the outlet. If there is, then tv is problem and if not, then not tv of course
Second, if the first don't work then I would open up the tv and check the board, see if anything looks broken or smells burnt. Make sure you have it unplugged of course and be careful about what you touch. I would leave it unplugged for say 4 hours and if nothing looks bad, then plug it back in and see if it starts working again.
If you want to know what to check then look at the board and everything attached to it
Also, if this is a newer tv, you should check to see if there is actually enough power coming from the outlet to give it sufficient use. These require a ton of power and your manual should say how much is needed.
Please update me on the situation, thank you
Posted on Apr 08, 2008
  • 3 more comments
  • Benjamin Patri
    Benjamin Patri Apr 08, 2008
    have you checked how much power the outlet is putting out?
    thanks for the update
  • Benjamin Patri
    Many times people that have this problem take it to a dealer or repair shop and they can't even figure it out, if it is still under warranty, I would consider doing that
    Have you seen any places where there is a loose connection at all that may need to get soldered back together?
    These tvs, need a lot of energy to get started, so my best bet is that the outlet might be the problem try switching to a different outlet.
  • Benjamin Patri
    does the tv even try to start up at all, is there a clicking sound or anything?
  • Benjamin Patri
    well with everything that you said, I think the board has gone bad from excessive heat most likely and needs to be replaced
  • Benjamin Patri
    Benjamin Patri Apr 17, 2008
    were you able to fix this from the information I provided. Please let me know
  • 4,234 Answers
When you attempt to start this up is there anything that occurs? A click perhaps? Is there a standby light? Does the standby light blink? If so, how many times?
Please update this with the answers and we should be ale to guide you along to a fix.
Thanks,
Dan
  • ABRsvcs Apr 08, 2008
    Thanks for the update. These plasma sets utilize what is called a switch-mode supply. These supplies either work or not. These are not the easiest to diagnose. Also, there should be a standby supply as well. This one should be active as long as the set is plugged in. Can you see a standby indication at all? If not, we need to look at the standby supply area first. Without the standby supply, nothing will work.
    Dan
    Unfortunately teh only replacement parts available for these sets are complete modules. Unless you have experience with this type of equipment, I would not suggest you start here. Even at the authorized service centers, it is rare to repair a module. The modules are replaced. Check with a local service center for the cost of the power supply module. That is the most likely problem area. If the problem was further into the set, you would have the standby voltage present. It is possible that there is a problem that is preventing the standby from being apparent, but that type of failure is extremely rare.
    Dan
Sound no picture
Sound but no picture....
Should ask yourself, does it PRIME? Meaning, That's where the Plasma panel lights up a little for about 10 seconds after startup. -- If it doesn't prime, then you need either the SMPS, YZUS, possibly both. OR you might need to check the ZSUZ. Driver boards can be culprits too.
And can you even get to the Menu, Volume, etc. but just picture?
Then you need the signal board.
Unfortunately that's pretty common with Plasmas. Can burn out or burn "in" easily.
Here's a great forum you might like. http://www.austech.info/electronics/20607-lg-plasma-tv-has-no-picture.html
Different Brand but similar problem. This site is excellent for do it yourselfers. As for Samsung Parts, be thankful if you are a DIY-er that the parts are much cheaper if you install yourself. Separate with installation adds up very quickly. Personally, I decided to go with the Rear Projection Samsung several years ago and haven't had any major problems. Heard then that Samsung was having lots of complications of this nature.
Here's the link to Samsung Site:
http://www.samsung.com/us/support/owners/product/SPN4235
You can try the tricks on this site:
http://www.broadbandreports.com/forum/r22996341-samsung-spn4235-sound-but-no-picture
To be honest though sounds like either bad SMPS and/or bad Y-SUS pcb's.
Wish you good luck.
Mar 08, 2011 | Samsung SPN4235 42 in. Plasma HDTV
5 blinking red lights when turned on
When you remove the bad check for bulged electrolytic caps, that need change, or change out the power supply.
Oct 18, 2010 | Samsung SPN4235 42 in. Plasma HDTV
I have samsung plasma tv 42" ps42c7s,have sound but dark ,no picture
Hi friend,,,
welcome to fixya
Commonly for Plasma tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Samsung SPN4235 42 in. Plasma HDTV
The sound works but no picture at all.
its eht is not working so call a repairing man then put it new. the original costs about 2600
May 20, 2009 | Samsung SPN4235 42 in. Plasma HDTV
My tv wont turn on now
sounds like you fried your digital board or power supply not sure need more info on what tv is doing
Dec 30, 2008 | Samsung SPN4235 42 in. Plasma HDTV
My Samsung SPN4235 42 in. HDTV
you could to go to samsung website to call the customer support to get an authorized repairman to fix it for you,unless it is still under warranty which you should take it back to the retail store you got it from.
solutiondoct
Jul 30, 2008 | Samsung SPN4235 42 in. Plasma HDTV
IF THERE IS SOUND, PROBABLY THE Y-MAIN BOARD, IF IN WARRANTY CALL SAMSUNG
May 02, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung SPN4235 42 in. Plasma HDTV Logo
111 people viewed this question
Henry  Thomas
Henry Thomas
