Question about Razor E100 Electric Scooter
My electric scooter stopped running. it turns on but wont "go"
  • 56 Answers
Make sure battery is freshly charged and is holding the charge would have to test battery with multi metre. If its holding its power then first i would go to the switch that you use to make the motor go.
Posted on May 30, 2010
Razor Scooter ground fOrce go cart wont go
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
Feb 07, 2015 | Razor E100 Electric Scooter
Scooter runs then stops I turn offf the key and then it runs again and then will stop again also the scooter seems to have lost speed over time
the batteries are worn and problably need replaced , the computer will stop running the scooter at threshold voltage, older batteries and will hit this threshold voltage and slow the scooter
Jul 09, 2010 | Electric Mobility Mobility Electric Power...
Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
My 150 scooter wont stay runnung
strip carb clean jets could be clogged up adjust air mixture screw tighten it then turn 1 &half turns take it long run then adjust timing screw give that atry mate
Mar 21, 2010 | Peg Perego Vespa Scooter
Schwin scooter not running properly
If the battery is old its likely that it needs to be replaced. Also, if batteries sit in the cold in the winter or are exposed to high heat they can be damaged. Try checking out http://www.batteryinternational.com/electric-scooter-batteries.html for a scooter replacement battery.
Jun 09, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
How dose my scooter stop
right, what scooter is it, You can try putting it in reverse slowly and that will bring your scooter to halt then reverse so take care, what brand and model of scooter ? Regards GeWiz
Apr 15, 2009 | Pride Mobility Victory 3 Wheel Electric...
My wifes strider chair runs a bit the stops. Then she turns off the key, turns it back on and it runs a little bit a stops. The green light stays steady until it stops then blinks..any help?
Ztarg is the Medline Industries approved service and parts distributor for the Strider and Gemini Scooters.
Their contact information can be found on their website www.striderscooterservice.com
Dec 15, 2008 | Electric Strider Midi 4 Wheel Mobility...
Razor E100 Electric Scooter Logo
955 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
