Question about Lexmark X1150 All-In-One InkJet Printer
Broken ink cartridge carriage. need to know where to buy spares
    President:
  • 3,085 Answers
Throw it away
Posted on May 30, 2010
My Dell A920 black Ink holder broken
call DELL technical support number and ask if there is available spare parts for broken cover replacement, you might end up replacing the whole ink carriage.
Jan 13, 2013 | Dell A920 All-In-One USB Color Inkjet...
Hello. My Epson Stylus CX 4200 now flashes the letter E and all the lights flash, including "error." How do I get it working again?
here's what you can do:-disconnect the printer from the computer-turn off the printer-inspect for anything foreign inside like jammed paper-turn the power back on-remove the ink cartridge-check the chip connnector at ink tank and at head carriage. If its dirty clean it with soft moist cloth. -check the status monitor. which ink tank not recognized. -press ink light (1-4 times) depends on number ink tank not recognized, press 1 time again, carriage will move co replacement position, unplug and plug again all ink tank, press ink light 1 more.
if that doesn't work, replace ink cartridge ONLY if you have a spare. DO NOT BUY new ink as the printer is bound for repair.
Nov 13, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Open door clear carriage and then press ok to continue
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
it also can be the defective cartridge itself causing such problem..!!
well if u r a professional then just dip a cotton into isopropyl alcohol n gently rub the connector sensor/ contact surface, n reinsert it properly, gently rub on the head too n make sure ink is coming/flowing, make sure the toner is not jammed or dried up, also have a glance on the 'carriage' n see that no sensor pins are broken and or bend..!!
..if u r not an professional, make sure it is properly inserted and the ink-spill protective/head covering is removed and call ur system admin....
if all the above fails, then it may b a defective cartridge..!!
Oct 26, 2009 | HP Photosmart C5280 Printer
Black ink carriage broken
with most laser printers nowadays, it would be easier to junk the one you have and go buy one from wal-mart or someplace of the like than to have it fixed. most printer manufacturers dont even sell replacement mechanical parts through their sites anymore... its just not cost effective to either the producer or consumer.
Aug 26, 2008 | HP OfficeJet R80xi All-In-One InkJet...
Ink cartridge carriage HP 7410
i would trace the line back and put a small wire to replace the broken path.
Jan 13, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Broken ink cartridge mover
No Spares no fix- unless you can find a scrap one. Printers tend not to be fixed because they are so cheap to buy- just like small domestic elctricals Breakit-Binit-Buy the next one
Jul 18, 2007 | HP DeskJet 5650 InkJet Printer
Cartridge clip broken
They would rather you buy a new one. You may try try following number, it to is Dell repair. *For prices and availability on spare parts for this system call 1-800-357-3355. It is a critical piece that is broken. Let me know what happens. Good Luck, Tim
Mar 14, 2007 | Dell A940 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
