Question about Dryers
Dryer drum is rotating, timer appears to be working, but dryer not getting warm
  • 185 Answers
Is it gas or electric
Posted on Apr 08, 2008
The selector knob on my Whirlpool LER4634JQ1 does not move, so the dryer will not turn off automatically and no "end of cycle" buzzer sounds. Do I simply replace the timer?
Your timer most likely does need to be replaced. The timer has a small motor that causes it to rotate during the cycle and those can go bad causing the timer to not advance. Unfortunately, you cannot get just that timer motor anymore. Hope this helps!
Feb 16, 2015 | Whirlpool Dryers
Why does Drum does not rotate
can be severl causes check drum rotates by hand freely is good most common fault is the capacity needs replacing
Jun 08, 2014 | Fisher and Paykel Dryers
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
I have a Kenmore 80 series and the motor is not running but the heating coil comes on, what can be the problem? I have traced all wires and they appear to be OK
You could have a faulty motor, or possibly a faulty timer switch.
Try this:
Unplug the dryer, reach inside and try to rotate the drum 1/4-1/2 turn.
Plug the dryer back in and push the start button and see if it starts to rotate.
Sometimes motors get dead zones in them and this will help rotate the motor out of the dead zone.
If this does not solve the problem then the thing I would check is the motor.
Again unplug your dryer from the electric. Remove the box on top of the dryer that contains the timer switch, start switch, etc.
Be real careful not to knock any wires loose off of the timer switch.
Remove the top of the dryer, then remove the front of the dryer to expose the drum and belt, remove the drum and belt to expose the idler arm with pulley and motor. Now is a good time to check the condition of the belt and the drum rollers also. I will suggest that you oil the drum rollers at the shaft with a good grade of machine oil such as 3 in One oil. This will save a problem of a squeaky roller in the future. If the drum rollers have flat spots on them they will have to be replaced.
Then check your motor.
Note: Make sure you note how the belt route is, this will come in handy when you go to put everything back together.
If the motor checks out ok, then I would think it is the timer switch, you will have to replace the timer switch as they are not repairable.
I will include a couple of websites that have parts and live chat assistance:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Good Luck,
I hope this helps.
Oct 19, 2009 | Kenmore Dryers
Dryer drum won't rotate
if there is no air coming out of your vent on back of dryer then it would be likely your motor has gone out.
Jun 24, 2009 | Dryers
Whirlpool Dryer Drum Won't Rotate
sounds like your drum belt has broke. remove two phillips screws at lint screen. pull top towards you then up. you will expose drum.
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Dryer Drum not rotating
If warm air is still coming from the unit, but the drum is not rotating, it sounds like your drive motor is fine, but your drive belt is broken. Depending on you dryer model, these can be fairly easy to check, or may take a little creativity to get the dryer apart. Knowing your dryer model number would go a long way towards assisting further.
May 06, 2007 | Whirlpool LSW9750 Front Load Washer
Dryers Logo
51 people viewed this question
Top Dryers Experts
