Question about Acer Aspire One PC Notebook
Wireless doens't work on my 7535 - it connects to the router, but not to the internet - internet does work on the main computer
  • 857 Answers
You have to do a few steps to check the problem : 1.Check if the wireless switch is on, on your laptop.
2. If it is on then check if the network adaptors are installed or not. You can check that by going into device manager ( start - run - devmgmt.msc). If it is not installed you will find a exclamation mark or simply go to your manufacturers website and update your wireless driver.
3.Then go to Start\Connect To\Show All Network Connections (or, if this doesn't show up on your computer, Start\Control Panel\Network And Internet Connections\Network Connections). For your wireless card, remove it from the bridge (right click on the wireless network and enable it if it is disabled and then if you have a option remove it from bridge click on that.)
4.Restart your wireless zero configration. Go to control panel/Administrative tools/Services, right-clicking on the "Wireless Zero Configuration", and telling it to stop. After it stops, right-click on it again, and tell it to start, and then wait a minute or so and see what happens.
then try to connect and see if you can for this go to the network and sharing center search for all the wireless networks and try to connect. I think this should do it for you. If not reply with the message or error you get.
Posted on May 30, 2010
Testimonial: "thanks for your help - it works now"
  • 421 Answers
Hi, hope this helps.
Access TCP/IP property.
Select "Obtain an IP Address Automatically".
Press OK
Try to browse
Testimonial: "thanks for your help - it works now "
    President:
  • 1,851 Answers
Let's make one step at a time to control the problem.
If you connect your Acer laptop at the router with ethernet cable do you get internet bowsing?
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Testimonial: "it works now. thanks for your help "
Second computer is not connecting to wireless
Check if you have DHCP enabled on your router.
If DHCP is enabled check Wireless Settings
Feb 20, 2010 | Dell Wireless 2350 Router
Can you hook up the ps 3 to the internet router to get online with out using a computer
do you have a wireless router?
depends on how your internet is set up
but if your internet is set up like this
internet plug on wall>>>wireless router>>>>main computer
then you can connect to the wireless router without having the computer to be on
if you can use the wireless internet using a laptop then i dont see why it wount work for the ps3
if you dont have a wirekless router and your internet router has several eithernet ports then you can run a either net cable from the router to the ps3
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
Cant connect to internet with main computer, one upstairs is fine
The upstairs computer is wired or wireless ?
If the upstairs computer is working then the router must be working properly.
Check the connection between the downstairs computer and the router.
If it is a wireless computer then check the wireless connection status on that computer.
Click Here for step by step solution
Nov 05, 2009 | Belkin Computers & Internet
Slow internet for my hardwired computer
its because ur belkin routers MTU is not properly configured in the products ... u need to lower doen the MTu speed ..
Sep 25, 2009 | Computers & Internet
I hooked up wireless internet and my main coputers internet isnt
check the connection or from where u r connected the wireless connect just see that the problem will be solved ok
Aug 22, 2009 | 2wire 2700HG-B Router (2700HGB)
Connection to my Desktop not working.
Try and change the cable from the router to computer with a new one and do the same with the modem and see if connects. Hopefully it's just the cables that are faulty.
Aug 11, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Wireless internet
you are going to have set up the router for wireless user to hook up so to speak
Jun 15, 2008 | Computers & Internet
Can't connect
First if your computer has an ethernet port attempt to connect through the router to the internet with a wire. If that works the next question is did you buy this device new or used? If used we can work to assure we know the configuration of the device. Second what is the manufacturer and model of your computer? Third, if the wireless adapter is not built into the computer what do you know about the make and model of the wireless adapter? Armed with the above information we should be able to resolve the issue.
Thanks
Dec 04, 2007 | NetGear WGR614 Wireless Router
Belkins router not connecting to cable modem
You need to start from beginning. Clear all temp internet files and run this programme Start>Run ipconfig /flushdns and hit enter. Get into the routers settings(probably 192.168.2.1) and ensure in the Lan settings that 'DHCP Server' is on and wireless is enabled.(you might need to be connected by RJ45 lan cable first) If it's a 125mbps router change settings to 54mbps to try that speed first(especially as your wireless cards will be 54 mbps) look in Mac address Filtering is off. Look in the DHCP Client list and see if your pc's were allocated ip addresses, if so it should allow an internet connection. Go to both your pc's wireless cards properties and under TCP/IP properties ensure obtain ip address automatically is checked. Restart both pc's and the router, disconnect cable and try wirelessly
Mar 07, 2007 | Belkin (F5D9230-4) Wireless Router...
Acer Aspire One  PC Notebook Logo
176 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
