Question about Siemens HB77L65GB 900 Watts Convection / Microwave Oven
How do I change the lightbulb in my siemens quantumspeed HB77L65GB microwave?
Change lightbulb
most times you have to take the outer case off (the stainless steel part) and then you can see all the wires circuitry etc. thats how you get to the light bulb. make sure you unplug the microwave first and do not touch where it says electric shock hazard it will shock you even if not plugged in
Jul 16, 2012 | GE JES1142SJ Microwave Oven
Hello, I have a microwave Siemens HF 66051.The oven is working perfect,but the microwave doesn't.The fuses are well. Do you have any idea?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
This is a job for a proffessional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 03, 2011 | Siemens HB77L65GB 900 Watts Convection /...
HOW TO CHANGE VIKING MICROWAVE LIGHTBULB VMOS200
The Viking VMOS200 is essentially a rebranded Sharp R-530E.
One or both of these service manuals should cover disassembly and location of the bulb:
http://www.microwavedisplay.com/r530ekt_r530est_r530ewt_sm.pdf
http://www.microwavedisplay.com/r530es_sm.pdf
May 28, 2010 | Viking VMOR205SS Microwave Oven
HF87960GB Need to change lightbulb,how? Cant seem to locate it can anybody help please, Tony
on the top of the oven there is a plate with 2 hex screws, just undo these and your see a bulb and BINGO!
Oct 17, 2009 | Siemens HF87950GB Convection Microwave...
How do I change the lightbulb?
4359741 You have to remove the outer case and it will be accessible. Eric
Aug 02, 2009 | Whirlpool GT4185SK Microwave Oven
Shorted it while changint lightbulb
some microwaves have an internal fuse.
Mar 23, 2009 | Maytag MMV5207AAS Microwave Oven
Changed lightbulb
simply changing the lightbulb should not cause a problem like that. It sounds like you accidently shorted out two terminals during the process, which probably blew out the power board on the unit. I wouldn't trust it any further unless you were to take the entire unit apart and find the "blown up" component and replace the board that it's on. Believe it or not, it's not that hard a job if you're up to it.
Apr 22, 2008 | Goldstar MV-1526 Microwave Oven
CHANGING LIGHTBULB ON MICROWAVE
they should be torx # 15 0r # 20 this is not aifficult tool set to get unless the manufacturer put high security type torx and those have a small nipple in the middle of the screw so the tool has a small hole in the middle of the end. Good Luck
May 21, 2006 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Siemens HB77L65GB 900 Watts Convection / Microwave Oven Logo
104 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
