No audio from SM10 mike, PTT ok I need a schematic can anyone help
    Prodigy:
    An expert who has answered 500 questions.
  • 611 Answers
The SM10 does not come with a PTT switch. It simply has an XLR on it that will plug into any mixer with an XLR mic input.
Posted on Jul 22, 2010
I have a Vintage kinematix reverb with 5 wires red,yellow,white,brown and black how I hook it up what are the wire? it also has a delay tuning knob
usualy you have a transmit recieve switch
like this
.....common
RX <<-- >TX ptt
so three wires
the ptt button common in a cb with 4 pins is also ground
should be
black screen and i think brown
but you need to meter out the ptt common and RX TX
for rx audio switched radios then one pin is RX one pin is TX one pin is common or ground for the PTT and also ground for the screening copper braids and also ground for the transmit audio
so you have 5 wires
3 will be PTT 1 will be audio and one audio ground
usually white or yellow
so i think black and yellow or black and white
black being ground
just look up the schematic or service manual for your CB
and check out the 4 pin plug config
there is only two usual ones
cybernet or uniden so.. easy stuff
look for like cybernet cb 4 pin wireup in google or similar
remember just meter out using the beep test range on a cheep multimeter too see which three are the PTT
so the common of the ptt needs connected to the copper screening and also to the black wire all to the ground pin on the 4 pin plug
you can short from the ground pin on the cb side to its TX pin and the set will enter tx mode
same with rx audio enable {if uses most cb post 1984 dont use RX audio hard switching}
so just three pins to worry about
Dec 03, 2014 | Radio Communications
Hi I have the T5622 talkabout with a PTT headset. I can transmit OK but I am not receiving anything other than a ''click'' when the other person transmits. I have tested the headset and I am able to recive...
Here a few thoughts which come to mind.
1. You do not mention whether the radios communicate with the headset no on the radio. I will at this point, assume they do.
2. Be certain to have the radio SHUT OFF when plugging in the audio device.
3. Check your VOX settings. It could be your radio is going into VOX mode.
4. Only use the PTT button on the headset. Do not press the PTT on the radio at any time while using the headset.
5. Check that you have CALL TONES shut off.
6. Lastly, if nothing else works, go back to a basic mode, and set both radios where there are no special features turned on. ie turn off CODE, Qt Filter, VOX, Call Tones, etc.
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Feb 05, 2010 | Motorola Talkabout T5720 (7 Channels)...
Heil microphone gm series wiring diagram to suit kenwood ts 450
This is the pinning of the GM-series.
pin 1- Ground / shield
pin 2 - Mic (audio)
pin3/4 - PTT
On the 450 the next;
pin 1 - Mic (Audio)
pin 2 - PTT
pin 7- Ground (Audio)
pin 8- Ground (PTT)
Good luck,
Gerard
Jan 21, 2010 | Heil Sound PR-40 Professional Microphone
My T5530 don't transmit audio to another radio, you can hear the.
good am, if no audio, try to check the microphone if its ok? , if not, just change, if its ok, try the PTT maybe the switch is busted or need cleaning, most cases is the need to clean due to dust and moisture. just spray contact cleaning fluid. - DU7UV
Apr 09, 2009 | Motorola TalkAbout T5530 2-Way Radio
Mike to CB
This has worked for me in the past
Pin 1: Shield and Blue (Mic shield and PTT ground)
Pin 2: White (Mic Audio)
Pin 3: Red (PTT)
Pin 4: No Connection or Mic Return
Note: The Yellow and Black wires are not used.
I hope this helps,
Thank you,
Shuttle83
Nov 03, 2008 | Radio Communications
Kenwood ts-450s - cannot tune and no ptt
This is usually due to a stuck or shorted ptt line. I have repaired a couple of these and it was the same component each time. The packet TX transistor Q65 shorted causing the radio to power up in TX inhibit mode. Transistor Q65 is located on the underside of the IF board under the ACC 2 connector. This switching transistor is used only for tx (pin 9 of acc 2) and no other circuits depend on it. It can be removed completely if you don't mind not having ptt on acc 2.
This seems to be a common problem lately, I hope this helps you.
Apr 26, 2008 | Radio Communications
Very old astatic 525 mike wiring
Hello..maybe not a solution..but a hint..measure red-black for 0 ohms while pushing "ptt button" i think it's ptt...bare and transparent is mike...but you can look at original mike and make the same measurement for finding out what is ptt..the two others is mike ...good luck...Ron
Mar 13, 2008 | Galaxy Radios DX-44V 40-Channels Base CB...
No audio output with internal OR external speaker. Any suggestions? Could it be audio circuit and is this a common problem? Also need schematic for 75-822.
Unfortunatly this is a common problem. I have found that the mic switch ( PTT Switch ) doesn't always make good comtact internally ( You might spray some contact cleaner in the switch ) and also you might look close at the speaker jack in the radio. It may have broken contacts ( the lead broke loose from the board ). Resolder them and it should work. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 18, 2007 | Midland 75-822 40-Channels Handheld CB...
PTT SCREEN HAS UNABLE TO ADD CONTACT MESSAGE:
I had this problem and we needed to contact our cellular company to verify settings. After some time looking into the problem they said it was a hardware malfunction and swapped phones for us. I think there must be a solution to this problem that the cell representatives did not know about.
Oct 22, 2007 | Motorola Mobility V365 Cellular Phone
458 people viewed this question
 Grubhead
Grubhead
