Question about Philips HD-5702
We've tried to start our Phillips Espresso Bar type HD5702/A, but can't seem to get the water to go into the coffee; Are there a step-by-step instructions on how to get it going (we got it from a friend without instructions, and are lost as to how to use it).
There are merely 3 controls on the unit, two swithes on the right hand side and a turn knob on the left hand side. Press the upper switch - power should go on as indicated by a red light, the orange light of the lower switch indicating the unit is heating up. When the orange goes off, you can press the lower switch whitch starts the compressor to pump up the boiling water into the coffee. During coffee preparation the orange light may go on from time to time indicating the unit is reheating. Stop the pump when coffee is enough. When turning the knob on the left by 90degrees the unit will produce steam and feed it out through the metal nozzle at the left of the unit.
Posted on Nov 28, 2010
Problems whith astoria argenta
Hi just a tip from experience, grind the coffee fine and keep the spout ( where the coffee comes out) very near the cup, while making the coffee.
Kolbrun
Mar 06, 2014 | Astoria Coffee Makers & Espresso Machines
Problem with Miele CVA615 Espresso Machine Water
Frankly, there are things wrong that are beyond your scope, mainly because of the domino effect in small espresso machines no matter who makes them. There are multiple thermostats instead of a pressurestat, and on and on trying to replicate what a commercial machine does. In a machine like yours, the slightest failure of a gasket throws off everything. There is better containment of problems in commercial machines, but that too depends on what fails first.
My advice, if you are a home user, would be to get a manual pump machine , such as a Pavoni, (which I have lost respect for since they employed plastic pistons,) or if for a small cafe or bar, something like a semi-automatic job plumbed through a filter. Either way, in all honesty and that has cost me dearly, I warn you about this coffee business, because it is a science and an art.
It is not easy to make a good cup of coffee or espresso, especially.
Oct 10, 2013 | Miele CVA615 Espresso Machine
Yellow light keep coming on when i try to make a cu of coffee
the optical sensor that reads the bar code could be dirty. My Tassimo sensor also needs to be "wet" before the disc is inserted to work properly. Seems that the plastic of the sensor has started to degrade and clouded over. When you clean the sensor just use soap and water. Nothing abrasive.
Feb 22, 2011 | Bosch Tassimo TAS4511UC Coffee Maker
Descale button not lit, but the machine has been in use for 2 years and manual says to descale. All steps have been followed: solution is in machine water tank. Program is set to FILTER NO/HOLD. ...
You've done it all correct but before you add the solution (making sure to remove the filter), try holding the descale button down for over three seconds. As long as the FILTER NO is your filter setting, this should work. You may want to try to descale more often in the future but hopefully this helps you get started NOW. Best of luck!
Feb 22, 2011 | Bosch Benvenuto B30 Espresso/Coffee Maker
I have a Saeco Spidem Villa. Iâ??ve been
I dont understand what exactly happen when you try to make coffee? Is the coffee comes out or no?
Apr 20, 2017 | Saeco Spidem Villa
Espresso maker doesn't work properly
It is clear that there is a problem with water supply. Check if pump works, if it does, there is blockage in water supply to pump. Check and clean.
Jul 11, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
I have Saeco Royal Coffee Bar. Hot water and
Hi
You may have a flow meter that is bad. If its white plastic check for corrosion at the wire terminals. If your have corrosion change the meter and you should be good to go.
Apr 10, 2009 | Saeco Royal Coffee Bar Coffee Maker,...
Gaggia Syncrony does not get past the grind cycle
Water has probably been spilt in the beans area. The grinder needs cleaning out along with the chute
Feb 24, 2008 | Gaggia Syncrony Compact Coffee...
Philips HD-5702 Logo
834 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
Ross Keen
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
