Question about Dryers
I have an early maxidry 457 dryer can u show me how the main tension pulley is fixed with spring attached. i m changing belt, and pulley assembly fell apart, and ill be damed if i can figure it out...cheers nic
nic
i did the same mistake. now i am not sure what to do ? did u fix your problem?
cheers, Vin
Posted on Jul 26, 2010
  • satvin_gill Jul 26, 2010
    hi nic.
    i have the same problem. did u get to fix yours?
    cheers,
    Vin
  • Stuart Walbridge Sep 27, 2013
    Love to know the answer
Simpson Maxidry 362. Tips on putting back together....? Roller tensioner spring attached to...?
Here are the steps to get the belt and tension pulley and spring attached properly.
1. Remove the drum from the dryer housing
2. Fit the belt around the drum, secure the belt to the drum (grooved side towards the drum, flat side away from the drum) with small strips of masking tape. Leave a loop of about 10-15 cm's free to fit around the motor. (This was Hurdle #1, it was next to impossible to hold the belt on with one hand and attempt to work out the tension pulley thing at the same time)
3. Place the drum back in to the dryer housing and rotate it so that your belt loop is facing the motor.
4. (Hurdle #2) Attach the tension pulley to the motor assembly bracket. (There should be slots in the bracket for the pulley bracket to insert into. The pulley faces away from the motor, about a 45 degree angle.
5. (Hurdle #3) Feed the belt through (under) the pulley and then over the motor's drive wheel or nub, whatever it's called.
6. (Finaly Hurdle) Attach the spring to the pulley assembly. In the centre of the dryer housing floor, there should be a seam, in the centre of this seam there is a small hole where the other end of the spring attaches too. Stretch and insert the other end of the spring into this hole.
7. Remove the masking tape that's holding the belt down.
8. Re-assemble dryer and your done.
Jun 20, 2008 | Dryers
I'm trying to hook up the belt which came loose from the drum. While trying to loop it around the motor pulley, the motor pulley came free and I can feel a spring attached to the motor pulley and the...
the idler pulley keeps tension on the belt itself, and is a complete unit,, it slides into a grove,, and once the belt is correctly installed ,, thats what holds it in place, heres a good reply from another question that may help you with pictures
http://www.wikihow.com/Change-a-Clothes-Dryer-Belt
Aug 03, 2010 | Maytag PYE2300AY Electric Dryer
Can you tell me where I can print instructions for free to help me change my timing belt in a 93 ford festiva
Here are the instructions for removing the timing cover, and for replacing the timing belt. If this is helpful, please click my accept button! Thanks!
Remove accessory drive belts.
  1. Remove water pump pulley to pump hub attaching bolts, then the pulley.
  2. Remove right inner fender panel to gain access to crankshaft pulley.
  3. Remove outer crankshaft pulley attaching bolts, then the outer stiffener/spacer and outer pulley
  4. Remove inner stiffener/spacer, attaching screws, inner pulley and baffle plate.
  5. Remove attaching bolts, then the upper and lower timing covers.
  6. Reverse procedure to install. When installing crankshaft pulley, ensure curved lip on baffle plate and deep recess of inner pulley face outward
  1. Remove timing belt covers as outlined previously.
  2. Remove timing belt tensioner pulley attaching bolt, then the tensioner pulley, spring and spring cover
  3. If reusing old belt, mark direction of rotation on belt to aid installation.
  4. Remove timing belt from crankshaft and camshaft sprockets.
  5. Check crankshaft and camshaft sprockets, tensioner pulley and timing belt for wear or damage. Replace components as necessary.
  6. Align camshaft and crankshaft sprocket timing marks with marks on cylinder head and oil pump housing
  7. Install timing belt. If reusing old belt, ensure belt is installed so that direction of rotation mark made during removal is positioned correctly.
  8. Install spring and spring cover onto tensioner pulley, then install pulley and attaching bolt. Do not tighten bolt at this time.
  9. Install tensioner spring onto anchor, then tighten pulley attaching bolt to torque listed at the end of this section.
  10. Reinstall timing belt covers.
This photo shows timing marks.
Jul 14, 2010 | 1993 Ford Festiva
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
Hi i need to fix the belt that rotates the dryer
MOST SERVICE COMPANIES WILL HAVE A BELT, OR RING SIMPSON ON 131350
BEFORE YOU FIT THE BELT MAKE SURE THE CENTRE PULLY IT GOES ON SPINS FREELY- IF ITS TIGHT IT WILL RUIN THE NEW BELT.
Jul 06, 2009 | Dryers
How to fix a Simpson Maxidry 1000p?
Idler pulley and spring have come off while cleaning dust from inside cabinet a diagram whould be a great help as Im 500kms from nearest service place simpson maxidry 1000p Ray bushed
Jul 26, 2008 | Dryers
Fitting tumble dryer drive belt
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Mar 28, 2008 | Dryers
Dryers Logo
130 people viewed this question
Top Dryers Experts
