Question about Logitech WingMan Formula Force GP Wheel And Pedals Set
Help sourcing spares
My wingman FF racing wheel needs a new right side microswitch board as I can no longer use the gear changer button. Where can I find one?
Best bet is a whole new (well, second hand) wheel from Ebay. There were a couple of sites that made spare bearings & wheels for it but that was as far as they went I'm afraid.
Posted on Sep 05, 2008
SOURCE:
DVD player not working.
Hello
The changer mechanism should be suspected. It is a skilled work to look into. You have to disassemble it. There are three microswitches inside the mechanism, which give signals of the state of the mechanism to main system control IC. If the loading gear wheels have some problem, these witches won't engage well, and the the whole mechanism will be inoperative.
Mar 04, 2012 | Panasonic Televison & Video
Wingman ff gp gear paddles not showing gears,no power from gas pedal, Vista 64bit,configures wheel and buttons ok. 4 years since last used on win xp cheers
The drivers were made to work on XP, but I think I found one that may work on Vista for the steering wheel.
http://www.opendrivers.com/driver/240041/logitech-wingman-series-joystick-driver-5.01.256-windows-xp-vista-free-download.html
Now I am not sure whether it will work or not, there are alot of complaints for the wheel's pedals not working for games, but all the buttons working. Go into the control panel and look for the menu for controllers and input devices. Make sure all the settings are correct.
Apr 15, 2011 | Logitech WingMan Formula Force GP Wheel...
After winding 2 new bobbins, the LED screen remains showing the bobin being wound, even when bobin is removed from spindle and spindle is mived back to the left.
The front panel circuit board has a microswitch which is activated mechanically when the bobbinwinder is moved to the winding position. The error is most likely with the microswitch stuck in one position. The remedy requires you to have moderate mechanical aptitude. The best thing to do would be to take it to your dealer for repair. If you want to try to do it yourself, here you go:
  • DO NOT REMOVE THE SCREW HOLDING THE SMALL PLASTIC BOBBINWINDER STOP NEXT TO THE BOBBINWINDER SPINDLE
  • Open the top lid and, with a straight slotted screwdriver, remove the two large silver screws
  • Close the lid and raise the handle into the carry position
  • Loosen, but don't remove, the small phillips screw underneath where the right side of the handle rests
  • Pull the top of the right side cover over slightly
  • Remove the small phillips screw underneath where the left side of the handle rests
  • With the handle up in the carry position and the lid closed, lift the entire top cover from the left side first, exposing where the handle attaches underneath
  • Carefully bend the lower part of the handle to the right and detach it from its mount
  • Remove the top cover and handle
  • With the top cover removed, you can see the bobbinwinder arm make contact with the microswitch
  • If you are extremely careful to not touch the circuit board with your bare fingers or with a metal object, you can manually press the microswitch to see if it works
  • The plastic microswitch "button" may have become detached
  • The "spring" on the end of the bobbinwinder arm may have become bent
  • Don't remove the bobbinwinder assembly
Nov 09, 2010 | Janome Memory Craft 4900QC Mechanical...
How do i setup the g25 to my ps3
i have a g25 wheel on my ps3 it is simply plug and play.
if you struggle with buttons check this out it has all the functions:
Buttons for the G25 wheel and PS3
Top 4 The Black ones
Top-triangle-cancel-reverse(gear to back car up)
Left-square-cancel
Right-circle-E_brake
Bottom-X-enter You can also use the gas pedal for enter
Bottom 4 buttons The Red ones
Far left-no function
Second button-Change view
Third button-Pause-quick exit replay at the end of race-This button will also speed up the winnings (to keep from waiting with the cup spinning around so you can get back to racing)
Fourth button-best race line for license test
Buttons on wheel
Left-look back (default)
Right-nitro (default)
I change these two buttons around myself so I have the nitro on the left.
D-pad-same as the controller up,down,left,right. For menue use.
Also for (during race)
Look back-bottom pad
Look left-left pad
Look right-right pad
To change any of the button functions use the DFP settings in the options menue.
I have not used the wheel in photo mode. The only thing you can't do with the wheel is "exit" game. I also never have my controller on during gameplay I only turn it on to exit the game. If anyone needs anymore help with this wheel give me a shout-back and I'll try my best to help.
One last thing make sure your wheel is in the far left port(port 1) or port 3
Oct 08, 2009 | Logitech G25 Wheel And Pedals Set
6-cd changer says error 3 and won't eject CDs
hi i recently bought a lexus ls400 and it the trunk it has a ten disc cd changer by the steering wheel in the car is this little black box that keeps reading E-99 evertime i press play on this odd little box that is the control device to make the cd's play i've put the cd 's in the changer upside down right side up testing it and still the little black cd player play button/disc change button keeps saying E-99 my question is, is it a fuse or is this cd player thing near the stearing wheel just a peiece of garbage please contact me at [email protected] if you have any idea why this is doing this because i can't play any cd's theres no cd player where the cd/tape decks usually are in cars in the middle above the column shift. it would mean the world to me if you could help me out with any information as to why this brand new sony ten disc cd changer is giving issues to the cd player thing next to the stearing wheel on the right it's kind of hidden but it just won't stop saying e-99 no matter how brand new a cd i put in the changer thank you your friend john bunce
Aug 14, 2009 | Car Audio & Video
No lights no FF for momo
Vista simply doesn't support a lot of game controllers. Flight sim enthusiasts are still amazed that even Microsofts own Sidewinder sticks are not supported by Vista. Don't hold your breath for a patch either, so far Micrsoft haven't shown any interest in sorting out their own products, so your only hope is that some tech-savvy person happens to want to use the same stick and shares the driver.
Jul 14, 2009 | Logitech MOMO Racing Force Feedback Wheel
Mad Catz MC2 Universal Wheel and Pedals Set. I've
http://www.madcatz.com/Default.asp?Page=43 for the manuals
Jul 10, 2009 | Mad Catz MC2 Universal (6320) Wheel And...
What are the function of the buttons on gear shifter
Left-square-cancel
Buttons on wheel
Look left-left pad
Jan 13, 2009 | Logitech G25 Wheel And Pedals Set
Manual and Troubleshooting resource for InterAct V3 Racing Wheel - Sony PS2
Hi there 78 Racer, Press SET button the LED light will start to blink and beep once. Press the square button on the right hand side of the wheel. This will set it to Digital and pressing the circle will change it back to Analogu. The LED will stop blinking and a double beep sound indicates it's been set - that's it
Aug 20, 2008 | Cables Unlimited InterAct Racing Wheel V3...
Logitech WingMan Formula Force GP Wheel And Pedals Set Logo
127 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Ekse
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
