Question about Avocent SwitchView 2-port KVM Switch
Using switchview (SC4 UAD) kvm the keyboard keys hold themselves down and I am forced to hard power down my computer.
SOURCE: KVM hotkey
Hold down the Scroll Lock key for several seconds. The switch should beep briefly and blink. Hit either the "1" or "2" key on your keyboard to switch to the corresponding computer connection.
Posted on Sep 15, 2008
SOURCE: Power adapter of Avocent SwitchView® 1000
Usually, you can get away with a 12 DC adapter, at about 1 - 2 Amps, preferably switchmode. The center Pin is Positive & the Outer is negative. Most computer "Things" require 5 Volts & under for the IC's etc, and 12 Volts for Other communication IC's and Motors etc. So generally 12 Volts is a good choice. And you could get a 10 Amp unit because it will not matter as a unit will only "Draw" it's maximum, of whatever that is. So if the max draw was say 1 Amp, well a 2 Amp would be fine, but if the reverse were true it could not work. You also need a little head room, too which is why use use a 1:1.5 ratio, IE: The unit draws 5 Amps, your supply should be able to provide, at least 8. Now if you check on your unit it may even tell you the wattage, if this is the case, divide that figure by 12, that will give you the Current required in Amps, just get a supply with slightly more.
Posted on Feb 16, 2010
SOURCE: I have an Avocent Switchview
Is your switch a SCxPDV or a SC4UAD? Regardless, if it's a DVI switch, you can try place a DVI-D cable in between your HP PC and the switch. Do the same between the switch and the HP monitor. I'm guessing you are currently using a DVI-I cable between the PC and the switch. Some video card/OS combo send out analog signal when you use a DVI-I cable on the PC, which would not be displayed if you are using the digital port on the monitor. To read up on the difference between DVI-I and DVI-D cables, check out http://en.wikipedia.org/wiki/Digital_Visual_Interface
For future Avocent product related questions, I suggest you post them at Avocent's user forum http://community.avocent.com as it's monitored by their tech support team.
Hope this helps. Thanks.
Posted on Jan 07, 2011
Zphinx
  • 60 Answers
Did someone temper with the seal on the switch?
If not power down the Switch, power it back on, wait 2 minutes and reboot your PCs. What happens?
Posted on May 11, 2011
Zphinx
  • 60 Answers
SOURCE: i ve Avocent switchview osd.in
how did you connect from the switch to the server?
Did you reboot your server?
Posted on May 20, 2011
Reset password log in KVM SwitchView1000
This is the reset process for the SV1000 password. Enter all 0s in the password field, without pressing the Enter key and use a small pin to press and hold the reset button for 3 seconds or so that is located in the back of the sv1000 switch next to the power adapter#s connector. This process does not require the user to turn off the power for sv1000 and its connected target PCs.
#TreasureIt... It doesn't come easy.
Nov 28, 2013 | Avocent SwitchView 1000 - KVM switch -...
I have an Avocent Switchview SC4. This morning when I turned it on, I'm not getting the orange power light. Instead I'm getting a green light on the "A" station and two blinking green...
May 05, 2011 | Avocent SwitchView 10040-SC 4-port KVM...
I have avocent switchview 1000 8 port. it has been working ok for over a year. On monday I found that 4 computers are not displaying 2 windows 2003 server, 1 windows 2008 and 1 xp. I have tried switching...
What resolution are you using? And if you place the Avocent KVM cable to a different port, do you get a signal? If you use a Known good cable do you get a KVM session with good video?
Feb 24, 2011 | Avocent SwitchView® 1000 8-port KVM...
I have an Avocent Switchview SC4 DVI hooked up to an HP monitor and an HP computer with a NVidia 9500GT dual DVI card in it. If you hook the monitor directly to the computer it works. However, I can't get...
Jan 06, 2011 | Avocent SwitchView 10040-SC 4-port KVM...
Just bought a 4 port KVM and hooked it up and the USB mouse and keyboard arn't recognized by either of the two computers that were hooked up. The HOTKEYs are recognized by the KVM. The lights on keyboard...
is that a Mouse/keyboard combo ? If so, try with a standalone Mouse and a keyboard. If the Keyboard and Mouse need Special Drivers the solution might not work neither.
I hope that helped.
Oct 17, 2010 | Avocent SwitchView 1000 KVM Switch
All Keys do not work on keyboard with KVM switch
GCS632U is designed to work with standard USB keyboard an mouse only. You have to make sure that you are not using any type of adapter such as PS/2 to USB adapter. To further isolate the problem, please follow the steps below:
1. Connect the USB keybord directly to th computer to make sure that the keyboard is working properly.
2. Make sure that the keyboard is connected to the keyboard port on your KVM switch. You may take a look under neath this GCS632U (near the USB ports) and you will see an icon where to connect the keyboar and mouse.
3. If you're still gettings the same problem, Try power cycling this kvm switch by disconnecting if from the computers and disconnect also the keyboard and mouse from the KVM switch and leave them disconnected for a minute or two.
4. Reconnect everything after two minutes and then reboot the two computers.
5. If same problem exist, try using different USB keyboard.
NOTE: This KVM swith does not work correctly with wireless, gaming and smart keyboards because it's designed to work with standrd USB keyboard only.
Mar 23, 2009 | IOGear GCS632U 2-port KVM Switch
KVM hotkey
Jun 23, 2008 | LinxCel PS-121D 2 Port PS2 KVM Switch
Hotkey mode
This just worked for me. Using your PC keyboard, boot up to the PC first and then power up your mac. Hit the scroll lock twice and IMMEDIATELY hit enter. You have to go fast- click-click-click with no hesitation and it works great. I still can't toggle the hot keys to set up my mac keyboard, which I prefer using, but I'm assuming it takes the "right" timing on the keys. I'll keep trying.
Oct 23, 2007 | IOGear GCS632U 2-port KVM Switch
Avocent SwitchView 2-port KVM Switch Logo
1,184 people viewed this question
Top Avocent Computers & Internet Experts
gary433
Are you an Avocent Computer and Internet Expert? Answer questions, earn points and help others
